Yokomo YZ-2
#1876
What parts should I have on hand if i run this buggy?
#1877
The front top plate/bulkhead is the only thing I've broken more than one of in 90+ racedays with this car so far. Rear arms actually seem more likely to break than fronts - personally, I've broken one rear and zero fronts but have seen others also break rears but not fronts as well. Otherwise, anything else this car breaks will be such a fluke, you'd have to carry just about everything (I have a box full of almost every plastic part on the car that almost never gets opened) to be prepared for such a fluke or accept that it's probably the most durable buggy you'll ever own and not worry about it.
#1878
Cool, I've been running a b5 which is pretty solid. Yokomo part will be harder to come by in a pinch because I live in Canada. So I'm just trying to be prepared
#1879
I have a pile of broken front arms from the B5m. I did just break one on the yz2 and you will find its allot EASIER to replace the are on the yz2 vs the b5m.
#1881
The only thing I've broken so far is a PL Trifecta wing. That wing took a severe beating and not a single part on the buggy failed. I too have plenty of spares still in the package.
Blake
Blake
#1882
OK that is why I got the bmax, I mainly race on clay...thank you
#1883
Aside from one rear arm, I've broken 3 ball cups on the front upper links. They bend right at the end of the turnbuckle, and break fairly quickly thereafter. I haven't seen anyone mention this yet, but probably a good idea to grab an extra set of ball cups.
#1886
Any word on 3 gear laydown release date?
#1888
I replaced the ball cups with AE B5 style
#1889
Carpet and astro edition
What will change in the CA edition? What hopups are needed in this car?
I will run on astroturf.
