    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 06-20-2016, 11:14 AM   #2296
Is it normal that the servo arm doesn't stand vertical when the front wheels are straight?I'm using a Sav÷x servo...thanks!
M.Boos is offline   Reply With Quote
Old 06-20-2016, 11:26 AM   #2297
Originally Posted by kerby View Post
Unless you're looking for bling, stock stuff is more than adequate.
Not really. I snapped a stock end cap and bent a turnbuckle in a not-so-tragic bump into a wall. I thought I'd step it up for lighter weight and durability.
checo55 is offline   Reply With Quote
Old 06-20-2016, 12:19 PM   #2298
Ya, it is normal. My servo arm is tilted to the left when looking from the rear of the car.
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 06-21-2016, 03:15 AM   #2299
Trader Rating: 21 (100%+)
Interesting... I run the stock ones on stock and mod car..... and my YZ-4. Im yet to break a part. I think the ball size are equal too the Kyosho ones 4.8mm
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 06-21-2016, 08:31 AM   #2300
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
Does anyone have a good starting setup for the DT car on Wet High Traction Clay? I looked on Petit but, they were all low traction or laydown trans setups.
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 06-21-2016, 10:02 AM   #2301
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'll see if I can get one of our local guys setup. I drove his the other day and it was $$
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-21-2016, 10:06 AM   #2302
the incubus's Avatar
Trader Rating: 17 (100%+)
Except for Ball Cups. They are barely adequate and the ONLY weak component on the car that I've come across thus far. I am going to change the front ones out but am considering the captured links from the B5 but not sure how well they fit. If all else fails I will go with my foolproof TLR Ballcups and studs all around.
No better Ballcups in my experience.
I hope this is the case because all I'd have to change are the cups themselves.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 06-21-2016, 10:18 AM   #2303
Start with Randy Pikes most recent set up on petit. The only changes I made was YAS orange front and back and Jcon 60 mm. I'll check the sheet at home later and post it if it will help.
Tfielding is offline   Reply With Quote
Old 06-25-2016, 07:39 PM   #2304
Moderator
MarkA's Avatar
The new rear hub carrier/axle/driveshaft sets have arrived at Amain, complete with nonsensical translation of what they do.
MarkA is offline   Reply With Quote
Old 06-27-2016, 08:18 AM   #2305
Thanks for the headsup!
Yokomo YZ-2
Yokomo YZ-4
Old 06-27-2016, 04:14 PM   #2306
cclifton's Avatar
Send a message via MSN to cclifton
I ordered the proline front wing setup for the YZ2, but I was wondering if any other front wings fit on the shock tower.
The Fleet:Xray:XT2 - Associated B6, B64
For Sale :Xray XB2 CE 2016 w/XB2 DE conversion
Poorboy Raceway and Hobbies
Grants Pass, OR
cclifton is offline   Reply With Quote
Old 06-27-2016, 04:15 PM   #2307
Azarashi makes a front wing.
ROB RIVERA
Old 06-28-2016, 02:06 PM   #2308
Trader Rating: 6 (88%+)
Default .
If I wanted to run the laydown transmission in my dirt edition, what all would I need? Does anyone have a part number list for the needed parts?
Thanks,
Chase Spears
_____________________________________
| Rb6 MM | Rb6 | ZX5 FS2 SP | SCTE 2.0
Roni45 is offline   Reply With Quote
Old 06-28-2016, 05:29 PM   #2309
Look at the CA manual online.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 06-28-2016, 09:43 PM   #2310
Trader Rating: 137 (100%+)
I don't have the car anymore, but mine was really good setup like this (using slicks). Front shocks: 1x1.6 30, red standard front spring, rear 2X1.7 green kit spring 27.5, 23mm front/rear ride height. All ballstud washers stock. Went out one hole on the rear shock tower. Car was dialed. Would have kept it, but I got sick of having USPS lose parts packages. They really need to get better distribution. Amain sucks.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
