    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 09-06-2016, 01:59 AM   #2431
Originally Posted by ProfessorX View Post
Here comes a sales pitch.
I would like to here the pitch as i have just received mine today
PENN01 is offline   Reply With Quote
Old 09-06-2016, 07:47 AM   #2432
YellowClip's Avatar
Hello
Got my YZ2-CA, have most of it already built. Car went together very well.
When building the shocks, they sounded quite squeaky, when finished. I have not yet put any oil in them. Is this normal or would it be neccesary to buy the machined pistons?
Thanks in advance.
YellowClip is offline   Reply With Quote
Old 09-06-2016, 09:36 AM   #2433
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
The machined pistons are the one must-have part for this car that doesn't come in the box.
MarkA is offline   Reply With Quote
Old 09-06-2016, 10:02 PM   #2434
YellowClip's Avatar
What pistons do You recommend? This thread's first page suggests 2x1.6 and Lee Martin suggests 2x1.6 and 2x1.7.
I also found that the steering link, that connects the horn and the rack, rubs the inner upper part of the bulkhead. Do I shave a little Of the rod end or have a done something wrong?
Old 09-07-2016, 09:02 AM   #2435
Moderator
MarkA's Avatar
2x1.6 front and 2x1.7 rear is pretty much the standard starting point on pistons.
If you are rubbing the bulkhead with the servo arm, take the arm off the servo and re-orient it 1-2 teeth more towards the left of the car on the servo itself. It is hard to tell in the manual (stare at the illustration on p20 for a while and you'll get it) but the servo horn doesn't actually go totally upright for center like most cars.
Old 09-07-2016, 11:38 AM   #2436
YellowClip's Avatar
The servo horn works fine and doesn't rub the bulkhead. Although as I use a large servo,which put the rod in a very bad angle, I switched the plastic horn for a 0-offset aluminium horn. When I installed the horn upright, I figured out it should be tilted.
The problem is, that the rod end on the steering rack side touches the bulkhead's arc, when turning right.
Also, is there a trick to make the clutch hole into the body.
Yellow Clip Racing Team
Awesomatix A800X/Yokomo YR-10F
Old 09-11-2016, 02:42 AM   #2437
JAE
Trader Rating: 28 (100%+)
Are yatabe springs all that much harder than standard Yokomo? Petit rc spring chart shows the actual measured rate of a yatabe green rear at 1.99 vs advertised 2.71? Just bought a set of Yokomo Orange and the rear is measured also at 1.99. What is a good setup for yz2 on super high bite and medium bite ? Looking for aggressive steering if driving a yz2 dirt. Any help on how to approach these springs or which sets to buy to experiment with is much appreciated
JAE is offline   Reply With Quote
Old 09-11-2016, 01:00 PM   #2438
What surface?
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 09-11-2016, 06:28 PM   #2439
JAE
Thx - need one for med-high grip(Ocrc) and also super high grip clay.
Originally Posted by kerby View Post
What surface?
Old 09-11-2016, 08:47 PM   #2440
JAE
Randy - which yatabe spring combos are you running? Need high bite and med/high bite setup
Originally Posted by Randy_Pike View Post
I'm pretty much running Yatabe springs on all my Yok's now.
Old 09-12-2016, 12:38 PM   #2441
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
DT or the 3 gear lay down version?
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 09-12-2016, 12:40 PM   #2442
JAE
Both please.
JAE
Old 09-12-2016, 10:46 PM   #2443
CW22's Avatar
Trader Rating: 93 (100%+)
Any one has an extra YZ-2 ball diff want to sell, please let me know.
Thanks.
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 09-14-2016, 10:03 PM   #2444
I am in the process of building the CA and was wondering what the handling differences are when the rear shocks are mounted in front versus behind the tower?
Thanks!
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 09-15-2016, 03:02 AM   #2445
Shocks in the rear feels more stable on bumpy low(er)-traction tracks. If the traction is up, mount the shocks in the front.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
hairymuffin
