    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree39Likes
Old 05-29-2016, 04:11 AM   #2221
Originally Posted by M.Boos View Post
Is there a smaller spur gear than the stock 80T available?Thanks!
You can use Associated spur gears (direct fit). I run a 69t for stock
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 05-29-2016, 05:21 AM   #2222
Trader Rating: 21 (100%+)
Originally Posted by SAMCRO View Post
Thanks. I know the earlier chassis needs a hole drilled in it. I heard there was a kit to drill the hole, but couldn't find it anywhere. Would like to find it vs paying another 85 bucks
No need for a kit. Add the waterfall brace last and it's quite easy to figure out the hole location. Also, the composite side pod need dremeled to fit a shorty sideways...if you choose to run the battery all the way back.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 05-29-2016, 09:07 AM   #2223
One other thing you will have to do to convert is to file or grind the top of the rear front suspension holder to an angle, otherwise you will not be able to get the motor back enough. Look at the DT manual, the holder is a bit different. Took me about 10 minutes with a large file to mod mine.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 05-29-2016, 03:59 PM   #2224
Forgot that part....I'm running 72/34 and it works but anything smaller I'll grind.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 05-29-2016, 04:41 PM   #2225
That's what happens when you run stock... 😜
Old 05-29-2016, 05:54 PM   #2226
Guys,
FYI if searching for manual or setups.
Arn0 is offline   Reply With Quote
Old 05-30-2016, 04:29 AM   #2227
I'm forced to run stock, nobody runs mod at the local track. Guys running the DT, what changes from the stock set up have you made? I read only a few changes are needed
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 05-30-2016, 09:23 AM   #2228
SAMCRO's Avatar
What is the difference in these two towers? I am looking for Z2-017D, but can't find it anywhere so will have to decide between one of towers below. I am running on dirt.
https://www.amainhobbies.com/yokomo-...z2-017/p417670
https://www.amainhobbies.com/yokomo-...2-017g/p417671
SAMCRO is offline   Reply With Quote
Old 05-30-2016, 09:33 AM   #2229
YOKZ2-017 is for flat front arms.
YOKZ2-017G is for gullwing front arms.
And the kit DT-version comes with Z2-017D plastic for flat arms.
matterooth is offline   Reply With Quote
Old 05-30-2016, 11:12 AM   #2230
I bought an AE 75t spur (ASC9650), and the Yokomo slipper pads are a hair too big. Anyone experienced this? Should I attempt to cut down the pads to fit, or is there another brand of gear that has a larger pocket?
josh18_2k is offline   Reply With Quote
Old 05-30-2016, 12:43 PM   #2231
celt's Avatar
Default build/materials quality?
How would you compare the build and materials quality with other similarly priced kits?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-30-2016, 04:32 PM   #2232
Better than Kyosho IMO...plus the car doesn't need anything other than what's provided in the kit. Comparing this kit to AE is like comparing a Yugo to a Lexus
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 05-30-2016, 05:11 PM   #2233
SAMCRO's Avatar
Agreed, this is a great kit. The rb6 requires you to sand down the chassis, buy aluminum steering rack and drill holes in the chassis to fit the pack in.
What is the strength of the ball studs? In my other kits, i install titanium. Is that required on this car as well?
Old 05-30-2016, 06:20 PM   #2234
Mckune Design has an aftermarket slipper pad (2) that works very good with team associated spurs.
Team Novak® (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 05-30-2016, 07:13 PM   #2235
Better than Kyosho IMO...plus the kit doesn't need anything other than what's provided in the kit. Comparing this kit to AE is like comparing a Yugo to a Lexus
so You are loving the yoks then huh kerns? gonna get a dt for outdoors?
psycho02 is offline   Reply With Quote
