    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 04-17-2016, 02:01 AM   #2086
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by SamuraiJack View Post
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one YZ2 wing mount? Thanks!
(Between the two vertical holes on one mount for mounting on the shock tower)
25.5mm -/+ 0.2mm
Edit.....sorry that's my bmax rear end I measured
hacker is offline   Reply With Quote
Old 04-17-2016, 06:17 AM   #2087
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
New to the yz-2 whats a good gearing for a 10.5 motor. Im running 78/23 also have a 75 spur gear. thanks
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 04-17-2016, 07:49 AM   #2088
You should be really good with the 78/23 I run a 78/24 on a medium/ high standard size track.
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 04-17-2016, 10:12 AM   #2089
thanks
Old 04-18-2016, 12:46 PM   #2090
motorfinger's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to motorfinger
Default YZ2 DT Ball Diff
I just got one of the DT cars last week and started building it over the weekend and I was wondering if anyone else experienced a flat spot after building the ball diff?
I got the diff together and went to rotate it and I felt a slight flat spot. I am sure that this is not typical but, I also not sure what is normal. I have run Kyosho's and never experienced this issue. has anyone else.? Thanks!
Team Kyosho (RB6, RT6, ZX6 & SC6)
Team Orion R10.1 Pro
Team Orion Touch Duo Charger
Team Orion Pro Carbon 100C Batteries
motorfinger is offline   Reply With Quote
Old 04-18-2016, 02:24 PM   #2091
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
I am looking into getting a 2wd buggy for stock racing on a clay track (SDRC in San Diego, CA). Would the CA (with diff) or the DT version be recommended for 17.5? I think the traction is considered high for a dirt track. Thoughts?
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 04-18-2016, 02:30 PM   #2092
KrAcOn's Avatar
I just finished my DT on Sunday. Diff is smooth like the last two I did for my other YZ's
So no flat spot here.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 04-18-2016, 02:32 PM   #2093
KrAcOn's Avatar
Originally Posted by cpatel529 View Post
I am looking into getting a 2wd buggy for stock racing on a clay track (SDRC in San Diego, CA). Would the CA or the DT version be recommended? I think the traction is considered high for a dirt track. Thoughts?
I have yet to run on that track. At LRH in Anaheim I run stock 17.5 on the normal yz-2. Car works good with the clay we have here. For Mod it didn't do as well so I bought the new DT version.
So I would guess you would want the DT.
LRH RACEWAY So. Cal
Old 04-18-2016, 03:09 PM   #2094
Suspended
Trader Rating: 61 (100%+)
Tito won the jbrl round in 17.5 with a laydown car. People run both there competitively. This is up to you and your driving style.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 04-18-2016, 06:10 PM   #2095
Thomas PA's Avatar
If you want to drive "touring car" style, then CA, if you want to drive "point and shoot" style, DT. IMO
Thomas PA is offline   Reply With Quote
Old 04-18-2016, 06:45 PM   #2096
Trader Rating: 21 (100%+)
Lay down is the new trend, just like front wings....lol. I have the orginal Yz and it's the whip in stock. I will be trying the 3 gear CA tranny once I can find one. I'm running on a med grip and it's pretty fast.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 04-18-2016, 08:01 PM   #2097
Thanks for all the help guys... I havent driven an RC car in over 10 years and when I did it was primarily 4wd touring cars. Found a good deal on a used YZ-2 CA Edition so I will be running that when it arrives... Cant wait!
What non-Yokomo wheels are people running? Also, speaking of the front wing trend, seems like a number of people at my track run one and anyone have any suggestions on which one to get for the YZ-2??
UPDATE: Ended up getting Yokomo front and rear wheels from Amain. Also ordering the proline front wing mount as a tuning option (along with picking up recommended tires, spurs/pinions, and ball stud spacers from local shop).
Also looking for a good starting setup for clay. Not sure who Tito is but I will have to see if I can get his JBRL setup for SDRC (assuming that he drove a YZ-2).
UPDATE: Fount some YZ-2 setups on PetitRC for OCRC that I will use as a baseline.
Thanks!
Chi
Old 04-18-2016, 08:06 PM   #2098
I thought my AE B5M CE was good but damn this YZ-2 is on another level on carpet!
Old 04-19-2016, 06:03 PM   #2099
Got my new yz-2 out saturday night and ended up 3rd in the A after literally the first time running it. Didn't run the front wing that night but I'm trying it out tomorrow night. Put a little weight out front to help with the tight corners. Jumped amazing with 60 wt up front and 50 in the rear. (Maybe stiffer than what people run on Ozite carpet, but worked well for me). Picked up some new gears and might try 84/18 for a 10.5T motor... my motor hits the trans with the stock 80t spur so I seems like i will have to go with larger spur and around a 19 or 18 pinion. Hopefully it isn't too low but we shall see!
jakearoo92@gmai is offline   Reply With Quote
Old 04-20-2016, 08:13 AM   #2100
Trader Rating: 59 (98%+)
Does anyone know if you can convert your original Yz-2 to a 3 gear? do you have to drill any holes in the chassis? and what else is different on the CA? trying to figure out if its worth getting a new kit, Thanks
Fundukian is offline   Reply With Quote
