    Hide Wikipost
Old 08-10-2017, 01:11 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
Print Wikipost
Like Tree43Likes
Old 10-08-2015, 08:39 AM   #1501
scr8pn4205's Avatar
ok thanks just trying to get an ozite setup working a little better as I see most setups are for either carpet of turf which have more grip I am guessing.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 10-08-2015, 03:13 PM   #1502
I have not eperienced any shortage of steering with the shocks mounted in the rearward position. FWIW I have only driven the car on medium-high bite clay.
afm223 is offline   Reply With Quote
Old 10-08-2015, 03:15 PM   #1503
zeakemedia's Avatar
Trader Rating: 70 (100%+)
I got the Speedy's slipper eliminator today and threw it on. This is his B4 eliminator. For whatever reason, I haven't measured the topshaft yet, the 5mm versions had a little play in them. I still need to get the buggy wired and hopefully will be turning laps this Saturday at The Factory.
Blake
DJO Race Designs | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 10-08-2015, 06:42 PM   #1504
Trader Rating: 22 (100%+)
not needed for anything but astro/carpet car rotates quicker through 180's,etc.
noproblems209 is offline   Reply With Quote
Old 10-09-2015, 03:34 AM   #1505
scr8pn4205's Avatar
not needed? you talking about the shocks in the back of tower only needed for dirt? just asking thanks
Airtronics M12
TSR power
Old 10-09-2015, 01:41 PM   #1506
Heading out to LSR in about an hour. I will finally get to see how she performs on a lower bite surface. It certainly won't help that I haven't driven the newest layout, but I have my b5m with me just in case things don't go as planned. Also a necessary evil since I haven't invested in any spares for the YZ yet.
Old 10-09-2015, 02:30 PM   #1507
when you see carpet on the setup they're talking about ozite, So only question would be are you running on pin tires?
Old 10-11-2015, 04:48 PM   #1508
Trader Rating: 42 (100%+)
Guys you have any shock piston recommendations? I'm getting a lot of chassis slap up to 1.6x2 rear pistons and 32.5 oil. Front is 1.5x2 35 weight. Associated blue springs all around.
My car is heavier with brass rear ballstud mount, smc brass rear weights, front brass arm mount.
Car bottoms in the rear very bad.
Anyone use vrp pistons? If so which ones?
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 10-11-2015, 04:52 PM   #1509
WillS's Avatar
Trader Rating: 30 (100%+)
Send a message via MSN to WillS Send a message via Yahoo to WillS
I run 32.5(F)/27.5(R), 2x1.6 (all the way around) on my car with no problems at 1536g.
Will Smith
Sponsors:
Cheater Racing, Team Powers, Amain.com/Protek, Dialed RC Hobbies, Sweep Racing
WillS is offline   Reply With Quote
Old 10-11-2015, 07:15 PM   #1510
freakshow__'s Avatar
Can someone tell me how much wider the rear end gets by using the b-max 4 arms with the b-max 2 driveshafts???
I run on astroturf exclusively...wondering if this is even worth looking into to further stop traction rolling?
freakshow__ is offline   Reply With Quote
Old 10-11-2015, 07:28 PM   #1511
WillS's Avatar
About .5 wider. All you really are doing is moving pivot points and creating a softer rear spring rate do to outer pivot point being farther away from the shock pivot point.
Will Smith
Sponsors:
Old 10-12-2015, 12:14 AM   #1512
Vented Dual disk slipper finally available in the US
http://www.amainhobbies.com/rc-cars-...2-670v/p465826
Old 10-12-2015, 01:32 AM   #1513
hacker's Avatar
Trader Rating: 140 (100%+)
.5 what?
hacker is offline   Reply With Quote
Old 10-12-2015, 05:04 AM   #1514
Motorman007's Avatar
Trader Rating: 76 (100%+)
Why would you need this?
What is purpose of a Dual Slipper?
Thank you
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 10-12-2015, 05:05 AM   #1515
WillS's Avatar
Originally Posted by hacker View Post
.5 what?
millimeters
Will Smith
Sponsors:
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
