Ceramic bearings - oil before using?
I'm going to get a set of ceramics for my sc. For new bearings, do you install them straight into the car with no prep or do you pop seal, clean, and lube with your oil of choice before installing into the car?
You save yourself the hassle and $100 by not buying them. Unless you plan to clean them after every couple of runs, they will fail much sooner than expected. They don't handle dirt too well, and don't handle high shock loads, like landing a big jump.
If you still plan on getting a set, just install and run.
Thanks for the tip. Is reliability still an issue for driveline use, rather than using in the hubs?
R/C Tech Elite Member
Get some regular bearings and a bottle of this http://www.shopviperrc.com/ProductDe...e-for-gearlube
Open the seal, spray them out with motor spray and lube them up with the dry lube.
https://www.youtube.com/watch?v=WZwv1hhbDQ4
Eric, is that what you do? That DryFluid looks amazing, I've never heard of it before.
