    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 01-10-2016, 06:37 AM   #1801
hacker's Avatar
Trader Rating: 140 (100%+)
Default stock pucks
I knew it 'could' be done. How, is another question I've been asking myself for months. It wasn't until the recent yz-2 stock pucks request thread had popped up to give me the motivation to figure this out!
Short answer;
B5 ball diff
B5 mip stock pucks
B5 rear hub assembly, up to all the bits that connect to the mip drive shaft.
This is what I needed for 'my' ymax with bmax4 rear arms. I actually have the opposite problem to above poster 'Crawlin', my pucks is only half way in, and half way out, of the outdrives. Putting back the original yz-2 arms will solve that!
The B5 hubs are too wide for the yok arms. Required to take off roughly 2mm, I choose the shave the forward side. Also slight dremmelling required as B5 hub hitting rear arm(see 3rd pic). I've just hacked it with a blade instead, as its 1:39AM and don't wanna wake everyone up!
I personally havnt used pucks before, I got these pucks with my used b5m. And I don't plan to use them unless my consistency is better. However, now you know what to do to achieve stock pucks!
hacker is offline   Reply With Quote
Old 01-10-2016, 04:41 PM   #1802
HSV427's Avatar
Trader Rating: 21 (96%+)
I have bought all the parts to do the ymax conversion including the factoryrc kit, my question is i ordered all the parts on petitrc website except tee rear wing, can you use the yz-2 wing or do i have to get the bmax2 wings TI.
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 01-10-2016, 04:59 PM   #1803
Crawlin's Avatar
Trader Rating: 22 (100%+)
Nice hacker! Seems we need to swap arms, haha.
For the hell of it, here it is "ready to race" but not legal weight. Right now the battery is all the way forward(shorty) in the pod. You like those cross-weights/side to side balance? Its as even as I could get with placement, and shock settling can change it anyways
And just for information purposes, I put the two pieces of Mckune Design Shorty Battery weight under the battery in the forward position. So added the 50g. And it looks like the front of the battery compartment is the balance point on the car. It added the 50g but the front/rear balance % stayed the same. I'll be adding two 10g pieces on the servo up front for the start to get to the 1500g. Probably only swing the f/r balance very little
Crawlin is offline   Reply With Quote
Old 01-10-2016, 07:11 PM   #1804
Trader Rating: 53 (100%+)
u can use it but it widens the mount holes a little and u cant use the one piece shim unless u cut it .....i liked it because it lowered the wing slightly...
Rick Hess
Tekno RC--Protek RC
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 01-10-2016, 07:57 PM   #1805
Built my YZ2 over the weekend.
Best build I've done by far! A combination of build instruction details on par with Xray/Losi, plastics quality of Kyosho. Everything is butter smooth. The ball bearing steering system ... blissfully smooth and slop free!
Shocks are super smooth too. Only downside I have for the ENTIRE kit is those pistons. Including machined pistons with the kit would have been the cherry on top of all the icing and cake. Shocks still not quite as butter smooth as the Kyosho velvets but a switch to machined pistons could change that!
Super happy with my purchase. Now looking for a BMax2 so that I can have a YMax rear end to bolt on and also to build my YZ4!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 01-10-2016, 08:06 PM   #1806
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
Can't wait for reports on these puck systems and how they ran. Good job guys very interested over here
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 01-11-2016, 10:50 AM   #1807
KrAcOn's Avatar
MIP14145 is the puc system for the Bmax2. If you are running the Bmax2 rear arms on the YZ2 I would think you could run this kit. vs converting all those B5m parts over.
AE:RC10B5ML,B5M,B4.2,B44.3,B3,RC10TeamRPM,Rc10T,RC10B64D
Yokomo:YZ-2 LD,YZ-2 DT,YZ-4 and MX4
LRH RACEWAY So. Cal
KrAcOn is offline   Reply With Quote
Old 01-11-2016, 11:12 AM   #1808
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The shiny kit fits without issue, I run them in my car.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-11-2016, 12:06 PM   #1809
hacker's Avatar
Yes I assume you are right!
However i just happened to use what I already had in my 'pit box'.
Old 01-11-2016, 12:45 PM   #1810
Crawlin's Avatar
and if I wanted a puck system that weighed the same as the stock stuff that is what I would have gotten. Since the yokomo ball diff was out of stock, the B5 stuff was what was available at my LHS and its pretty much the same price. This was for a 17.5 car that I wanted to see how light it could get. People were asking and I had the time, money, curiosity to see, haha.
And in all honesty, instead of the shiny puck system, if you already had the yokomo ball diff, you could just pick up the male/female outdrives from the shiny system for $13ea and the custom works blades and have the same setup MIP sells for $90 for $30, just not a shiny dogbone. Don't know what those weigh to be honest or what the benefit of the shiny system is other than just being a puck setup.
if this aluminum 17.5 setup doesn't work, i'll just toss the stock axles back in with the CW blades and be right back at the shiny system.
Its also just a last option since I'm not seeing that the shiny system will be produced any longer??
Old 01-11-2016, 06:01 PM   #1811
Crawlin's Avatar
Initial testing night and the b5m puck kit worked fine. No issues, no popping out. Will be throwing the stock pieces in tomorrow as I have a slight on power issue coming out of corners. Has a tendency to want to keep rotating. Could be my throttle control after being away for so long, could be the tires being brand new, etc..(full of excuses )
Started with Chris Johnson setup. Does feel real "touring car" like on the local clay track, just that one issue on power, corner out
Thought process is that maybe the puck on the outside is creating the bind under compression on the corner exit, the inner wheel diffs out and the car spins. Maybe my understanding is wrong, so just tossing thoughts out
Old 01-14-2016, 11:07 AM   #1812
Crawlin's Avatar
Anyone/Anywhere that has the aluminum rear camber link mount and weighs in stock?
Amain doesn't and no response on when they expect them in
Mibosport doesn't either
Ordered the Rear/Front Steel hinge pin holder but the Rear/Rear was out of stock at Amain as well.
Any other parts houses?
Old 01-14-2016, 11:38 AM   #1813
I found a rear aluminum upper arm on ebay
Levelup is offline   Reply With Quote
Old 01-14-2016, 12:41 PM   #1814
Race and drift Japan looks like they have both in stock.
http://www.rc-race-and-drift-japan.c...36_137_181_185
http://www.rc-race-and-drift-japan.c...b8bnu4unlm5lu6
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 01-14-2016, 05:09 PM   #1815
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
I run stock pucks in my car with the stock axles as the weight difference from steel to aluminum wasn't enough to over weigh the longevity of steel.
What I do is push the pins out of the dogbones and drill with a #34 drill bit. Use a drill press to do this step. By using the stock dogbones, its a reduced cost and I have the option of the yz2 or bmax2 dogbone. I use the MIP TLR 17.5 puck outdrives with a couple shims on each side of the diff to center. I have no issues with plunge depth or having to make any other modifications.
Parts List:
Axles
Qty 1 - MIP13131
Qty 1 - MIP13132
Diff
Qty 1 - MIP13149
Qty 1 - MIP13147
Qty 1 - MIP13148
I am not sure if this is the right shim kit I bought: YOKZC-S100S
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
