Yokomo YZ-2
#1741
Yes, using bmax rear arms. Didn't try the shorter wheelbase.
#1742
Another issue is the track we run at has 2 sections of small "ripples" that upsets the far quite easily, meaning the rear of the car will buck and kick one way or the other..
Yataba yellow front, green rear
37 and 30 wt oils.
37 and 30 wt oils.
#1743
http://mckunedesign.com/parts/yokomo/yz2_shims_set
Instant rear traction!
Are you using machined or stock pistons?
#1744
Machined pistons all around, diamond coated shafts.
#1745
rear shocks are rear mounted?
#1746
If you really want to gain rear grip you can pick up these tranny shims from Mckune Design
#1748
Anyone had some success finding a setup to keep the rear end planted just after the apex of a tight turn when getting on power quickly? No matter what I have tried, the only resolve is patience to get squared up first. Those McKune spacers didn't do anything, weights didn't help, tried several camber locations and spacers w/o luck. I've driven other buggies and none seem to have this issue. Med bite turf. Car is fast, but it (I) could be faster if I can find the answer to this.
#1750
#1751
What's your setup? We have 2 turf tracks out here ranging from med to high bite
#1752
I was also looking at the xb2... which has 2 versions one for dirt one for carpet. I like the look of the yokomo and the replacement/upgrade parts aren't as high priced as xray but if it can't be setup for dirt I guess I have no option. I have no carpet tracks around here at all.
#1753
#1755
