    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree74Likes
Old 11-28-2015, 09:39 AM   #1666
Originally Posted by schirmann433 View Post
Does anyone have Futaba servo horns for the yz2 I can buy from.
Spend the money and get an aluminum one.
afm223 is offline   Reply With Quote
Old 11-28-2015, 10:39 AM   #1667
Trader Rating: 62 (100%+)
Originally Posted by chvtec33 View Post
Anyone have a good turf or carpet setup they are willing to share?
Lee Martins Worlds warm up set up is a good starting point its on petitrc
N.W Hobbies
M.Pease
The Wease is offline   Reply With Quote
Old 11-28-2015, 04:03 PM   #1668
schirmann433's Avatar
Where do I get one I can't find the stock ones let alone an aluminum one
schirmann433 is offline   Reply With Quote
Old 11-28-2015, 04:16 PM   #1669
Amain has the Yokomo aluminum servo horn plus several other brands. You need a 25 tooth.
Old 11-28-2015, 07:17 PM   #1670
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
What is a good starting point for gearing with a 17.5? Smaller track.
Depends on the motor as well. I am running a Motiv RC 17.5 w/42* timing (mid rotor) and 69/30 on a medium sized carpet track. Car is a rocket!
dr_hfuhuhurr is offline   Reply With Quote
Old 11-28-2015, 09:03 PM   #1671
Only one the show is for the BD7 will that work?
Old 11-29-2015, 03:15 AM   #1672
mes
Should work, but my son managed to break one in his SC10. Any 20mm 25t servo horn should be fine. I like the MR33 one I bought at Tonisport, which looks like the BD7 horn but is a little thicker.
mes is offline   Reply With Quote
Old 11-29-2015, 06:26 AM   #1673
Ok I'll check that out. Thank you
Old 11-29-2015, 10:29 AM   #1674
LiL CeeZ's Avatar
Trader Rating: 15 (100%+)
What company is the one making carbon fiber parts, I'm looking for the battery brace tired of mine popping out all the time
Team Associated B6D
LiL CeeZ is offline   Reply With Quote
Old 11-29-2015, 10:42 AM   #1675
303slowdown's Avatar
Trader Rating: 24 (100%+)
http://http://www.amainhobbies.com/rc-cars-trucks/mckune-design-yz2-carbon-locking-battery-plate-mdr10017/p473585Mckune makes the clamping battery brace. Amain has them.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 11-29-2015, 11:46 AM   #1676
freakshow__'s Avatar
thought I would share this with everyone...unless it has already been discussed....
I have been racing my YZ-2 for a few months on astro-turf and I just recently started playing with weights on the chassis. I have definately found that even on turf this car is just so light that it has a lot of rear wheel spin....yes, even on high traction turf. With a 17.5 it's not so bad, but with even a boosted 10.5 the tires just spin a lot.
To help this I have put 15 grams in front of the servo to give consistant steering, I have the yokomo under battery weights, 55 grams I believe?, and I have also got the aluminum rear camber plate with the optional rear steel weights on.
Yes...it is heavier now...but I can definately see that it now gets much less tire spin and I see this also because I am going through tires less often than before. When I punch it the car moves as opposed to that spinning and rear end drift I was getting before.
Anyone else try this on turf? Anyone think I'm nuts? I see all the pro setups on petitrc have front of servo weight added as well as under battery weights...even on turf.
freakshow__ is offline   Reply With Quote
Old 11-29-2015, 01:23 PM   #1677
mes
TBH I have not tried it without the TY Europe 50 g LiPo weight and 20 g of sticky weights in front of the servo, but running mod I don't care about a few grams more or less. I have thought about adding the steel front arm mount, but did not buy it yet. The car has been pretty good with the 11 g brass insert on carpet last time, and I guess I will try some other tweaks first. So much to test, so little time...
Old 11-29-2015, 08:40 PM   #1678
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This is what I use: HERE
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 11-29-2015, 08:43 PM   #1679
Factory rc also makes them. I just finished building my yz2 and purchased the factory rc one so hopefully I can test it out soon. Haven't herd anything bad about it yet!
Levelup is offline   Reply With Quote
Old 11-29-2015, 08:47 PM   #1680
joeymdz's Avatar
Send a message via MSN to joeymdz
Mckune has a locking battery brace and it will never pop out
http://www.amainhobbies.com/rc-cars-...r10017/p473585
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
