    Hide Wikipost
Old 10-18-2017, 07:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Yokomo YZ-2
Last edit by: Bob Barry
Welcome to the YZ2 Wiki!
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top
Setup Sheets can be found here
DT CA DTM parts comparison
Print Wikipost
Like Tree105Likes
Old 10-05-2015, 01:02 PM   #1486
Motorman007's Avatar
Trader Rating: 78 (100%+)
Originally Posted by MarkA View Post
A contrarian thought to your direction - when you gear mod motors way down like that, you tend to turn them into on/off switches - something that doesn't help laptimes due to the diminished smoothness and the tendency to then use more full-throttle gets them warmer no matter how small the track is. Try gearing it like normal (23-24ish/80 on an 8.5) to take advantage of a smoother power delivery and I'd bet it doesn't run warmer either. Even on the smallest track I run on, I use a 7.5 geared at 22/77 and it rarely goes much over room temperature.
Thank you sir
So a Viper 9.5t 3600kv I should be around 23 24 with the 80 spur
But it felt so good Mark LOL I will change things around thanx
One guy is running a 10.5t and is running great.
22/78 tekin 10.5t 4550kv
final ratio 9.22
Maybe I need to pick up a 10.5t lol
Thanx sir
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 10-05-2015, 01:21 PM   #1487
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Motorman007 View Post
Thank you sir
final ratio 9.22
Yes, I would gear up and use more range of your throttle and there's nothing wrong with running a 9.5-10.5 on a dirt track of that size. Before one of our old dirt tracks started sweeping and saucing traction up to an asphalt like level in the groove, I regularly used a 10.5 in a mod class there. Driveability is what makes one competitive in that environment.
MarkA is online now   Reply With Quote
Old 10-05-2015, 07:09 PM   #1488
Originally Posted by klx1695 View Post
How do these compare to the b5ms?
I have been doing a bit of back to back testing with this car and my trusty b5m lite. The b5m feels lazy after some time with the yok. The yok is so responsive that it feels like it is on a different level. I run my steeri,g at full travel and 100% speed on my b5m, but have the speed turned down to 80% On the yok and it still is more responsive. When I get it right the yok is definitely rewarding, but the b5m is easier to drive fast. Of course this is all based on my moderate (at best) skills.
afm223 is offline   Reply With Quote
Old 10-05-2015, 07:57 PM   #1489
thecman26's Avatar
Trader Rating: 99 (100%+)
Thank you sir
final ratio 9.22
Thanx sir
That's the 405!
Anybody run the YZ-2 there? How is it?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-06-2015, 02:35 AM   #1490
What is everyone running in this car for battery square shorty or saddles? Which is better?
turtle189 is offline   Reply With Quote
Old 10-06-2015, 08:18 AM   #1491
8ight-e's Avatar
Trader Rating: 58 (100%+)
depends where you want weight and how much weight Shorty allows you to make changes in position.. the other two are essentially the same, they just take up the entire space and add weight (which at times maybe what you want). If you buy 1 pack id get the shorty, if you can get two have both :P
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 10-06-2015, 07:21 PM   #1492
svndayNZ's Avatar
Trader Rating: 20 (100%+)
Sorry if it's already in here but it's a lively thread so could take awhile to find it. Does anybody know if the Schelle B5M chassis protector would fit the YZ2. The YZ is a narrow based chassis so I'm not sure with some trimming if it should fit?
svndayNZ is offline   Reply With Quote
Old 10-06-2015, 07:46 PM   #1493
It fits, need some trimming on the back sides and some parts on the front are not protected but was efficient for me to keep my chassis clean
mojo tom is offline   Reply With Quote
Old 10-06-2015, 08:15 PM   #1494
Amain sells two different Protek chassis protectors for the YZ-2.
Old 10-06-2015, 08:47 PM   #1495
svndayNZ's Avatar
Sadly Amain take 31 years to ship to Sydney. So I'll pass on Amain.
But I'll give this Schelle one a try
Old 10-07-2015, 11:55 AM   #1496
C4PT4IN's Avatar
Getting a new 8.5t motor. What gearing should i be looking at for a smaller mid-high grip track?
Also, i want a body like this for my buggy.. Message sweep about it for the good of everyone
C4PT4IN is offline   Reply With Quote
Old 10-07-2015, 12:59 PM   #1497
http://www.petitrc.com/setup/yokomo/...VDM2015071112/
80/25
http://www.petitrc.com/setup/yokomo/...ort2015050910/
80/25
http://www.petitrc.com/setup/yokomo/...space20150412/
80/22
Old 10-07-2015, 01:46 PM   #1498
23 was good for a 7.5
24 for a 8.5
Old 10-08-2015, 09:22 AM   #1499
scr8pn4205's Avatar
rear shocks mounted of front vs rear of tower. pros and cons? tight ozite track running shocks if front right now just not sure the difference between the 2
thanks
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 10-08-2015, 09:29 AM   #1500
Moderator
MarkA's Avatar
You get more steering and have a more unbound rear with the shocks on the front of the rear arm, you get more rear grip or, in other words, a more "plush" feel with them on the back. If the bite is high on carpet/turf, lap times will generally be faster with them on the front as they let the car rotate quicker even if the car "feels" better with them on the rear.
Currently Active Users Viewing This Thread: 8 (1 members and 7 guests)
tekin112000
