    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 01-19-2015, 08:26 AM   #211
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by joehundy View Post
http://youtu.be/VLfji8XhMxs
Couple laps tonight ...with a gear diff on our track when it was dry and loose
And our track is just dirt
Looks good Joe
A Special Thanks to Arno and Rigor for there support...
http://www.rctech.net/forum/electric-off-road/664682-ae-factory-team-b44-2-thread.html
http://www.petitrc.com/setup/associated/setupb44/B44.2_BuildAdvice/
UN4RACING is offline   Reply With Quote
Old 01-19-2015, 08:53 AM   #212
mes
Brass from teamyokomo.eu:
mes is offline   Reply With Quote
Old 01-19-2015, 11:03 AM   #213
neallewis's Avatar
Looking good. Can see vid now. doesn't seem to be struggling at all there.
neallewis is offline   Reply With Quote
Old 01-19-2015, 01:49 PM   #214
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Just got off the phone with MIP. If we want a 17.5 puck system for the cars we need to send them an email to show interest. The email address is [email protected]. In the subject line make sure to address which version (mod or stock). Also reference the new axle length of 60.5mm as the length is not the same as the bmax counterpart.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 01-19-2015, 02:08 PM   #215
MOmo's Avatar
First off, SUPER JEALOUS of all the pics. Makes me want one BAD!!!!
Guess I'll have to wait till the 2nd order thru Amain. Hopefully the parts are coming too, just to have spares.
Originally Posted by mhuse6969 View Post
Ran on clay track today and was able to match my fastest bmax2 time on the second pack. I setup the buggy the same as my bmax2 and found that this buggy carries more speed in all areas of the track. The were no issues with the landings and it was actually very forgiving.
1.6 machined pistons all around
32.5ft 30r
Kyosho gold in rear and whites in front
middle hole in shock towers
stock roll center settings
So this brings up a good question for those who have the new YZ2 as well and the prev. versions.
-Are you starting with your prior working setup?
*it may be too soon to tell, but are you having to deviate much with the new car?
-Again, it still might be too new, but is anyone finding any neg. with this car over the prev. versions? Overall is this a better car that would make them replace the prev. version with YZ2?
-I plan to dedicate my Carpet action to the YZ2. My Bmax2MR is relegated to Dirt duty. Curious if others who have mult. track surfaces are planning to run separate cars, or are you seeing this car slowly taking the place of the Bmax2?
Can't wait to get one!
MOmo
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 01-19-2015, 02:23 PM   #216
joehundy's Avatar
Trader Rating: 15 (94%+)
Default Car
He is what mine looks like
Thanks to
AmainHobbies/Protek/RB/Upgrade Rc/Jconcepts/Odonnelle fuel
joehundy is offline   Reply With Quote
Old 01-19-2015, 02:30 PM   #217
303slowdown's Avatar
Trader Rating: 24 (100%+)
Why do you scuff up the wing? Looks good though.
where you running the shorty in the video?
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 01-19-2015, 02:39 PM   #218
MOmo
I have the b-max2 Mr v3 and now the yz-2 also. I started with the box setup but with 2.5 deg caster instead of the 5 deg. I feel the stock setup is significantly softer than the setup I was running on my v3 ( blue spring all around and 32.5f 27.5r oil) . Yz-2 seems to have more forward grip than my v3 ( witch I struggled to find on the v3) . I run on carpet most of the time so the yz-2 feels much better and faster than the v3. The v3 is going to get changed to rear motor and turned into my dedicated dirt car unless I can find an extra $380 to buy another yz-2.
Ryan Borgheiinck
Old 01-19-2015, 02:45 PM   #219
joehundy's Avatar
Default Wing
ROAR rules that the wings cannot be clear
And I ran the car just as it is in the picture
But I run al my electronics down the middle feels better that way
Thanks to
Old 01-19-2015, 02:50 PM   #220
I never new that rule. I'll have to try the electronic setup your running . Thanks for the reply.
Ryan Borgheiinck
Old 01-19-2015, 03:21 PM   #221
WillS's Avatar
Interesting this is the first time in 20yrs I have heard this. So I reviewed the book...
6.5 WINGS
6.5.1 Definition: Wings are aerodynamic devices attached to vehicles to increase down force and traction when a vehicle is traveling at speed. The dimensions of wings vary depending on the class of racing, and are described in class rules or specifications.
6.5.2 Only single element or two-element wings may be used, and then only when allowed by the class rules.
6.5.3 Wing Mountings:35
6.5.3.1 Wings should be mounted using wire or some other secure mounting system,and be no closer than 1/4” to the body except as provided below. The
distance between the wing and the body is measured between the rear deck
of the body and the flat portion of the wing chord.
6.5.3.2 Off-road wings may be mounted using wire or fastened directly to the
chassis. There is no minimum clearance for off-road wings. Front wings are
allowed if utilized on the body's full-scale counterpart. If allowed, front wing
dimensions are specified in the class rules.
6.5.3.3 On-road wings, when permitted, may be mounted directly to the body without clearance. Front wings are allowed if utilized on the body’s full-scale
counterpart. Driver must show proof of full-scale utilization.
6.5.3.4 Oval wings may be mounted to or through the rear window of the body.
6.5.3.5 In some classes, wings and spoilers may be used in combination. When allowed by the class rules, separate specifications are provided.
Will Smith
Sponsors:
Old 01-19-2015, 06:23 PM   #222
carver gt's Avatar
Trader Rating: 41 (98%+)
Send a message via AIM to carver gt
Does anyone know when amain will get there next batch of YZ2's?
We support and run-
Team Associated-JConcepts-sticky Kicks RC
carver gt is offline   Reply With Quote
Old 01-19-2015, 06:48 PM   #223
WillS's Avatar
If your wanting the car, my recommendation is put it on back order. Its a free of charge service and with the popularity of this car, you could be waiting for the 4rd shipment if the next shipment is small by accident.
Will Smith
Sponsors:
Old 01-19-2015, 06:51 PM   #224
Trader Rating: 312 (100%+)
Just finished my build, my last Yokoma was about 15 years ago. Have the ball diffs installed.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 01-19-2015, 08:05 PM   #225
STLNLST's Avatar
Trader Rating: 21 (100%+)
Mine should Be here in time for a build and racing on Sunday ;-)
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
