    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree39Likes
Old 10-12-2015, 05:49 AM   #1516
Trader Rating: 53 (100%+)
Originally Posted by Antimullet View Post
Guys you have any shock piston recommendations? I'm getting a lot of chassis slap up to 1.6x2 rear pistons and 32.5 oil. Front is 1.5x2 35 weight. Associated blue springs all around.
My car is heavier with brass rear ballstud mount, smc brass rear weights, front brass arm mount.
Car bottoms in the rear very bad.
Anyone use vrp pistons? If so which ones?
What brand/style of 1.6's are you running ? Square edge ...taper ? Also your front end set-up seems stiff to me making the rear slap harder.
rkhess is offline   Reply With Quote
Old 10-12-2015, 06:13 AM   #1517
hacker's Avatar
Trader Rating: 140 (100%+)
Originally Posted by WillS View Post
millimeters
what were you smoking when you measured em?
I got 1.5mm on each arm, so 3mm in total track width increase.
I should have taken a pic when I was doing the conversion, as I didn't quite believe it too.
hacker is offline   Reply With Quote
Old 10-12-2015, 06:36 AM   #1518
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
When you use the 5mm hexes (as that is recommended) its only .5mm per side. If you use the 6mm hexes yes it would be 1.5mm per side.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 10-12-2015, 06:41 AM   #1519
Trader Rating: 42 (100%+)
I'm using the flat machined yokomo pistons. I've tried softer front setups but the rear still bottoms hard. Using the bmax 4iii longer arms and longer driveshafts as well. Maybe I need to increase rear droop.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 10-12-2015, 06:59 AM   #1520
WillS's Avatar
Try adding 2mm of spacer and an oring on the outside of the shock shaft. There is a little over up travel on the shocks and these spacers seem to help me with issues like this.
Will Smith
Sponsors:
Old 10-12-2015, 09:01 AM   #1521
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Motorman007 View Post
Why would you need this?
What is purpose of a Dual Slipper?
Thank you
Theoretically more consistency/"smoother". However, if you run stock, the last thing you'd want to do is add more rotating mass. If you run mod and you're doing so with this car, that means you're already probably racing on a surface so grippy to the point where your slipper is being used more to save the idler gears on jump landings than to actually slip anyway.
MarkA is offline   Reply With Quote
Old 10-12-2015, 09:07 AM   #1522
Moderator
MarkA's Avatar
Originally Posted by freakshow__ View Post
Can someone tell me how much wider the rear end gets by using the b-max 4 arms with the b-max 2 driveshafts???
I run on astroturf exclusively...wondering if this is even worth looking into to further stop traction rolling?
What's the rest of your setup? I only race astro with an occasional carpet race thrown in and the YZ-2 will be the absolute last car to start traction rolling anywhere.
Old 10-12-2015, 12:20 PM   #1523
Motorman007's Avatar
Trader Rating: 76 (100%+)
Thank you sir
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 10-12-2015, 01:45 PM   #1524
Little more droop and maybe some rebound ? I'm running stock arms and about 30% rebound .....also running ae pistons ....
Old 10-12-2015, 01:46 PM   #1525
Trader Rating: 137 (100%+)
Originally Posted by noproblems209 View Post
Vented Dual disk slipper finally available in the US
http://www.amainhobbies.com/rc-cars-...2-670v/p465826
looks nice, thankfully all of my local tracks are medium high to high bite, so I lock the stock slipper and am on my merry way
TLR 22T 3.0, TLR 22-4 2.0 , TLR 22 4.0 X2, 22SCT 3.0, Tekno SCT 4X4, Hobbywing, Futaba, LRH Hobbies, Spektrum Servos, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 10-12-2015, 01:48 PM   #1526
Agreed, he needs to pack up the whole car running all of that weight in it. How much does the car weigh? My car mostly stock slaps from time to time, but nothing that really gets it out of shape.
Old 10-12-2015, 09:47 PM   #1527
Trader Rating: 22 (100%+)
I'm running mod with a 6.5 on a 200x150ft high bite carpet track... have to let her slip alittle bit!
https://www.facebook.com/68650617473...9061429808140/
noproblems209 is offline   Reply With Quote
Old 10-12-2015, 10:16 PM   #1528
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
that track looks sweet!
RC*PHREAK is offline   Reply With Quote
Old 10-12-2015, 10:25 PM   #1529
How do you get proper rebound with emoltion shocks. I thought they had to be bled completely Bladder shocks can achieve rebound.
jake alton is offline   Reply With Quote
Old 10-12-2015, 11:17 PM   #1530
hacker's Avatar
I will try to get some pics up tomorrow.
I'm sure it was 1.5mm each side, just comparing the arms alone! I had them one on top of the other and it looked around 1.5mm longer.
hmmm got me stumped now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
