    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 05-18-2016, 12:37 PM   #2191
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jpcopeland1 View Post
http://www.losipartshouse.com/KYO96647-p/kyo96647.htm
The shims you need, use 1 .02 on both sides and your golden.
I actually like the SLIGHT side to side play in a diff because I take the shims and bend them at the half way point and point the peak side towards the bearings and then slide the tranny cases together. This ends up working just the way floating discs work on motorcycles which reduces friction and vibration. And while the life is static and centered, you can slide it side3 to side if you apply pressure on either side.
I also use this method on bell cranks systems when they have a touch of play because that play leads to slop. I crimp my shims at the half way point and again install them with the peaks facing the bearings and it all fits perfect without over tensioning the system.
Your method works perfect as well, but this is what I prefer.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 05-18-2016, 12:40 PM   #2192
Trader Rating: 139 (100%+)
The other option is to use the new main diff gear that is slightly wider on the DT version of the car, no washers needed.
TLR 22T 3.0 (Retired), XRAY XB4 '18, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-18-2016, 10:01 PM   #2193
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
A wider gear would not widen the diff. You would have to increase the diff ball size to increase the width. With increasing the diff ball size you would then have to increase the width of the diff gear to prevent walking of the gear to maintain smooth gear mesh between the idler.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is offline   Reply With Quote
Old 05-19-2016, 07:41 AM   #2194
I recently picked up a YZ2 off of the "for sale" section here and finally had a chance to take it to the local track. It handled pretty good on the clay track. I have a 17.5 with a 70/30 spur/pinion. The only changes I made to it were to mount the rear shocks to the rear of the arms and tower, and add a 25g shorty battery weight. The one thing I noticed is it's tendency to spin out when coming out of a turn on power. Is this an issue with the gear diff compared to a ball diff?
NhJeffS is offline   Reply With Quote
Old 05-19-2016, 10:19 AM   #2195
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Usually a tendency of the gear diff if the fluid is too light.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 05-20-2016, 11:10 AM   #2196
biggerT's Avatar
can somebody measure the DT. turnbuckles for me please (metric)just ordering up a gearbox n such for my wet car an noticed a different kit for the DT thanks
biggerT is offline   Reply With Quote
Old 05-20-2016, 02:17 PM   #2197
ReneT's Avatar
Steering 52
front upper 52
Rear upper 48
Yokomo B-Max 2 MR, YZ-2, B-Max 4 III, YZ-4, BD-7 2014 Black
ReneT is offline   Reply With Quote
Old 05-20-2016, 02:48 PM   #2198
biggerT's Avatar
many thanks
Old 05-20-2016, 03:45 PM   #2199
DirkW's Avatar
Yep, that's right what the manual says.
Dirk
My On-Road cars: ((Xray T4'18)) | Xray T4'17 | Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | ((Xray X1'18)) | Xray X10'16 | Yokomo SD SSG | ((VIP-Performance Vorlon/VTE))
My Off-Road cars: ((Yokomo YZ-2 DTM)) | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory>>>((??Yokomo YZ-4SF??)) | Kyosho Ultima SC6 | Tekno SCT410.3 | ((Xray XT2'18))
DirkW is offline   Reply With Quote
Old 05-20-2016, 04:22 PM   #2200
SAMCRO's Avatar
How does everyone like this car? I have been running the rb6 for quite a while and am looking at this and the X-ray car. Pros/cons to this car?
SAMCRO is offline   Reply With Quote
Old 05-21-2016, 08:41 AM   #2201
biggerT's Avatar
I ran rb6 before and I'm loving the yokes I've got the mk1 as a wet/low grip car now and it's faster than the rb in those conditions and the CA for high grip duties
the quality/durability is up there with the kyosho if not better in many ways no bling needed just machined shock pistons
Old 05-22-2016, 08:11 AM   #2202
Drove my car, and a friends Xray yesterday back to back, high bite clay so both cars were lay downs. The Xray was nice, but felt a bit dumbed down in the steering department. Setups were both close to box stock, so it was a pretty much out of the box experience, machined pistons, etc. we both agreed if someone wants a more aggressive car the Yokomo is the better option.
Old 05-22-2016, 12:38 PM   #2203
Ray Kindstrom's Avatar
Trader Rating: 147 (100%+)
Looking for a DT if anyone is wanting to sell. Please send me a PM. Thanks
Yokomo USA - Protek - AMain - ProLine - Fantom - Exotek
Ray Kindstrom is offline   Reply With Quote
Old 05-22-2016, 08:29 PM   #2204
SAMCRO's Avatar
I just got a YZ-2 CA and need to convert it to DT. Someone mentioned there is a kit to drill a hole in the chassis. Does anyone have a part number?
Also, what other parts are needed to convert it to DT?
Old 05-22-2016, 10:51 PM   #2205
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
both use the same chassis!
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
