    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 06-29-2016, 09:36 AM   #2311
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Amain actually isn't the issue. They're doing everything the can to assure we have the parts we all need and want. FYI
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-29-2016, 01:15 PM   #2312
JAE
Trader Rating: 28 (100%+)
How's everyone liking their ball diffs? I own 2 xray xb2's, and am installing the yokomo ball diff in one of them. For the mod, we use the xray gear but the rest yokomo with a yokomo 65mm dogbone. Xray's outdrives wear fast and are $30 per side! Hope the yokomo diff is a nice one
JAE
JAE is offline   Reply With Quote
Old 06-29-2016, 05:20 PM   #2313
I have to say the Yokomo ball diff is even better than Kyosho. The diff gear has a groove molded into it in line with the diff balls to keep the grease in place. And the thrust bearing screw had a large diameter head with a o-ring around it to keep out dirt. After three race days, two on very sandy soil, it is still buttery smooth.
speed90 is offline   Reply With Quote
Old 07-04-2016, 09:31 PM   #2314
Default Z2-415RS Questions
All,
I am interested in purchasing the recently released Z2-415RS aluminum rear hub / axle kit (66.5mm dog bone) and am confused. If we get this kit, is the only other requirement to run the Z4-008RS4 or Z4-008RL5 rear suspension arms?
It appears that if we want to continue the using the rear arms Z2-008R that came in the DT kit, we need to use an old B-MAX4 axle BM-10RAC (currently discontinued) and a 65mm dog bone Z2-01050B. I don't see the logic behind using this combination as the parts are not all available.
What are the differences between these rear arms?
Z4-008RS4
Z4-008RL5 (I believe this arm is +1mm wider for high bite conditions)
Z2-008R
Please let me know if i am missing something here. Apologies as this is my first Yokomo car. It seems like the Japanese cars (from my experience with Kyosho), allow the use of parts from other cars for added benefits/tuning options.
Thanks!
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 07-12-2016, 10:04 PM   #2315
Originally Posted by jpcopeland1 View Post
I don't have the car anymore, but mine was really good setup like this (using slicks). Front shocks: 1x1.6 30, red standard front spring, rear 2X1.7 green kit spring 27.5, 23mm front/rear ride height. All ballstud washers stock. Went out one hole on the rear shock tower. Car was dialed. Would have kept it, but I got sick of having USPS lose parts packages. They really need to get better distribution. Amain sucks.
Sounds like a mailman issue not Amain. I have never had a package lost. Order easily 20 or more times a year.
KW Raceway https://m.facebook.com/kwraceway
Mugen Seiki/Yokomo Usa/Protek/Amain/R1 Wurks/Flashpoint/KW Raceway
robbie_gtc is offline   Reply With Quote
Old 07-13-2016, 02:52 AM   #2316
dikke hond's Avatar
Guys, is the DT 3gearbox only compatible with the balldiff or does the geardiff fit to?
dikke hond is offline   Reply With Quote
Old 07-13-2016, 07:24 AM   #2317
I would have to guess the gear diff would fit. Idk why it wouldnt
Levelup is offline   Reply With Quote
Old 07-13-2016, 08:15 AM   #2318
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
Yes it does fit.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 07-13-2016, 12:06 PM   #2319
dikke hond's Avatar
Thanks!
Old 07-13-2016, 12:35 PM   #2320
JAE
What is the optimal anti-squat setting for the CE for rear traction rounding tight corners on power (just getting back on gas mid corner). Several theories on this but what actually works with the laydowns? thx all
JAE
Old 07-13-2016, 02:24 PM   #2321
Team Tekin
Randy_Pike's Avatar
2-3 is ideal in most cases. The more bite you have the less anti squat you need.
Old 07-15-2016, 07:41 PM   #2322
EricW's Avatar
My local track is switching over to turf from dirt, that makes 3 tracks within 45 minutes of me now running indoor turf. Rather than pick up a B6 I'm probably going to get a YZ2. Does anyone have a starting setup to use for turf that they could share with me? How's the kit setup work on turf? Are there any parts that need to be replaced/upgraded?
I plan to read through this thread I just want to get a starting point for a setup as I plan to get the car in the next week or so and it would take me longer to read this thread before I get the car.
Stickas are for straight up suckas......
**** "Luxury" ****
EricW is offline   Reply With Quote
Old 07-15-2016, 07:50 PM   #2323
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
I would get gullwing front arms and shock tower! gear diff with 3-5k and around 19mm ride height. I was running 37.5 fr and 32.5 rear shock oil. Also get off shapeways a front upper shock cover.
Pro-Line 1/10 2.2" Rear Buggy Closed Cell Tire Inserts (2) (Hard)
Pro-Line Pin Point Carpet 2.2" Rear Buggy Tires
Pro-Line Wedge Squared Carpet 2.2" 2WD Front Buggy Tires
JConcepts 12mm Hex Mono 2.2 "Slim" Front Wheels
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 07-16-2016, 11:56 PM   #2324
Stock setup is decent. I recommend adding some weight under the battery getting red front springs and running a 19mm ride height. Gullwing front arms and gullwing shock tower are a must! I run 2 toe in vs the box's recommended 2.5 what turn motor are you gonna run? If you find the car needing more steering I can give ya a few tips on that.
Old 07-17-2016, 09:28 AM   #2325
EricW's Avatar
Thanks, appreciate the help.
**** "Luxury" ****
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lexusbest
