    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 06-02-2016, 11:14 AM   #2251
Originally Posted by wstuart View Post
Ive got the old yz2 4 gear that i race in 17.5 on high bite clay. I havnt raced in a year. I loved the car but wanted just a little more forward bite. Will the 3 gear give me that extra forward bite?
I drove my buddies dt tonight. Had great grip but didnt quite have the corner speed im used to.
The physics suggests, yes, you would get more forward momentum, however if its the wheels spinning thats causing poor forward bite, it wont help. The trouble is that it will be such a small difference it would be hard to detect especially run 17.5.
Piles is offline   Reply With Quote
Old 06-02-2016, 11:31 AM   #2252
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
It can help. The trick on the "old" car is to run softer rear springs to allow the weight to transfer while you get on the gas. Too often I see cars that don't move at all. I was running as low as a 1.8 lb spring in the rear.
High bite clay is also where I race, so take a look at my latest Yz2 3 gear setup.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 06-02-2016, 07:06 PM   #2253
JAE
Trader Rating: 28 (100%+)
Randy - what is your front spring rate and weight oil you are using front and rear? Thx
JAE is offline   Reply With Quote
Old 06-02-2016, 11:15 PM   #2254
kempower2000's Avatar
If you buy the 3 gear DT version car, yes! If you buy the 3 gear CA car, no, I guess it will be even worse than the old 4 gear car then.
If the grip is there, the corner speed can be dialed in.
kempower2000 is offline   Reply With Quote
Old 06-02-2016, 11:29 PM   #2255
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
MM3 – Mid Motor, 3-Gear
This was the first orientation for most early Mid Motor conversions. It is still suitable for cars running on a high grip surface eg. artificial turf and carpet style tracks.
The rotation of the motor is in the opposite direction to the rotation of the wheels. The torque of the motor is in opposition to the rotation of the motor and is ‘aimed’ in front of the motor. This causes the rear end to squat very little under acceleration and provides very little mechanical grip unless there is already sufficient grip from the tyres. Thus forward traction is not as high as MM4. The car’s weight distribution is also more biased towards the front than in RM configurations. The car will also tend to jump with a more level attitude than in RM configurations.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 06-03-2016, 03:29 PM   #2256
Apologies if this has been asked before...
I just ordered the DT to run at my local track, SDRC. A lot of people seem to be doing the lay down transmissions in the B5 and Losi 3.0. Can the CA lay down transmission be installed in the DT? If so, what parts are needed?
Thanks!
Yokomo YZ-2
Yokomo YZ-4
rbk1115 is offline   Reply With Quote
Old 06-03-2016, 07:31 PM   #2257
SAMCRO's Avatar
Originally Posted by WillS View Post
MM3 Ė Mid Motor, 3-Gear
The rotation of the motor is in the opposite direction to the rotation of the wheels. The torque of the motor is in opposition to the rotation of the motor and is Ďaimedí in front of the motor. This causes the rear end to squat very little under acceleration and provides very little mechanical grip unless there is already sufficient grip from the tyres. Thus forward traction is not as high as MM4. The carís weight distribution is also more biased towards the front than in RM configurations. The car will also tend to jump with a more level attitude than in RM configurations.
That is correct. Four gear will always have more grip than three. The weight transfer is to the rear with four gear on power
SAMCRO is offline   Reply With Quote
Old 06-08-2016, 03:22 AM   #2258
HYPA's Avatar
I've just bought a used original YZ-2 and I've been searching the thread for setup info. I'm already planning to get a ball diff to run on clay and the machined shock pistons. Anything else to consider? What gearing are people going with for 17.5t Is the Exotek direct spur mount a good upgrade for 17.5t? Thanks.
HYPA is offline   Reply With Quote
Old 06-08-2016, 09:13 AM   #2259
Team Tekin
Randy_Pike's Avatar
Check it out.
Old 06-08-2016, 09:15 AM   #2260
Team Tekin
Randy_Pike's Avatar
Thanks!
IT should be able to, yes. You'll need the trans, idler, shock tower, and shock tower spacer I believe.
Old 06-08-2016, 09:17 AM   #2261
Team Tekin
Randy_Pike's Avatar
I'd suggest a few sets of the Yatabe springs to be ready to adjust to your track conditions.
I run the Factory RC Avid/Sheele slipper eliminator on mine and it works well in 17.5 no issue.
Old 06-08-2016, 04:17 PM   #2262
HYPA's Avatar
Thanks! I was looking at the Kyosho springs but damn they're expensive. Anyone know what Yokomo spring is similar to the Kyosho white?
Old 06-08-2016, 06:10 PM   #2263
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I believe it is Orange.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-08-2016, 06:32 PM   #2264
Team Tekin
Randy_Pike's Avatar
Kraig is correct
Old 06-08-2016, 09:13 PM   #2265
HYPA's Avatar
Thanks. Is there any reason why I should go for the Kyosho over the Yok/AE springs? Are they worth the cost?
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
[email protected]
