Like Tree16Likes
Old 01-25-2016, 05:48 PM   #1426
werner sline's Avatar
Originally Posted by nitro2be View Post
for sale MBX7R eco - hardly used, never raced, modified parts , and many other upgrades . Great car and never abused
I will use it until it dies !! usually as long as the chassis holds !
werner sline is offline   Reply With Quote
Old 01-27-2016, 05:00 AM   #1427
I found the front suspension too soft, even with the 5 holes pistons.
so I built this carbon shocktower, wider than the stock one. I want to check if it jumps better with this modification !
I used 2 integy 2mm carbon sheets glued together with epoxy
I used a rooter for the round edges, then a angle grinder + some filing.
I added epoxy glue on the boarders
looks like a tekno EB48.3 !
or somehow like a 1/10th buggy !
let's see how it breaks, lol. I guess the lower part near the screws is too narrow...
another thing : I summed up all the weight of my components and came to this weight distribution that seems better ( again, with my components ) than the stock distribution
but it's not perfect...
those are the estimated center of gravity of each side
Old 01-27-2016, 07:35 AM   #1428
It's the "official" thread.
Start a new thread with your tweak
intense82 is offline   Reply With Quote
Old 01-28-2016, 08:31 AM   #1429
Matt1970's Avatar
Originally Posted by Matt1970 View Post
Having a little issue with my buggy sliding out around the middle of turns off throttle and sometimes at exit. Running zero on drag brake. If I get on the throttle it straightens out. Indoor clay track, med-bite. A couple of races ago the track was real tacky and it was better, but still a little loose even in those conditions. It was good until about a month ago. I've made some adjustments here and there, but nothing seems to help much. I replaced shock oil a while back and replaced the stock 550 in front and back with AE 47.5 in front and AE45 in the rear since AE is only oil available at LHS so I don't know if that's the issue? Maybe too thick? I've attached a pic of my latest set-up.
So a little follow-up on my issues. I went lighter on oils and ended up at AE37.5 front and AE 32.5 rear. I raised my diff oils 10-10-5. Those adjustments helped some, but the biggest improvement was the club race a couple nights ago was a new track and almost no straightaway anymore. Mostly jumps, turns, etc. so I took my pinion gear down a tooth. Went from 16-15 for the tighter track. I can't believe how much it helped my buggy going into and out of turns. Had a lot of cars and good drivers. I qualified first in C main and finished 2nd (got hacked early on and worked my way past everyone but first, just needed another minute on time and could have passed him). Ran well against good guys in B main and finished about 5th I think. Much better than previous races. I've only had it a few months though.
Mugen XB7R Eco Tekin RX8 Gen 2 / Tekin 2050kv
Tekno SCT410.3 Tekin RX8 Gen 2/ 4300HD/BCE Chassis
Future additions: Whatever I can get without my wife seeing it!!!
"When in doubt, FULL THROTTLE. It may not be the best solution, but it ends the suspense."
Matt1970 is offline   Reply With Quote
Old 01-28-2016, 02:31 PM   #1430
the screw that holds the rear long chassis brace teared the gearbox... so I decided to use the front medium chassis brace in the rear ! ( mugen gives you 3 chassis brace in the kit )
As it is shorter, you get more flex from the chassis. I just had to trim it a bit and make a 4mm hole in the chassis. I added a thick shim to get the right height
The chassis brace also prevents the chassis from being bent after a hard crash
Old 01-31-2016, 09:52 PM   #1431
RMKinWI's Avatar
Trader Rating: 15 (100%+)
Can someone tell me the part numbers for the front and rear springs in Adams standard setup?
http://www.mugenracing.com/content/S...d%20set-up.pdf
Matthew Lust
www.WisconsinSurplus.com
RMKinWI is offline   Reply With Quote
Old 01-31-2016, 10:54 PM   #1432
Can I ask why do ppl change the rear shock tower to carbon
Shock tower
coombes is offline   Reply With Quote
Old 02-01-2016, 08:57 AM   #1433
rcgod's Avatar
Trader Rating: 27 (100%+)
Shock tower
Carbon towers flex more for better traction and lower cog. At least that's what Drake claims.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-01-2016, 09:26 AM   #1434
rcgod's Avatar
http://www.racemugen.com/forum/viewtopic.php?f=9&t=89
Dialed RC Hobbies
Old 02-10-2016, 12:46 PM   #1435
Will everything on the r work on the mbx7?
MikeGassRacing is offline   Reply With Quote
Old 02-10-2016, 07:00 PM   #1436
nitro2be's Avatar
yes
nitro2be is offline   Reply With Quote
Old 02-11-2016, 01:54 AM   #1437
Everything will work but some things you will need to change a few extra parts.
Rear Universal shafts - you will need the lower arms, uprights and some bearings.
Rear shocks - you will need to change the tower.
Sully is offline   Reply With Quote
Old 02-11-2016, 06:43 AM   #1438
Thank You!
Old 02-11-2016, 08:39 AM   #1439
No worries, now that i think about it the same probably goes for the front universal shafts, you might need the 7R uprights and bearings there too.
Old 02-14-2016, 07:49 AM   #1440
1fast5ive's Avatar
Originally Posted by hairymuffin View Post
Very nice nitro2be...
Here is my sons,fresh from vegas
Can you tell me what body that is?
1fast5ive is offline   Reply With Quote
