Yokomo YZ-2
#1861
However, because the wire is thicker, simply tinning the ends of your leads means you already have a greater area containing the more resistive solder. So even if your solder points are flawless, the greater area should mathematically yield greater resistance given both gauges of wire are soldered identically perfect.
The most crucial element in painting lids like this is PROPER application of liquid. If you brush it on it is a thousand fold more difficult to cut your design than if you spray your liquid mask. On bodies this thin, it is imperative to have it sprayed on because you need the uniformity to KNOW when you've cut all the way through. With a brushed LM you will cut through most areas but will have to go back over some thicker portions and it can lead to overdoing it, leaving you with deeply scored portions that require little encouragement to snap/break. You can use a cheap $30 automotive spray gun from Harbor Freight to apply LM. Just lay down 3 solid coats all the way to the edges and allow to dry in between application. I use a blow drier to speed up the drying.
#1862
Quick question on the running a Bmax transmission. Do you need a custom battery brace, or can you use the Bmax one?
#1863
The BMax one is also too short, but some Aftermarket Manufacturers have already Released C/F Battery Braces specifically for it. Think MB Models Sell them!
#1865
#1866
I was taught (perhaps incorrectly) that thicker wire means larger solder points/joints which nullify the benefit of the thicker wire because solder creates more resistance than the wire itself. Smaller diameter wire may have greater resistance but it is so minimal that in the end, because of the reduction in overall size of the solder joints it means current will flow more freely and result in overall reduced resistance.
Is this incorrect?
Is this incorrect?
Larger wire provides more volume for power to flow. Look at resistance like water flowing. The larger the hose, the more water you can flow.
#1867
#1868
If you really want to do it, you will more than likely be able to. its just a matter of deciding you are going to do it and apply yourself.
Martin Paradis
#1869
If you spray it straight from the bottle 3 good coats will be perfect, BUT you must make it a priority to put enough on the sides. Use too little and you will be hating life as it will be very difficult to remove, especially once paint is overlying it. You also want a fresh X-acto blade to cut your design and make sure you look at the design and cut the outermost section first or you will end up with additional trim lines where you don't want them. Drop shadows are the most difficult thing to learn but it's all in how much thinner you use and it should be 85% thinner and 15% color so it flows out of the brush with almost no pressure.
#1871
#1873
If you can't solder, you'll have a harder time on bigger wire though, so it's still sensible to stick with smaller wire in that case. Plus, diminishing returns and all that vs. cost and weight and soldering difficulty.
#1875
I just scooped up a bmaxx to try the transmission out..
Question about the yz-2 I see there is a shim kit to get the trans up higher, how much does this help also was thinking if I shim the trans higher why not clock the motor mount??
