    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree102Likes
Old 06-09-2016, 04:21 AM   #2266
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
Does anyone have a link to where there is a spring chart that compares most of the company's (AE,Kyosho,Losi,Yokomo) springs?
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 06-09-2016, 04:31 AM   #2267
Trader Rating: 21 (100%+)
http://site.petitrc.com/reglages/BuggyBigBoreSpring.pdf
AE B6
AE B64
kerby is offline   Reply With Quote
Old 06-09-2016, 04:44 AM   #2268
Thanks!
Old 06-09-2016, 07:53 AM   #2269
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by HYPA View Post
Thanks. Is there any reason why I should go for the Kyosho over the Yok/AE springs? Are they worth the cost?
I don't trust the AE springs because most AE drivers I talk to, around my area, are running Yok springs on the rear and Kyosho on the front.
I just picked up a set of Yok springs myself to try.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-10-2016, 12:49 AM   #2270
JAE
Trader Rating: 28 (100%+)
Awesome! My track is very similar to this. Would you happen to have a link for your esc settings for 17.5 blinky? Just picked up a few tekins to run in a lay down and a dirt
Originally Posted by Randy_Pike View Post
Check it out.
JAE is offline   Reply With Quote
Old 06-10-2016, 06:45 AM   #2271
SAMCRO's Avatar
https://www.amainhobbies.com/yokomo-...-500mr/p250006
How is the quality of the diff balls in this kit? Are the balls carbide?
SAMCRO is offline   Reply With Quote
Old 06-11-2016, 06:32 AM   #2272
Trader Rating: 138 (100%+)
Carbide balls. diffs are very good. On the same diff on my DT since the day it came out.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 06-11-2016, 10:13 AM   #2273
IT should be able to, yes. You'll need the trans, idler, shock tower, and shock tower spacer I believe.
Thanks for confirming. I'll see if I go that route of just buy an identically equipped CA when the need calls for it.
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 06-12-2016, 03:58 AM   #2274
I've just bought a used original YZ-2 and I've been searching the thread for setup info. I'm already planning to get a ball diff to run on clay and the machined shock pistons. Anything else to consider? What gearing are people going with for 17.5t Is the Exotek direct spur mount a good upgrade for 17.5t? Thanks.
The Exotek part is pretty nice. Goes together without much fuss and is quiet. I like mine. On a tight indoor clay track I run a 69/32-33. Works well.
Old 06-13-2016, 10:47 AM   #2275
Moderator
MarkA's Avatar
Ditto in my area on carpet/turf - the Yoke Yatabe springs are the spring of choice on most cars now whether it's actually a Yokomo car or not.
MarkA is offline   Reply With Quote
Old 06-13-2016, 06:26 PM   #2276
The DT version is a beast outside on medium to low grip. Made a few changes from the stock settings, man it's fast. 30 degree front block and 0 degree insert....I run 3mm Ackerman and most aggressive setting on the CF knuckle plate.... 2 degree anti squat and 0.5 hubs.
AE B6
AE B64
Old 06-14-2016, 11:05 AM   #2277
SAMCRO's Avatar
How much weight you have in the car? A shorty or full pack?
Old 06-14-2016, 12:24 PM   #2278
DirkW's Avatar
The only options on the YZ-2 are shorty or saddle/square packs. No room for a normal full size lipo.
Dirk
My On-Road cars: ((Xray T4'18)) | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: ((Yokomo YZ-2 DTM)) | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18)) | ((??Yokomo YZ-4SF??))
DirkW is offline   Reply With Quote
Old 06-14-2016, 12:39 PM   #2279
Shorty with the steel f/r suspension holder...no other weight.
AE B6
AE B64
Old 06-14-2016, 06:20 PM   #2280
JAE
What Yokomo springs are folks here using on high bite clay and med/high (OCRC), for the Yz2 laydown (or dirt).
JAE
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
OriginalDonk
