    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 07-17-2016, 10:29 AM   #2326
EricW's Avatar
Originally Posted by Levelup View Post
Stock setup is decent. I recommend adding some weight under the battery getting red front springs and running a 19mm ride height. Gullwing front arms and gullwing shock tower are a must! I run 2 toe in vs the box's recommended 2.5 what turn motor are you gonna run? If you find the car needing more steering I can give ya a few tips on that.
Thanks for the help. Probably will run an 8.5.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 07-17-2016, 12:03 PM   #2327
JAE
Trader Rating: 28 (100%+)
How's everyone liking the Dirt car. Not many comments here on it. Also, haven't seen one for sale used here. Ever. Want to know some comparisons with xb2 dirt and b6d. I saw a yz2 dirt this weekend in the hands if a newer driver on outdoor wet dirt (holeshots and ribbed fronts). Looked great. Cornering exceptionally well and the driver liked it. Had sold his xb2 as he was frustrated with the out of he box setup and loved the yok dirt out of the box
JAE is offline   Reply With Quote
Old 07-17-2016, 05:43 PM   #2328
I'm liking the DT so far. I came from a B5M and I find that the DT suits my driving style better. The DT has increased steering response, jumps better/flatter, has faster corner speed, etc. All positives in my book. I cannot compare it to the B6D as I have never driven one
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 07-17-2016, 06:32 PM   #2329
Suspended
Trader Rating: 61 (100%+)
I know of several for sale, let me know if you'd like their contact information.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-17-2016, 07:18 PM   #2330
8.5 is perfect for this car that's what I run.
Levelup is offline   Reply With Quote
Old 07-17-2016, 08:45 PM   #2331
JAE
After all the time and energy getting my Xray dialed I've decided to stick with it. Curious what the going price is though.thx for the info
QUOTE=Socket;14604901]I know of several for sale, let me know if you'd like their contact information.[/QUOTE]
Old 07-18-2016, 04:15 AM   #2332
Trader Rating: 139 (100%+)
AE basically stole the ideas it had to make the B6D, so you know its a good car. But with a much better starting setup.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 07-18-2016, 02:24 PM   #2333
KrAcOn's Avatar
I'm working on my friends B5m... I test drive it... Then get my DT and go back on the track... It's like ah butter again.
DT>B5
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 07-18-2016, 02:30 PM   #2334
the incubus's Avatar
Trader Rating: 17 (100%+)
I've found that my original YZ-2>than B5, anything really for outdoor dirt. If I were a top level driver thorns' doubt I'd win most races I enter because when I can drive flawlessly no one can touch my car. It's on rails and reruns superbly and jumps perfectly. In one race wherein was super loose I dialed in a tad more wing and my car was the only one not spinning out under braking and wouldn't lose the rear powering through faster corners/sections of track.
I'm going to order the SS RR hanger to see if it maintains the same performance as with my added brass bar. If not I intend to modify the tungsten weight kit I have to assist in bringing the rearmost weight bias back to where it is now.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 07-19-2016, 03:12 AM   #2335
JPucko's Avatar
I've got the original yz2 and have recently put a 3 gear in it. My local carpet track is closing so the nearest tracks to me now are loose dirt and clay tracks. Would my yz2 go ok as it is or can I put a ball diff straight in, which would be better?
JPucko is offline   Reply With Quote
Old 07-19-2016, 02:42 PM   #2336
gokarter64's Avatar
so since i race on clay i want to get one of these but im not sure which way to go. i was thinking about getting the dirt edition and buying the carpet edition trans case set/ waterfall but i dont know what else i will need to finish the car? is there anything else different between the two cars? i already campaign a laydown 22 3.0 and its wicked fast in stock buggy.
basically what do i need to convert to the low profile transmission?
Cars: TLR 22 3.0 Mod, Mugen MBX7 ECO, TLR 22 3.0 Stock, TLR 22-4, TLR 22T 2.0
Electronics: Airtonics, Orion, LRP, Xpert, Maclan
Goodies: Exotek, Avid, Raw Speed, Jconcepts, MIP . Paint By: Double Deuce Designs
gokarter64 is offline   Reply With Quote
Old 07-19-2016, 02:44 PM   #2337
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
I know that the shock towers are different. I think that is about it.
motorfinger is offline   Reply With Quote
Old 07-19-2016, 02:47 PM   #2338
JPlucko, is it the first version of the yz2 you have? If so then it wouldn't work on loose dirt and it depends on the type of traction you would get with the clay. If you have the CA version then I would get the stuff to convert it to the DT car for the loose dirt conditions.
Old 07-19-2016, 03:56 PM   #2339
gokarter64's Avatar
ok so the waterfall works between both cases? it looks like the battery brace is different too
Old 07-19-2016, 09:47 PM   #2340
Default Differences DT-CA
To Gokarter64 , just had a quick look in both manuals ,the following are different:
rear shock tower , wing mount , motor mount , waterfall (gearbox support) , gearbox halves , upper suspension arm mount . If you download the manuals there was a link a few pages back on Petitrc I think.
Good luck
sm77 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
