Like Tree16Likes
Old 12-09-2015, 12:54 AM   #1351
werner sline's Avatar
Originally Posted by Jw1529 View Post
Just found out today that mugen is changing they're material they use on the arms to make them much more stronger on the new mbx8. I was looking to retrofit a different brand of arms on my buggy until I found this out today.
exactly what I was wishing ! how did you get this info ?
I bashed my mb7r eco not too hard in the beginning : both front arms broke very quickly. I put new mbx7r arms with metallic bandage : they broke anyway...
I changed to hobao hyperstar arms with metallic bandage and beat the sh** out of this version and it didn't break ! the rest of the mugen parts hold actually very well. the rear wing starts to look bad but I will change it ... for a hobao wing !
what I do when bashing : backflip, frontflips and lots of failed attemps !!
werner sline is offline   Reply With Quote
Old 12-09-2015, 03:34 AM   #1352
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Where you See a new buggy? nothing wrong with the mugen plastic,its just the design...if anything new comes out, it would be closer to the worlds...even if you boil the plastic,the arms can break because of the design.. If they make the arms softer it will effect handling
hairymuffin is offline   Reply With Quote
Old 12-09-2015, 04:37 AM   #1353
about front arms design : do you think that the tekno arms would hold better ? their design is very different ...
Old 12-09-2015, 05:03 AM   #1354
Yea but they dont fit,tekno arms are super beefy...maybe xrayarms? Same issue with associated...it's not an issue for the pros because they don't crash hard
Old 12-09-2015, 05:17 AM   #1355
That's the best part about this car though you only need to stock up on front arms and front steering hubs and that's it not even the upper arms. Other parts on the tekno break before an arm like diff cases and towers...there is no perfect car. Kyosho even more fragile... A friend of mine at my track has everything on his front and aluminum he drives a Kyosho.. I'm sure someone somewhere makes aluminum arms for the mugen car..
Old 12-09-2015, 05:21 AM   #1356
A friend of mine races for mugen and he told me Drake has been working on a new design for the mbx8. They are using the same compound as what losi uses in they're plastics because they don't brake. Mugen will be freeing up the drive train as well, I'm hoping they aren't going to dog bones for the center shafts like on the losi. Drake should be running the 8 for worlds.
Jw1529 is offline   Reply With Quote
Old 12-09-2015, 05:40 AM   #1357
Universals are coming for the center...when there is no issue for the pros, there is no issue,thats how companies look at it,..my son broke 3 arms this year.. I dont think adam broke any..i will look at his car saturday...
Old 12-09-2015, 06:00 AM   #1358
prsjdsx1cr's Avatar
Originally Posted by Finken View Post
Will the Jconcepts Silencer Mbx7 body, fit my Mbx7r eco, i mean perfect fit?
Yes I just put our newly painted mbx7 eco body on our new mbx7r eco perfect fit
prsjdsx1cr is offline   Reply With Quote
Old 12-09-2015, 06:21 AM   #1359
I use the 6ecopl bulldog,fits tighter but i like the look better
Old 12-09-2015, 08:04 AM   #1360
Originally Posted by patrick lsp View Post
I ended up liking 573 in diffs after a couple days of changes. 550/500 with 1.3 5 holes.
Car is good. Way better than I can wheel it. You are welcome to drive it next time I see you. Drives a lot like my losi did, but more stable.
550 front , 500 rear?
eortizr is offline   Reply With Quote
Old 12-09-2015, 08:33 AM   #1361
Im pretty sure 550 front
Old 12-09-2015, 12:59 PM   #1362
aluminium front arms will break anyway : to stop a 3.6kg car, you need to absorb the hits so you need flex
My hobao arms ( with steel bandage ) can be bashed very hard because they flex
but on a racing car, you don't want too much flex, that's the difficulty.
About xray : they flex a bit, that's why they are more durable, and that's why xray adds carbon plates on them !!
let's see how they designed the mbx8 arms
Old 12-09-2015, 02:41 PM   #1363
patrick lsp's Avatar
Trader Rating: 172 (100%+)
Yep. 550/500. Other running stock Pistons running 600/600 and 600/550.
My shock pkg landed and settled quicker on our indoor medium/high bite track.
I am also running nitro black springs. This is just my setup that works for me. No guarantees. Trial and error.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Old 12-09-2015, 02:45 PM   #1364
Hairy muffin- when will we be able to pick up f/r uni's.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
Old 12-13-2015, 09:01 AM   #1365
Hi! Could somebody do me a favour and measure (to 0.1 mm) the distance between the diff/motor-mount plates?
thorwil is offline   Reply With Quote
