    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree35Likes
Old 04-02-2016, 04:14 PM   #2041
Trader Rating: 137 (100%+)
Originally Posted by JAE View Post
Has anyone here driven the yZ-2, Xray xb2(ce&ode), and the b5m?
I'm curious to know the difference. Looking to get something different than my b5m and don't know which dorection to head. Usually drive at Ocrc and similar mid/high grip indoor clay tracks. Any help much appreciated! Thx
Car works fine with a few tweaks on high bite clay. The Dirt Spec should alleviate all rear bite issues some have with less then perfectly groomed high bite tracks. I stuck 30 grams under my gearbox on my YZ-2 "classic" and it's really good. As far as an all around car, I think the Dirt Spec will be better for US style tracks that aren't SRS, Coyote, etc.
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 04-02-2016, 06:03 PM   #2042
Trader Rating: 21 (100%+)
What set up are you guys using? My track is bumpy and medium grip... No where near smooth or high grip. Original car is great. I've had this thing out only a handful of times and I've tried a lot of different cars. The 3 gear is great for stock or super grip.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
kerby is offline   Reply With Quote
Old 04-03-2016, 02:06 AM   #2043
steam's Avatar
I can't seem to find anything showing there is a difference between the CA and DT chassis.
Where does it say they are different?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 04-03-2016, 07:02 AM   #2044
All of the literature I have seen for the DT says the car has holes in a different spot to screw the waterfall brace into, much like the holes that had to be drilled to run the Ymax conversion. Makes sense since the whole transmission is closer to the rear shock tower. Mibosport has an updated parts list on the Yokomo YZ-2/YZ-4 Facebook page outlining the list of the updated parts (but no pictures as of yet).
Old 04-03-2016, 10:03 AM   #2045
Chassis for both cars is the same.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 04-03-2016, 10:10 AM   #2046
Trader Rating: 16 (100%+)
The chassis is the same for the new CA and DT. It is not the same chassis as the original YZ-2.
MX304 is offline   Reply With Quote
Old 04-03-2016, 06:17 PM   #2047
biggerT's Avatar
new chassis has the same dimensions as the old one and just some extra holes for the DT waterfall. I'll be building my new CA onto my old chassis and keeping the old as a wet car with the DT gearbox as an option ,)
biggerT is offline   Reply With Quote
Old 04-04-2016, 02:24 PM   #2048
Well Mibosport has the YZ-2 DT and CA in stock
https://www.google.com/url?sa=t&rct=...18443451,d.amc
Yokomo Bmax4 lll / YZ-2 DT / YZ-2 CA
Fantom Racing
Savox/Spektrum
Airtronics MT-4
Hobbywing
rippen is offline   Reply With Quote
Old 04-04-2016, 02:54 PM   #2049
the incubus's Avatar
Trader Rating: 17 (100%+)
OK guys, sadly we got rained out this weekend and for some odd reason I ran a couple hot laps and all was good, but as soon as Q1 began, my diff was barkin' up a storm. Had to run it that way but it was tough to drive and was too inconsistent to do any better than 5th the first time out. Then I adjusted it perfectly but I did feel it beginning to get gritty but nothing too bad. Q2 started and I was off like bat out of hell and the car was magnificent!!! Was in 2nd place overall with a minute left to go and then someone lost it going into the hairpin after the straight and instead of waiting to get back not he racing line, he immediately took both he leader and myself out but 1st place was ok and came to a halt at the pipe but their contact shot the other car right into mine and I popped both front left turnbuckles. The marshal got them back on like a BOSS - WHOMEVER YOU ARE YOU ROCKED! - but by then I was almost a lap down and had to rip it up back through the field to finish 4th. Dialed does not begin to describe how well hooked up my YZ-2 was. This was on an outdoor dirt track and people asked what I had done to it and what motor I was running because I was fast. When I took it off, the diff was mega CrUncHy so I will be rebuilding it this week and will be installing the Mikune shim kit to see how much better this buggy can get.
One thing is for sure, I will not be looking at the dirt edition for some time, if at all. I contacted an aftermarket company to see if they'd look into producing a brass RR hanger because honestly, that's pretty much all I've done and it did the trick.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 04-04-2016, 04:08 PM   #2050
hacker's Avatar
Trader Rating: 140 (100%+)
Exotek and yokomo do brass and steel RR hangers
Surprised your standard yz2 handled outdoor!
Mine was crap from the get go, added weight under motor didn't help much
Ymax conversion transformed my car
hacker is offline   Reply With Quote
Old 04-04-2016, 04:45 PM   #2051
i just picked up a used yz2 with the ymax conversion. it has the bmax rear suspension hanger at the front of the rear arm. does anyone know how the inserts in that hanger relate back to the yz2 manual for setting toe and anti squat?
this is the front hanger i have
http://www.amainhobbies.com/rc-cars-...300mrf/p250016
steve_40 is offline   Reply With Quote
Old 04-04-2016, 04:56 PM   #2052
Exotek only makes the RF hanger from what I know, and I've not seen a Yokomo RR hanger. I have the tungsten weights for under the motor as well as under the battery, but I found those didn't do much of anything in the way of reducing oversteer enough, so in the end they don't work.
I placed my old DEX410 side weights at the very rear of each side plate and I then hung a brass weight off the very rear just above the RR suspension Hanger end it planted my car really well. Adding the RF hanger would not do the trick as the weight needs to be as far back as possible to mimic the characteristics of a rear motor car while still maintaining the superior performance of a true mid motor laydown transmission car.
This car is so neutral that it simply wants to rotate just behind it center axis so placing light all the way towards the rear forces it down and slows the rotational pitch.
I had so much traction this weekend it looked like my outside tire was coming off the wheel on the fast turns. I might just have to resume my former do it yourself methodology I did when I was playing paintball and make my own aftermarket upgrades.
Tough thing is my old machinist from my paintball days is now making some of the finest components in all of Mar tough thing is my old machinist from my paintball days is now making some of the finest components in all of RC and you might not be interested in doing work for a competitor.
Old 04-04-2016, 05:15 PM   #2053
Exactly!! The car is great as is. The shim kit and 0.5 hubs is the ticket for mine on medium grip. Glad to see someone else having good luck with original YZ... Peeps probably though I was crazy.
Kyosho Rb6.6
Kyosho ZX6.6
Kyosho Rt6
Old 04-04-2016, 07:30 PM   #2054
What pinion and spur is a good starting point running a stock 17.5 reedy m3?
Med outdoor track?
symodt is offline   Reply With Quote
Old 04-04-2016, 07:49 PM   #2055
Suspended
Trader Rating: 61 (100%+)
Can someone explain how the receiver is mounted in their stock picture, please?
Best Avatar on rc-tech
Socket is offline   Reply With Quote
