    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 07-20-2016, 12:32 AM   #2341
JPucko's Avatar
Originally Posted by motorfinger View Post
JPlucko, is it the first version of the yz2 you have? If so then it wouldn't work on loose dirt and it depends on the type of traction you would get with the clay. If you have the CA version then I would get the stuff to convert it to the DT car for the loose dirt conditions.
Yeah I've got the original, which I put the 3gear because I was running indoor carpet. But that track is closing down so now there are just two tracks nearby, both outdoor dirt, low to med grip. I'm thinking to put the 4 gear back in, put a ball diff, shocks on rear of tower and that should be a decent setup for low grip track.
JPucko is offline   Reply With Quote
Old 07-20-2016, 12:37 PM   #2342
biggerT's Avatar
sell it on and put the cash on a dt ? you've got your 3gear a tower n a few little bits an your good for everywhere no
biggerT is offline   Reply With Quote
Old 07-21-2016, 04:15 AM   #2343
Trader Rating: 21 (100%+)
It's difficult to get it to work. I have had good luck running my original 4 gear on medium grip but it requires the Smc brass block. Anything less than medium it very difficult to drive.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 07-22-2016, 09:51 AM   #2344
the incubus's Avatar
Trader Rating: 17 (100%+)
Kerby,
I'm placing an order for wheels and tires tonight and I'm picking up the SS RR Hanger so see how it compares to the brass block I'm running on the back of my YZ now. I currently have it zip tied ultra-securely right on top of the Aluminum RR hanger, but I think the SS is going to weigh a tad less so I will need the SS RF Hanger and see what yields.
Yokomo SS RR Hanger: https://www.amainhobbies.com/yokomo-...300srr/p450429
Yokomo SS RF Hanger: https://www.amainhobbies.com/yokomo-...300srf/p450428
Exotek Brass RF Hanger: https://www.amainhobbies.com/exotek-...xo1568/p484268
I can't stand the crude look the SMC block so that is not an option for me and the weight isn't in the ideal location for medium-loose outdoor dirt anyway.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 07-22-2016, 06:50 PM   #2345
I have switched over to the DT and really enjoy driving that. Other than being a tad on the light side it's a great buggy. I will be trying the exotek 24g block next weekend...should lock it in pretty good
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 07-24-2016, 01:20 PM   #2346
Trader Rating: 30 (100%+)
I am using the exotek rear brass hanger in my YZ4 and like the results.
Norse is offline   Reply With Quote
Old 07-24-2016, 06:40 PM   #2347
Anyone try the Proline Predator body on the YZ-2 yet?
ROB RIVERA
Old 07-26-2016, 11:57 AM   #2348
Are there any aftermarket battery braces out there that don't constantly pop off for the DT? I've only seen them for the regular YZ-2.
checo55 is offline   Reply With Quote
Old 07-28-2016, 11:56 AM   #2349
SAMCRO's Avatar
It doesn't fit the DT car, you have to mill it down a bit..
SAMCRO is offline   Reply With Quote
Old 07-28-2016, 02:08 PM   #2350
I'm currently using the steel one and it fits with 72/34 gearing. Most likely will leave that one in place.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 07-29-2016, 04:14 PM   #2351
Pekr.da.skurl's Avatar
Does anyone here run the carpet addition on dirt with success?
Pekr.da.skurl is offline   Reply With Quote
Old 07-29-2016, 04:47 PM   #2352
I run the original YZ-2 on dirt and it's money w a touch of weight out back.
ROB RIVERA
Old 07-29-2016, 04:54 PM   #2353
Thank you sir
Old 07-29-2016, 05:28 PM   #2354
JPucko's Avatar
Have you kept the gear diff in it? What have you used to put weight and where?
Old 07-29-2016, 06:15 PM   #2355
I ordered the SS Rear hangers so I can get rid of my brass block I have on it currently. It souls end up weighing a touch more.
I run the ball diff in mine. I have pics posted a few dozen pages back. Let me look on photobucket.
Can't remember how much it weighs but it's almost double what the SS RR Hanger weighs.
ROB RIVERA
