    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 10-01-2016, 10:24 AM   #2476
Trader Rating: 138 (100%+)
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-07-2016, 02:14 AM   #2477
Has anyone else had trouble with the servo moving from even the slightest of knocks? Both me and a friend are having this issue which we never had with the original Yokomo yz2.
Cheers
Mi4cxl is offline   Reply With Quote
Old 10-09-2016, 08:07 AM   #2478
Edit nm. Found my answer.
RB6.6/YZ-2 DT/'17 XB2 CE/22 4.0
YZ-4/B64D/22-4 2.0/D413
EB410 on order
YMMV is offline   Reply With Quote
Old 10-09-2016, 10:41 PM   #2479
Originally Posted by jpcopeland1 View Post
Thats too bad cause not only are the prices now not worth the cost to maintain the buggy, but they are also slow in getting new upgraded pieces that come out. I got sick of waiting for the longer rear arms and needed suspension mounts for the YZ-4 so I got them from Europe the day of release, Amain was almost a full month later.
Prices are comparable to everyone else. The alum hopup parts are pricey, but none are needed on the DT.
robbie_gtc is offline   Reply With Quote
Old 10-10-2016, 03:41 PM   #2480
MOmo's Avatar
Cheers
I had trouble with my Bmax CONSTANTLY. the screw in the servo horn would loosen or back out. I have V1 YZ-2 and so far, not too many problems with the horn or steering movement
MOmo
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 10-16-2016, 03:46 AM   #2481
YellowClip's Avatar
1. Does the heavier front lower suspension mounts weight show its overall weight or how much it's heavier than the original piece?
2. How do you achieve 20+ mm of front travel with the shock in the middle hole on arm without outscrewing the adjuster on the body?
Yellow Clip Racing Team
Awesomatix A800X/Yokomo YR-10F
YellowClip is offline   Reply With Quote
Old 11-01-2016, 04:23 AM   #2482
ironsylvain's Avatar
Originally Posted by PENN01 View Post
Just had my first run with my new dt edition and i must say it feels that good to drive already but does anyone have any tips for even more tuning for low bite outdoor track ?
Please try this one...
ironsylvain is offline   Reply With Quote
Old 11-02-2016, 11:59 AM   #2483
Trader Rating: 125 (100%+)
Originally Posted by GSM Storm View Post
This is a spring chart we made using a G Force spring tester, the rates may not be 100% correct but comparing one brand of spring against the other is.
Regards
Gary
Do you have any comparisons with the Yokomo Yatabe springs?
Chris Gierse is offline   Reply With Quote
Old 11-02-2016, 04:57 PM   #2484
Does the Exotek 24g front/rear brass weight fit on the CA/DT
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 11-05-2016, 01:33 PM   #2485
What is everyone liking for the yz2 ca for diff fluid tight high grip carpet?
turtle189 is offline   Reply With Quote
Old 11-05-2016, 07:00 PM   #2486
Don't know about the ca. It doesn't fit the dt. Hard to explain but basically it interferes with the motor plate.
71WOK is offline   Reply With Quote
Old 11-05-2016, 09:04 PM   #2487
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
3or5k depending on just how high your high grip is and the rest of your setup.
MarkA is offline   Reply With Quote
Old 11-06-2016, 05:16 AM   #2488
Thanks for the info. I went with the steel front/rear C mount.
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
Old 11-15-2016, 07:33 AM   #2489
YellowClip's Avatar
What servo arms do you use on your buggies?
I have the RJX FS-0521HV servo and have used the Robitronic lightweight aluminium servo horn. At the last race, my fellow competitor pointed out, that as the servo arm doesn't have any offset, the nut used to hold the rod ball end on to the arm hits the servo case and limits steering end point. The original Yokomo horn puts the servo link at a such big angle, which in my opinion makes the steering uneffective.
Old 11-15-2016, 09:53 AM   #2490
Trader Rating: 15 (100%+)
I am going to try a TLR aluminum horn for the 22. It seems to have a similar off set tot the OEM Yokomo plastic horn. I had to drill and tap it for the 3mm ball stud however. I also ordered a 20mm Kyosho turnbuckle from AMain I plan to use between the ball cups. The manual says to screw the cups together but I don't like the angle of the servo like that, I like th servo to point straight up for straight ahead wheels. I plan to add 5mm of a gap with the new turnbuckle and the cups.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
