    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree40Likes
Old 05-14-2016, 08:01 AM   #2176
Trader Rating: 137 (100%+)
Originally Posted by ProfessorX View Post
Just curious how's the car in mes to high clay lazy to check page by page. Thinking of picking the DE up. Soon
Both cars are awesome on high bite clay, just depends on what your looking for? If the track has a tendency to dry out, the DT will be the better choice, if it stays consistently high the CA will give you more corner speed, at the expense of losing a little rear grip (can be mitigated some by cleverly placing 5 gram weights under the transmission housing). I have and run both. The CA when the track is wet and gooey, then change to the DT when it starts to dry up (The people running my local track are notorious for letting the track dry up to very low dusty clay conditions). Driving styles obviously change a bit as the CA has more inherent corner speed (you need to keep the forward momentum up), but it's an easy curve to learn.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 05-14-2016, 01:14 PM   #2177
celt's Avatar
Default excellent value?
Looking at the manual/build, kit seems to come with every possible alu hop-up option out of the box. From my rough calculations, it's got to be near $200.00 worth of add-ons included for an extra $50.00 in kit cost.
Not a bad value. And...the parts are cheaper than AE's? Wow...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-14-2016, 03:13 PM   #2178
Is it possible to run the laydown transmission in the DT car? Are the chassis the same?
-Ryan-
CTRJ is offline   Reply With Quote
Old 05-14-2016, 05:01 PM   #2179
DirkW's Avatar
Same chassis for CA and DT (# Z2-0022) but different from the original YZ-2 (# Z2-002)
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 05-15-2016, 09:14 AM   #2180
Yep.
Old 05-15-2016, 01:44 PM   #2181
Is anyone using part # YOKZ2-300RUD the aluminum rear camber link mount, my question is what is the offset's when you flip the mount over.
https://www.amainhobbies.com/yokomo-...300rud/p493841
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 05-17-2016, 08:13 PM   #2182
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
My 2nd hand YZ2 CA Edition came with a gear diff and ball diff. Is there a preference of diff for 17.5 stock class on medium bite clay? When I install the ball diff, there is some side to side play for the diff when the housing is put together. Can anyone recommend what diff shims will work for the outdrives? My local shop doesnt stock yokomo but I can order online or if another manufacturer's shims work (i.e. AE) I can pick them up locally. Thanks!
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 05-17-2016, 10:39 PM   #2183
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Chirag
Where did you but it so I can get both gear and ball diff ????
ProfessorX is offline   Reply With Quote
Old 05-17-2016, 10:43 PM   #2184
I bought my YZ-2 CA used from someone on RCTech. He included a ball diff (looks like its from the BMAX2) along with the gear diff that comes with the CA car. I dont think that their is a specific kit from Yokomo at the moment that offers both.
Old 05-18-2016, 10:23 AM   #2185
Chirag
http://www.losipartshouse.com/KYO96647-p/kyo96647.htm
The shims you need, use 1 .02 on both sides and your golden.
Old 05-18-2016, 10:24 AM   #2186
The shims you need, use the .02's on both sides and your golden.
Thanks!
Old 05-18-2016, 10:26 AM   #2187
Thanks!
I've worked out a really good starting setup for indoor clay with the CA if you need a setup let me know.
Old 05-18-2016, 10:28 AM   #2188
Any help would be much appreciated!
PM Sent!
Chi
Old 05-18-2016, 11:05 AM   #2189
Is that 0.2mm?
NhJeffS is offline   Reply With Quote
Old 05-18-2016, 11:31 AM   #2190
Originally Posted by NhJeffS View Post
Is that 0.2mm?
Yes. Typo.
Currently Active Users Viewing This Thread: 4 (2 members and 2 guests)
DHooter, rcgerber
