    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree39Likes
Old 04-06-2016, 12:26 PM   #2071
Trader Rating: 24 (100%+)
Yep, AMain Hobbies has the YZ2's. Here's a pic I just snapped.
newob is offline   Reply With Quote
Old 04-06-2016, 01:49 PM   #2072
Woo Hoo, it's on the way
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 04-06-2016, 05:38 PM   #2073
Trader Rating: 309 (100%+)
Does the DT comes with ball diff?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 04-06-2016, 05:46 PM   #2074
Yes sir, it does.
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
Old 04-07-2016, 02:45 AM   #2075
Originally Posted by jakearoo92@gmai View Post
Cool thanks matterooth. I think I may go with a 10.5t Novak. Next major question would be about what gearing have you had success running? Don't know how tight the track is that you run on but any starting point would be good.
I run stock 80t with 22t pinion.
matterooth is offline   Reply With Quote
Old 04-08-2016, 11:17 PM   #2076
the incubus's Avatar
Trader Rating: 17 (100%+)
Alrighty then guys. Just finished redoing my ball diff using a B-fast kit and I ended up raising my drivetrain 2mm to see how it changes. Have a memorial race in the morning for a friend who lost his battle with liver disease and our track is hosting a free everything race in his honor.
I will be paying close attention to see how this change affects the car. I will say it was a real B to bolt it down because the rear bulkhead pushes everything forward as the tranny is raised, and with the higher position you really have to muscle it into position to align the screw holes.
By the way, I'm running 72/31 with my Fantom 17.5.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 04-09-2016, 01:52 AM   #2077
Is the drive ratio of the diff 2.60 like the B5. I was going to run 69/31 with my 17.5
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
Old 04-10-2016, 10:09 AM   #2078
vagnik's Avatar
Does anyone knows if the bmax2 gear diff fits the yz-2 dt?
Today had my first race with the dt edition....the car with the manual setup was really really good!!! With few tweaks I found what I wanted (stiffer front springs, short wheelbase and 1 deg anti-squat)! The track had med traction with med jumps and quite flat...from the first run it was a better car than my bmax2...
Ps: not a perfect driver, but...that's my thoughts...
vagnik is offline   Reply With Quote
Old 04-10-2016, 02:44 PM   #2079
Any reports on how the new carpet car is going compared to the standard version?
Crash C is offline   Reply With Quote
Old 04-10-2016, 05:33 PM   #2080
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Yes it does fit, however in the DT buggy they have changed the gear to 14 balls, not 12 and the gear is wider than the original Bmax2 gear
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 04-12-2016, 07:21 AM   #2081
Trader Rating: 137 (100%+)
Regards
Gary
And it's a better diff for it, however mine till longer then usual to break in, using a captured thrust bearing, kept loosening up until Sunday when it magically stopped, didn't bark it, but it felt loose on the bench and on the dirt, so take your time and break it in properly.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-12-2016, 07:45 AM   #2082
JAE
Trader Rating: 26 (100%+)
Default Fantom
How hot is the fantom running. I'm about to install and was told 72/33 and gear up if it gets hot? Would have thought the opposite and gear down. Temps and how's it running in the yokomo?
JAE is online now   Reply With Quote
Old 04-14-2016, 12:26 PM   #2083
BigP's Avatar
Hello
I did look after an answer what the gullwing front arms/tower do to the car, but didn't found something.
Does it make the car smoother in the corner?
The underground would be Astro.
BigP is offline   Reply With Quote
Old 04-14-2016, 01:06 PM   #2084
First run on ths car last night, ran at least as good as my B5M and had no time to actually tune it. It is Night and day compared to my orig Yz2. I run on a dirt track with low to med traction and lots of dust. The car was very neutral with lots of rear grip even a little bi9t of under steer, I changed front tires and got a lot more steering for the main. I'm impressed since I've been running the B5M for 7-8 months and lots of tuning time on it and my laps were just as good or better with this car, and I was way down on power too, (I put a bad motor in the car by mistake and didn't have anything else to switch to). To say the least I'm extremely happy with the new car.
madmikepags is offline   Reply With Quote
Old 04-15-2016, 06:52 AM   #2085
SamuraiJack's Avatar
Trader Rating: 38 (100%+)
Hello! Could someone do me a huge favor and measure the exact distance between the holes (center to center) on one YZ2 wing mount? Thanks!
(Between the two vertical holes on one mount for mounting on the shock tower)
❂ 8IGHT-E 3.0 ❂ 8IGHT 2.5 ❂ XXX-4 ❂ DEX210v2 ❂ SRX4 ❂ SRX2 MM
SamuraiJack is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
