    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree42Likes
Old 01-15-2016, 03:35 AM   #1816
I saw someone using the stock yz-2 body on the 22 3.0.
Anyone tried the JC s2 for tlr 3.0 on the yz-2?
matterooth is offline   Reply With Quote
Old 01-15-2016, 05:41 AM   #1817
Crawlin's Avatar
Trader Rating: 22 (100%+)
Originally Posted by rhodopsine View Post
Race and drift Japan looks like they have both in stock.
http://www.rc-race-and-drift-japan.c...36_137_181_185
http://www.rc-race-and-drift-japan.c...b8bnu4unlm5lu6
Martin Paradis
Thanks Martin.
Sent in my order. I get a little skeptical ordering from overseas like that in lieu of Amain/Tower type places so we will have to see. Seems to have good stock and good prices.
Crawlin is offline   Reply With Quote
Old 01-15-2016, 06:56 AM   #1818
Originally Posted by Crawlin View Post
Thanks Martin.
Don't worry about this shop. I've ordered from them many time (far too many for the good of my bank account!) and never had any problems. Fast shipping, everything is well packaged. Also, when you have a question or concern, Tim is very quick to answer, given the time zone difference.
Martin
rhodopsine is offline   Reply With Quote
Old 01-15-2016, 09:22 PM   #1819
Slapjack's Avatar
Trader Rating: 19 (100%+)
Hi guys. I am wanting to buy a yz2 and maybe a yz4. But I was just wondering if these yz's are made specifically for carpet tracks and high traction clay or if they also do good on low to med bite clay. I also would want to run it on my outdoor dirt track in summer. And what is this ymax conversion? Is it a bunch of parts you buy individually or is there a kit that comes with everything needed and what is the conversion for? And how much does the conversion cost? Any advice is appreciated. Thanks
Tekno Eb48.3, EB48.2, Tekno ET48, X-Ray XB4'14, '15 & '16, X-Ray XB2 CE, X-Ray T4'15, Hot Bodies D413, Serpent SRX-2, Axial Wraith (full custom Mattzilla Build), Blade 180QXHD
Slapjack is offline   Reply With Quote
Old 01-16-2016, 12:06 AM   #1820
http://www.amainhobbies.com/rc-cars-...ftc042/p465631 . Ymax conversion will run you about $150 after you buy all the separate parts . The conversion is for moving the motor and battery about an inch rearward to get the 36/64 front/rear weight bias that is magical on low bite dirt. It also raises the center of gravity .
Treasure Valley RC Eagle, Idaho
rc10b6 xb4 22sct3.0 rc8b3e
carpetburner is offline   Reply With Quote
Old 01-16-2016, 05:42 PM   #1821
Slapjack's Avatar
So it in the part you linked it lists all the other parts to complete. One being bmax gear box. Do you use all the yz gears and just swap them into the bmax gear box or do you still need to get a bmax transmission too? I really like the look of the yz2 but would it be better for me to just buy a bmax2 instead? Or are there other upgrades on the yz2 that make it worth buying the yz and then doing the conversion?
Old 01-16-2016, 11:21 PM   #1822
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
You can just buy the Bmax 2 ball diff and its a direct fit to your yz2 tranny case. One thing I learned the hard way is that the ball diff gear where you put the 3/32nds balls, the balls only go in from one side not from both. Thought my balls weren't the right size and took me a while to figure out that I had to flip the gear over and the balls fit fine.
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 01-16-2016, 11:23 PM   #1823
The gears x 2 http://www.amainhobbies.com/rc-cars-...2-503i/p242405 idler shaft x2 http://www.amainhobbies.com/rc-cars-...2-303i/p242492 and gear cover http://www.amainhobbies.com/rc-cars-...-304gc/p242436 . Your better off converting the yz-2 as the suspension and steering geometry is better . It fits my driving style so I am gonna stick with it on dirt this summer.
Old 01-17-2016, 10:53 AM   #1824
Not all the parts linked on the amain site exist (or are available any more) - I found options for just about everything by digging through the bmax manual or searching. If you get new gears and bearings and everything it'll run closer to $250, though part of that is the ball-diff which you're probably getting anyway. Note that the factory-rc site has more parts listed than amain.
For the wing mount (throws a '404' from their linked list) use B2-001WB; it will require a 3x25 screw to mount to the transmission (assuming it lines up when mounted to the YZ shock tower - perhaps it doesn't, which is why this isn't listed anywhere.)
The waterfall support mount they link comes up NLA but another turns up with the part number search: B2-118MR
If you fully stuff the transmission, you'll need 6 5x10x4 bearings and 2 10x15x4 bearings in addition to the noted idler shafts, idler gears, diff, and top shaft. That would cut down on the time to switch, but that may not be something you really care about doing where time is that much of an issue.
The screw set is currently on back-order (along with the ball diff and the waterfall mount set so it really doesn't matter) but it requires 3 3x35 cap head screws; 1 3x8 set screw; 1 2x12 self tapping cap head.
Assuming I'm looking at the appropriate manual the relevant steps are 10, 13, 14, and 15, 17.
I'd link all the relevant bits but I can't yet - not enough posts. I'm going to give the hobby a try again after 15 years hiatus (oldest car in my collection is from '88...) with the YZ-2. Should be interesting. I'm hoping this hobby is a little less expensive than racing full-size cars (even just Autocross is pricey...)
C
ccjd is offline   Reply With Quote
Old 01-18-2016, 04:21 PM   #1825
freakshow__'s Avatar
Does anyone know where you get the alloy castor blocks for the YZ-2? I have seen them in pictures on the petit-rc setup sheet for the YZ-2 under the INDOOR listings under Carson Werimont's Nurburgring EOS setup.
Are these available somewhere or is this a one-off team driver thing?
freakshow__ is offline   Reply With Quote
Old 01-18-2016, 07:32 PM   #1826
KrAcOn's Avatar
deleted
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is online now   Reply With Quote
Old 01-18-2016, 09:30 PM   #1827
joeymdz's Avatar
Send a message via MSN to joeymdz
http://www.mibosport.com/aluminum-fr...ng-hub-carrier
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-19-2016, 08:51 AM   #1828
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Or: http://www.rc-race-and-drift-japan.c...oducts_id=6018 but not imported by Amain yet that I'm aware of.
MarkA is offline   Reply With Quote
Old 01-19-2016, 04:12 PM   #1829
cclifton's Avatar
Send a message via MSN to cclifton
I was wondering if someone could help me with setup on my yz2 with the ymax conversion. We will be running on high bite dry clay with slicks. Im just looking for a starting point for this bigger race I will be going to in march. Any help will be appreciated as I usually run on quite a low bite track. This will be in 17.5 class.
Chris
The Fleet:Xray:XT2 - Associated B6
For Sale :Tekno EB48SL, Kyosho RT6, RB6.6, Xray XB2 CE 2016 w/XB2 DE conversion
Poorboy Raceway and Hobbies
Grants Pass, OR
cclifton is offline   Reply With Quote
Old 01-20-2016, 08:44 PM   #1830
HSV427's Avatar
Trader Rating: 21 (96%+)
For those running the YMAX conversion on the yz2 what body are you running.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
