Like Tree13Likes
Old 11-20-2015, 03:38 AM   #1321
rider313's Avatar
Trader Rating: 94 (100%+)
Shocks F/R, rear tower, F/R universals, chassis and mud guards.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 11-20-2015, 04:05 AM   #1322
Trader Rating: 40 (100%+)
If you get the 7R F/R universals you will also need the new front hub carriers so you can run a trailing front axle and new rear uprights. The rear arm was also changed to clear the new universal.
Rick S is offline   Reply With Quote
Old 11-20-2015, 06:58 AM   #1323
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by coombes View Post
What parts do I need to do a basic upgrades do I need going from a 7 eco to the 7r eco
Just do the shocks and rear tower...chassis and universals are not needed.. U can upgrade the universals if you break a axle.. Maybe the steering slider but also not needed.. Just do the shock setup and you will be happy
hairymuffin is offline   Reply With Quote
Old 11-21-2015, 02:38 PM   #1324
werner sline's Avatar
about Front Universal :
it's possible to use those cheaper ofna Front Universal on the mbx7r eco :
http://www.nitrohouse.com/Front-Univ...-2_p_8026.html I
I checked the size and it's exactly the same. only difference are the pins : mugen uses 3mm, ofna uses 2.5mm pins. So you'ill have to switch to other pins/hexes.
The ofna are cheaper and thicker ! you won't bend them like the mugen's...
here the mugen:
http://www.nitrohouse.com/Front-Univ...R_p_17192.html
other mugen part I changed : the steering has some issues with the suspension travel : the 6.8 mm pivot ball don't allow enough angle to the plastic rod end.
So the steering squicks and bends when the droop is quite high but not even at its maximum.
so I use those 6.8mm hobao hyperstar "thinner neck", like here :
http://www.ebay.co.uk/itm/Hyper-Star...-/191105845347
The steering doesn't bind anymore at high droop !
werner sline is offline   Reply With Quote
Old 11-21-2015, 10:07 PM   #1325
nitro2be's Avatar
I added 2mm ball stud washers under my steering rod ends to help with binding at full droop. I did this with out research and seems to work. I just eye balled the effects , any feed back on this would be nice
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 11-21-2015, 11:38 PM   #1326
R1Joel's Avatar
Anyone have trouble with pillow ball nuts coming out? I lost one nut last meet, replaced them and now I've lost another this meet. I am doing them up to the point just before the steering starts to bind up. I don't know what else I can do other than Loctite? This is on the older M-Spec.
R1Joel is offline   Reply With Quote
Old 11-22-2015, 01:54 AM   #1327
check out how much toe out the steering gets when the suspension fully compressed.
but, after all, it might help steering when turning while braking !!
Old 11-22-2015, 01:57 AM   #1328
i never had this problem
you might loctite yours ?
Old 11-22-2015, 02:40 PM   #1329
R1Joel's Avatar
I'll Loctite them today.
Old 11-22-2015, 03:23 PM   #1330
are there any snow skis that would fit on this car? lol ik im crazy. but i want to do it.i seen them snow skis on that t-bone site. got me thinking..
jomoe is offline   Reply With Quote
Old 11-27-2015, 04:47 PM   #1331
nitro2be's Avatar
Wow, this question stopped this thread
Old 11-27-2015, 05:45 PM   #1332
ski are meant for 2wd cars. you will need more work to adapt it on a 4wd car...
let's continue the thread !
to achieve maximum steering, i trimmed some plastic for the hubs ! now it steers like kung fu !!
Old 11-28-2015, 05:58 AM   #1333
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
DON'T Loctite them, Loctite eats up plastic. Use fingernail polish
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 11-28-2015, 09:36 AM   #1334
gokarter64's Avatar
Default New to 1/8 scale
This is something i have always wanted to try but the cost held me back. I found a mbx7 and the price was right so i bought it.
I have been racing 1/10 indoor for 6 years now so im in no way new to the hobby, but are there any glaring differences ill need to keep an eye on when it comes to 1/8 scale vs 1/10?
gokarter64 is offline   Reply With Quote
Old 11-28-2015, 02:19 PM   #1335
looks good ! put some boots on those shocks and you're done ! almost...
