    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree63Likes
Old 11-01-2015, 06:35 AM   #1606
Originally Posted by the incubus View Post
Thanks and yes, the lid will be purple whit and black but racy and I will be replaceing all washers and spacers with HPI purple ones.
This is my 410 using the same wiring. I'll look for the paint scheme in the 410 thread. Best paint job any track I've been to but it's a 12+ hour endeavor. Might do my YZ-2 like that since I consider this a special car.
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
Found the pics
Very nice!
afm223 is offline   Reply With Quote
Old 11-01-2015, 06:37 AM   #1607
the incubus's Avatar
Trader Rating: 17 (100%+)
I knoooow! Lolol
Looking at my lid contemplating drawing it up on it! The perils of being a damn designer.
the incubus is offline   Reply With Quote
Old 11-01-2015, 11:53 AM   #1608
Default Jumping back into 2 wheel buggy.
I have a question for this group. I am going to get back into 2 wheel drive buggy. I am thinking about getting one of these YZ-2 kits. I will be trying to drive it one a carpet track (The Rug in King, NC) and a clay track (SpeedRC in Moorseville, NC). I know it'll be a good car for the carpet, but I am worried about how much $$$ I am going to have to change it for the clay at SpeedRC. I see talk of having to change gearboxs, rear arms and driveshafts. Slick tyres are the current choice at SpeedRC. Does anyone have any experience with this kit on clay with slicks?
cooperking is offline   Reply With Quote
Old 11-01-2015, 12:01 PM   #1609
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
If they are running slicks, I would just add rear toe and maybe some rear weight to the car. The SMC brass option might be the best choice for your situation.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies/Soar
WillS is online now   Reply With Quote
Old 11-01-2015, 12:12 PM   #1610
Do you think I will have to do the gearbox change? Going to a Bmax2 rear end?
Old 11-01-2015, 01:12 PM   #1611
Definitely not if the track is high enough traction to run slicks.
Old 11-01-2015, 01:12 PM   #1612
No!! The car is very user friendly out of the box. Don't worry. Run it straight out of the box on both tracks. It will work well.
jake alton is offline   Reply With Quote
Old 11-02-2015, 07:59 AM   #1613
Trader Rating: 137 (100%+)
He should be able to get by just adding the under battery weights. If the clay is not good, then 20 grams under the gearbox of stick on lead should be good enough..
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Tekno EB48.4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 11-02-2015, 01:18 PM   #1614
Thank you for all your input gentleman. I'm sold.
Old 11-02-2015, 09:21 PM   #1615
WillS's Avatar
I run on 2 types of clay tracks, one is slicks only and the other switches between treads and slicks. I had 100g on the rear of the car, never liked how it handled, then put the bmax transmission in and saw a huge improvement in the car (almost 1.5 seconds a lap difference, let alone the consistency/driveability greatly increased).
Will Smith
Sponsors:
Old 11-02-2015, 09:38 PM   #1616
What's the difference between those gearboxes? I have the original one on my NIB kit I just got but the other assembled roller it has the B-Max Tranny and I can't tell the difference between them.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
Old 11-02-2015, 10:50 PM   #1617
[QUOTE=the incubus;14249502]What's the difference between those gearboxes? I have the original one on my NIB kit I just got but the other assembled roller it has the B-Max Tranny and I can't tell the difference between them.[/QUOTE
Less steering with the Bmax tranny.
Old 11-03-2015, 03:47 AM   #1618
DaveG28's Avatar
Trader Rating: 60 (100%+)
Hi guys, am about to get the conversion to run the bmax gearbox, and it looks like the guy who drilled my chassis did not get it right, the holes offset from center nearly 1mm... As its for the waterfall brace should I basically be ok, or do these holes have to be drilled perfectly?
DaveG28 is offline   Reply With Quote
Old 11-03-2015, 05:57 AM   #1619
WillS's Avatar
[QUOTE=jake alton;14249535]
Actually I did not lose steering, I gained side bite and rear traction but lost very little steering that it had before.
Will Smith
Sponsors:
Old 11-03-2015, 05:58 AM   #1620
WillS's Avatar
If he was that far off, it might cause a tweak issue with the chassis.
Will Smith
Sponsors:
