    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 03-15-2016, 08:59 AM   #2011
the incubus's Avatar
Trader Rating: 17 (100%+)
If that's the case ALL the top RC News sites are misinformed and need to retract their articles all reiterating the same information and Yokomo vendors as well.
http://www.neobuggy.net/2016/02/01/y...-dirt-edition/
https://www.teamyokomo.eu/yokomo-yz-...roturf-edition
It seems A-main has corrected it on their end.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 03-15-2016, 12:19 PM   #2012
Can't read then? "Those new parts are no possible to mount on the main chassis of conventional YZ-2. The new main chassis and side plate will be essential."
And the link you send from Yokomo Europe is the Carpet edition, not the Dirt edition. The dirt edition NEEDS the new chassis, see my previous post for part numbers.
株式会社 ヨコモ
dennisV is offline   Reply With Quote
Old 03-15-2016, 12:50 PM   #2013
It's apparent I'm not the one who can't read.
Having said that, correct... It is the carpet edition listed on the European site that says the cassis is compatible but you say is different. If you don't see the conflict, read again. According to you the parts are different but reliable RC News outlets and Yokomo's own vendors and/or region specific subsidiaries state otherwise. You may well be right but the fact is the information is inconsistent.
Now, if you go back and read the last sentence in my previous post you might notice I said A-main has changed the info on their site deeming your little attempt at an insult unwarranted.
If Yokomo got their act together and got around to actually posting the complete info on their own site this would be so much easier to understand for all interested parties.
ROB RIVERA
Old 03-15-2016, 10:51 PM   #2014
Rob - I'm not sure what's so hard to understand on the Yokomo EU website
YZ-2 Carpet/Astro Edition new parts:
3 Gear box for CA
New Motor plate for CA
New idler gear for CA
New Main Chassis CA/DT
Those 3 parts are possible to mount on the conventional YZ-2 without any manual modification on main chassis. The dimension of new chassis are the same with the current one.
There is a new main chassis for the new CA/DT editions that I would imagine contain the holes for the waterfall for the CA and DT editions. Given the CA edition is laydown also, you can mount the new 3 gear transmission, motor plate and use the new idler on the conventional YZ-2.
But you cannot mount the DT gearbox unless you were going to modify your main chassis to accomodate for the different position of the waterfall as you would do for a Y-Max conversion.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 03-16-2016, 02:17 AM   #2015
I didn't insult you at all - or I didn't meant to . I just have the right information and tell it here.
Just read the post by WagwanBumba:
The DT edition needs a new chassis (of course, you can modify the old chassis probably ), the CA can be mounted (without mods) on both the 'old' and 'new' chassis. Thus: the chassis for the CA is different (!) from the current YZ2. However (keep thinking) the CA can be mounted on the current chassis as well, clear now?
You can wait for my information to be correct (because it is), all those "news sites" are just copy-and-paste of each other. They simply don't check their sources.
株式会社 ヨコモ
Old 03-16-2016, 04:18 AM   #2016
gokarter64's Avatar
Originally Posted by MarkA View Post
I didn't remove mine from the car to measure so from roughly center of screw to center of screw = 12.5mm. Adjusting for a shaky hand, that makes it either 12 or 13mm
Why not order the YZ-2 wing mounts and then drill your tower for this other car after you physically have them?
Yea, im thinking that may be a good plan. Im doing a conversion for another car in autocad and decided to use those mounts, so ill just buy them and measure
gokarter64 is offline   Reply With Quote
Old 03-16-2016, 06:13 AM   #2017
hacker's Avatar
Trader Rating: 141 (100%+)
Ymax
How much weight are you guys running at/around the front?
I've got 20grams with a full size servo, still sucks at jumping nose high.
Don't really want to buy alu/brass bulkhead.
I"ll just keep adding weight.......
hacker is offline   Reply With Quote
Old 03-16-2016, 07:04 AM   #2018
shannow's Avatar
Weight shouldn't change the way it is affected while jumping as the acceleration of gravity only depends on time and not mass (+aerodynamics to be precise) . Adding weight will only reduce the effect because of pitch inertia.
It jumps nose high at every jumps or just a few ?
Idiot check : Is your throttle trim at zero (no coasting effect on the esc as well).
Yokomo YZ-2 , sanwa M12
Tekno EB 48.3 1900kv Hobbywing XR8+
Tekno NB48.4 Ko propo servo's Alpha dragon III
shannow is offline   Reply With Quote
Old 03-16-2016, 07:27 AM   #2019
Trader Rating: 53 (100%+)
Originally Posted by hacker View Post
Ymax
if your running the ymax conversion i would suggest adding more rear droop .....you will need the longer bmax2 drive shaft though ....it helps the car land and jump better in the ymax form
Rick Hess
Yokomo-Amain-Protek RC
R&C Hobby shop Clarksville TN
RCP Customs-RC Juice
rkhess is offline   Reply With Quote
Old 03-16-2016, 06:50 PM   #2020
Originally Posted by OriginalDonk View Post
So when's Randy Pike going to post a pic of his YZ-2 with the 3 gear we saw at Reedy. Looks like they went back to the 4 gear BMax tranny chasing a bit more forward bite.
would be cool if the bmax gearbox works on the new dt car. the tracks i run at need a 4 gear for the added rear traction. i just sold my rb6 and i'm very tempted to try this car, just do i wait for the dt or get one now and do the ymaxx conversion
steve_40 is offline   Reply With Quote
Old 03-17-2016, 01:05 AM   #2021
hacker's Avatar
done that....
I'll just add some more drag brake, maybe more anti-squat too
...and yes trim at 0
Old 03-17-2016, 07:31 AM   #2022
Paultje040's Avatar
a 3-gear would generate more rear traction(on power) than a 4-gear. Also LESS antisquat could give some more traction.
Schumacher KC
Tekno EB48.3
Paultje040 is offline   Reply With Quote
Old 03-17-2016, 09:36 AM   #2023
Well everything tried didn't get what I was looking for until swapping the 4 gear in. That is my only concern with the DT version I see
Old 03-17-2016, 11:03 AM   #2024
its the other way around.
psycho02 is offline   Reply With Quote
Old 03-22-2016, 08:12 AM   #2025
Trader Rating: 8 (90%+)
When is the dirt edition shipping? Or is it already available in japan?
juicy74 is offline   Reply With Quote
