Yokomo YZ-2
#1756
Lees japan warm up right?
any inserts in the front tires have you guys tried?
#1757
Daboots are okay....
http://site.petitrc.com/setup/yokomo...Arena20150606/
#1759
I was just thinking about getting this car then started looking at the pics and saw how the tranny was layed down and wondered if it was designed for carpet. So there aren't any setups that would make this car good in low traction conditions?
I was also looking at the xb2... which has 2 versions one for dirt one for carpet. I like the look of the yokomo and the replacement/upgrade parts aren't as high priced as xray but if it can't be setup for dirt I guess I have no option. I have no carpet tracks around here at all.
Having said that, I noticed you have a srx2 as well. I have one too, and its also a great car!
Or wait for the dirt spec xb2
#1760
Hi guys,
Need a favour, I'm looking for a slipper lockout for my Schumacher Cat K2. The shape of the shaft looks similar. Exotek make a slipper eliminator.
Can someone grab out their calipers and measure the width & height. Flat side & rounded side.
#1761
I am using the Speedy's Racing Parts eliminator for the B4. Works and fits perfectly.
Blake
Blake
#1762
#1763
this is taken from a spare bmax2 top shaft I have lying around, which wouldn't be far off the yz-2 I gather
the 'flat' bit is 3.87mm wide ! !
the round shaft is 4.67mm in diameter ( )
as previously posted, I have also been using on and off, the speedyRC eliminator (the original that came out for the B4 that everyone else has copied)
these were made in the day of the B4's, and I'm sure the top shafts ran on 3/16" bearings (4.76mm)
You could possibly get any of these eliminators to make it fit your K2 with a bit of playing around. I wish I had a mill and lathe.....
#1765
I just got the same measurements on my YZ-2 topshaft as hacker.
Blake
Blake
#1766
#1767
The good thing about the Speedy elim is that it doesn't matter what size your 'flat' width is. As the eliminator is held down to the top shaft by two grub screws. The only issue really is the size of your shaft!
But even if your shaft is bigger (eg. 5mm), you can just drill it out. Since its 4.76mm anyway, its not much work to enlarge the hole to 5mm.
Personally I wouldn't do it for a gear diff'd car!
Anyway, back to the yz-2....
#1768
#1769
Just wondering if Lee had posted his world's setup anywhere?
Just curious as to what if any differences in setup he used.
