    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 11-03-2015, 05:59 AM   #1621
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
Originally Posted by the incubus View Post
What's the difference between those gearboxes? I have the original one on my NIB kit I just got but the other assembled roller it has the B-Max Tranny and I can't tell the difference between them.
Besides the motor being pushed to the rear A LOT, it also changes rear roll center since the weight is also higher than the originial transmission.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 11-03-2015, 07:05 AM   #1622
[QUOTE=WillS;14249764]
Originally Posted by jake alton View Post
Actually I did not lose steering, I gained side bite and rear traction but lost very little steering that it had before.
In order to gain something you have to lose something. I lost a lot of initial turn in steering at 180 turns for example. It did increase rear traction and side bite. The car was able to be pushed harder through other parts of the track. But it's all relative to conditions, and setup. We get the best of both worlds with the tranny options.
jake alton is offline   Reply With Quote
Old 11-03-2015, 09:23 AM   #1623
DaveG28's Avatar
Trader Rating: 60 (100%+)
How much better than the bmax2 on dirt is the y-max conversion?
Just wondering, especially if my chassis was drilled wrong, whether to keep the Yz for carpet and just keep running the bmax on dirt!?
DaveG28 is offline   Reply With Quote
Old 11-03-2015, 09:28 AM   #1624
DaveG28's Avatar
Originally Posted by WillS View Post
If he was that far off, it might cause a tweak issue with the chassis.
Is my best bet to initially screw all the screws in part way and see how easily it all tightens down? Presumably the tweak will occur if it is offline and twisting as I screw it all down?
Old 11-03-2015, 03:40 PM   #1625
Do you guys find the car has lots of steering I used to race buggies years ago and went to on road for many years after that and came back off road last year...Finding the car is good happy what I am doing to the car but just can't get the car to rotate in the corners as fast as I would like.I am wondering if it's down to the onroad driving as don't drive with the brakes like the others do.
Can someone suggest what they would change on the car to go to a locked in rear to get one looser...,,Astro and carpet running on same tyres as everyone else...
Quietman is offline   Reply With Quote
Old 11-03-2015, 10:29 PM   #1626
hacker's Avatar
Trader Rating: 140 (100%+)
try running without bolting down the waterfall!
I initially ran it with a shim glued to chassis only, couldn't tell the difference to be honest now that I have mine screwed in now.
hacker is offline   Reply With Quote
Old 11-04-2015, 06:28 PM   #1627
Trader Rating: 42 (100%+)
Rear shocks front mounted.
No extra weight in the rear.
Put some weight up front.
Lengthen wheelbase.
Remove as much ackerman as possible.
Less rear toe in maybe 2.5.
1 degree or maybe slightly more front toe out..
Many things you can try but I'd do one at a time.
This car has more steering than any other 1/10th buggy I've ran so it can get to where you want it, just need to mess with the chassis settings a bit.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 11-04-2015, 09:00 PM   #1628
the incubus's Avatar
Trader Rating: 17 (100%+)
IDK Antimullet,
I've only drive my YZ-2 inside for a quick steering adjustment but I can say that my 4.2 definitively turns tighter. Will have to see out on track but initial comparison suggests it won't turn as tightly as a 4.2, but it's close.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 11-04-2015, 09:07 PM   #1629
hacker's Avatar
IDK Antimullet,
dumb question, but do you have the servo setup correctly on your yz-2?
I've noticed this car can be quite finicky when it comes to setting up the servo. I can't quite get 100% throw on one side, even with my steering epa maxed at 150. Doesnt matter if the servo is dead center, or one notch off center!!
still playing around with servo spacing, steering link length etc. but it's not bad, just not ideal. Still corners better than my B4.2 however, which I ran just a couple of days ago again
Old 11-04-2015, 09:43 PM   #1630
As far as I can tell, I have equal steering to both sides and am using a slightly longer horn to ensure full throw.
My DEX410, SB401, Daughters RB5, all steer similarly tight, about the same as the YZ-2. My PRS1 will turn tightly at very low speed but at medium to high rates of speed it can push but I compensate with a touch of throttle steer.
ROB RIVERA
Old 11-05-2015, 05:33 PM   #1631
Trader Rating: 53 (100%+)
anyone remember the dude who made ymaxx cf battery plate/strap that was same shape as the stock ?
Rick Hess
Tekno RC--Protek RC
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 11-05-2015, 06:04 PM   #1632
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Hey hacker, yea I get the same mate. I fiddled and fiddled and fiddled.
I run a BLS551 and I have the allow servo mounts. but yea pain in the to get it set up right.
Some guys up here in Sydney put a 1mm spacer in between the cups to get the servo centred and go from there. But I noticed Lee Martin doesn't
svndayNZ is offline   Reply With Quote
Old 11-05-2015, 07:24 PM   #1633
freakshow__'s Avatar
To even your steering throw: put a 2mm or 3mm washer in the short linkage between the servo horn and the bellcrank.
freakshow__ is offline   Reply With Quote
Old 11-05-2015, 09:34 PM   #1634
IDK Antimullet,
Run your front axles in the high position for more steering as well.
I think you'll like it once you get it on the track and set up well!
Aaron Moore
Old 11-06-2015, 12:19 AM   #1635
DaveG28's Avatar
Guys, with the y-max running battery rear it is raised due to the chassis plates slanting upwards on the sides... Is it an issue with c of g? Also, thinking maybe I need to use plenty of foam to protect the cells there, it must be easy to split a lipo case?!
Viper ESC's ~ Xpert Servo's ~ Sanwa Radio
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DirkW
