Mugen MBX7R Eco thread!
#1366
#1367
werner sline: yes, assuming the bearings sit exactly flush, the space between the diff bearings, what could be called the installation length of the differential.
#1368
I also took those pictures. you should have more infos and read the dimensions
22.4mm :
might also be usefull :
22.1mm and 32.5mm ( the bearings can slide quite a lot on the diff outdrives. so mugen let some space between 32.5 for the diff and 32.9 between the towers )
#1370
aluminium front arms will break anyway : to stop a 3.6kg car, you need to absorb the hits so you need flex
My hobao arms ( with steel bandage ) can be bashed very hard because they flex
but on a racing car, you don't want too much flex, that's the difficulty.
About xray : they flex a bit, that's why they are more durable, and that's why xray adds carbon plates on them !!
let's see how they designed the mbx8 arms
#1372
by chance, would anyone have that lil piece that the transponder mounts to xtra they would like to sell? I bought a used MBX7R eco and for some reason it wasnt on there. I really dont want to buy a plastics replacement kit just to get that lil piece if I can help it lol
#1373
werner sline: Awesome, thank you very much!
#1375
#1376
werner-sline: convert a CEN Matrix. The Mugen is one of 3 buggies with a motor/diff mount to my liking, strange as it may seem to put high-end stuff on that platform. Got a nice deal for RC8B diff and wondered if it could be compatible. Seems like it should. Though the next nice deal already happened for a Serpent mount, so I'm about to learn the hard way if that fits (or if I have to consider fabricating a new cover piece)
#1377
I went the cheap way : L shaped 3mm aluminium piece from the hardware store + some diff plate that take 16mm bearing ( like the tekno ones for example )
that's a ultra lx2 diff + ultra lx diff plates for my monster truck :
check out my photobucket for more pictures
of course, this simple system is not as easy to adjust as modern sliding diff mounts, but its way cheaper and I always use some strong 4mm screw to hold the motors.
#1378
New Mbx7r Eco Buggy
Hi all, New to 1/8 EP Buggy. I'm in the build of my New Mbx7r Eco...currently running Mbx7r Nitro and have raced many brands over the years only ever gas, This is the best handling Buggy I've ever had, which is why I need to try EP so this is a first.
Now I wish I had read this thread earlier regarding Esc and Motor Combo as I've purchased Tekin Rx8 Gen2 with 2600kv. I have never read on this thread anyone using this high KV motor, Am I better to sell it new before I install it or is this motor able to be dialled down....Ill more likely run the 14t pinion with box set up for a start with a Gens 5000mAH 4s 40c battery.
Thx in advance for any input
#1379
Yes sell that monster to Werner Sline. He needs more power. Lol. 1900 is all anyone ever needs imo. I have tried big motors, usually more wheel spin and hotter temps.
#1380
