    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 02-03-2016, 03:40 PM   #1906
Brian R's Avatar
Trader Rating: 22 (100%+)
I ran one pack through my new yz2 at outback in Chico on high bite with the box stock set up and I could not get "NO" traction,kinda sucked.
Brian R is offline   Reply With Quote
Old 02-03-2016, 03:42 PM   #1907
Brian R's Avatar
I am going to put the shocks behind the tower,and maybe run lighter oil in the gear diff(Iwant a ball diff,but they are back ordered everywhere).
Old 02-03-2016, 03:43 PM   #1908
Brian R's Avatar
Any suggestions would be appreciated.Thanks Brian.
Old 02-03-2016, 03:46 PM   #1909
KrAcOn's Avatar
Yes you want the shocks on the back. With oil 30F / 27.5R. I couldn't say what oil in the diff, I have ball diff in mine.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 02-03-2016, 03:50 PM   #1910
Brian R's Avatar
Right on,Thanks
Old 02-03-2016, 04:59 PM   #1911
Try this
http://site.petitrc.com/setup/yokomo...T_LSR20150207/
always ran my car on kyo golds and white though. had under battery 50g weights as well ran the car at about 1550g. Try packing the diff completely full of black grease should work quite well for the time being
noproblems209 is offline   Reply With Quote
Old 02-03-2016, 05:42 PM   #1912
Brian R's Avatar
Thanks noproblem,for the set up sheet,looks good.You guys are the bomb
Old 02-03-2016, 09:33 PM   #1913
brokenmoto's Avatar
Yok Diff=bfast plates, carbide balls, thrust washers, ceramic thrust balls 28.00. Amain has parts(whole diff been on backorder for months).Also Race and Drift Japan has parts, good prices and fair shipping. I just built one last night after waiting forever for amain to get the whole enchilada.
brokenmoto is offline   Reply With Quote
Old 02-03-2016, 10:18 PM   #1914
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by noproblems209 View Post
Try this
This setup is dialed at Outback. One mistake away from winning the Shootout last year. What tire are you currently using????
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-04-2016, 06:58 AM   #1915
I had the same issue and didn't seem like I could get the clutch right, I thought lighter fluids in the diff also but was advised to go heaveyer so with the box setup to start out I ended up with 10k in the diff and 27.5 in front shocks and 25 in rear with machined 1.6 front an rear, now this car is on rails I also added about 70 grams of weight behind the motor, I was also told the car jumps like crap with the rear shock set up and have yet to try it, I'm running on medium to high bite clay with big jumps
CPT.HOOK is offline   Reply With Quote
Old 02-04-2016, 07:29 AM   #1916
What did you use for the t nut it's also on back order thank you
Old 02-04-2016, 08:53 AM   #1917
brokenmoto's Avatar
Sucks getting stuff out of U.S. I understand but that's another part a-main never has. Race and drift Japan has them in stock, I just checked.
Old 02-04-2016, 08:56 AM   #1918
KrAcOn's Avatar
A parts list to hand build a ball diff would be nice for people. Something that could go on Page one would be great.
Both my YZ2's already have a ball diff so I'm good
LRH RACEWAY So. Cal
Old 02-04-2016, 09:10 AM   #1919
the incubus's Avatar
Trader Rating: 17 (100%+)
With the limited running I did before my race this past Sunday, the track was more slick than Pat Riley's 1989 hair but when I got a bit of traction before hitting jumps, my car was excellent in the air. I did however install my DEX410 side weights to the very rear of the chassis side plates so I'm assuming they balance it out nicely. I do feel I need just a touch more weight at the very rear of the car but I have an idea for adding it in the most ideal location so as to offer a LCG but still adding a touch of roll to it for better mid speed cornering grip.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 02-04-2016, 10:25 AM   #1920
KrAcOn's Avatar
That's what this is for http://www.amainhobbies.com/rc-cars-...300ruw/p453879
With this you get some more on the very back rear and you have the option to add 1-2 more weights.
LRH RACEWAY So. Cal
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Woulvesbaine
