Like Tree12Likes
Old 08-28-2015, 02:31 PM   #1126
Originally Posted by rcgod View Post
When you order parts get them from dollar hobbyz. Do a search for mugen and sort by lowest price first. There are multiples of most parts but some are cheaper than others so it helps to sort. Trust me you will save a lot of money. They usually ship same day too. The only part I've seen there that isn't a great deal is front arms. Some stuff is 1/4 to 1/3 what you will pay ordering online fyi.
Yeah I came across dollar hobbyz before I bought the
Mugen. Prices are pretty ridiculous 👍
JJG690 is offline   Reply With Quote
Old 08-30-2015, 08:03 AM   #1127
Anyone tried the 5x1.35 pistons for indoor? If so, how did the performance differ from the stock 8x1.3 pistons?
Old 09-01-2015, 01:01 PM   #1128
Nitro Tiger's Avatar
Could someone point me where to get a slipper clutch with clutch bell like drake runs.
Wade Lazich- NSW 1/8 IC State Delegate.
Thankyou for your support- Werks Racing USA/ Pro Rc Supplies/ Aka Aust./ Ryper Hobbies
LRD- Australian distributor of Werks Race Blend 30% fuel. Dedicated solely to the supply of racing products for 1/8 scale nitro Rc. -lazrd.com.au-
Nitro Tiger is offline   Reply With Quote
Old 09-01-2015, 03:07 PM   #1129
rcgod's Avatar
Trader Rating: 27 (100%+)
They're discontinued but you can still find them online. Google the part number.
http://www.amain.com/rc-cars/tekno-rc-traktion-drive-elektri-clutch-system-tkr4301x/p181463
rcgod is offline   Reply With Quote
Old 09-01-2015, 04:10 PM   #1130
egobrkr's Avatar
Trader Rating: 26 (100%+)
After searching 10 pages of search results for the clutch system I found 1 so I bought it.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 09-02-2015, 03:46 PM   #1131
nitro2be's Avatar
did you see this. New tlr e buggy clutch posted on neo buggy 30 hours ago. 2nd page
http://www.neobuggy.net/mobile/page/2/
nitro2be is offline   Reply With Quote
Old 09-03-2015, 08:04 PM   #1132
Guillermito's Avatar
Hello, I wonder if someone uses a Cooling Fan to the motor? My engine is a Tekin Gen2 2050Kv.
Thanks. Best Regards.
Mugen MBX7R - Nova Keep Off 4S - Futabas S9353HV & R614FS
Mugen MBX7R ECO - Combo Tekin Gen 2 - Futaba S9353HV & R614FS
Team Durango DEX410V3 - Tekin Redline G2 7.5T & RS Pro - Futabas BLS551 & R614FF
Tamiya TRF417X - Tekin Redline 6.5T & RSPro - Futaba BLS551 & R614FS
Tamiyas: Hotshot - Blackfoot - Avante 2011 - Futaba 4PKS-R FASST
Guillermito is offline   Reply With Quote
Old 09-03-2015, 10:41 PM   #1133
I've used them in the past and yes they do work, but you should instead look at what is making your motor run hot in the first place. Gear ratio, gear mesh, and run time are all easy things to take a look at before you just slap a fan on there. Hope that helps and I'm sure others will chime in with their opinions as well
Old 09-03-2015, 11:28 PM   #1134
nitro2be's Avatar
I have been running hot at 190 to 200. I moved my esc fan behind the motor with double sided tape to chassis and rear chassis support and it worked great. I was down to 150 to 160. I have same 2050kv
Old 09-04-2015, 01:26 AM   #1135
Just picked up a very barely used eco 7, pulled off a 2nd in one of the finals so pretty happy with that, did have a big problem of over shooting the jumps , landing hard and then coming all undone (that was my fault not the cars, usually run 1/10), as its a m spec and I have no idea what the oils any where are, I am up for a rebuild and inspection, I am going to use whats been advised here with 774 diffs, 45/650f 40/550r at 22,25 ride height and going to run lower middle rear link, 7.5f spring, 7.75r, not sure of droop eye to eye and when grease on the diff gears is mentioned are you using silicone grease like on the smaller ball diffs I give them a coating of shock oil great for 1/10 diff gears not sure for the bigger cars, last mugen I ran was a bulldog many years ago, happy to be part of the mugen family again.
jagman1 is offline   Reply With Quote
Old 09-07-2015, 10:53 AM   #1136
Trader Rating: 65 (100%+)
For the serious racer it's best to confirm by starting over with your own oils and go through everything. Fill out a setup sheet as you go. Droop is going to depend on track like most settings. Test with stock settings and find what works for you.
IMHO- If it rolls, oil it. If it slides such as gears, grease it. Best to use grease designated for gears. Ball diff grease is not really for gears, but anything is better than dry to get maximum life from ring and pinion. Grease protects better than oil. Doesn't take much if you go through your drive train every few race events. I think 50 lipos is a good inspection point for diffs. CVDs and wheel bearings depend on how clean track is. About 25 lipos for my loamy track.
Mugen is a really solid rig with large following. Hard to go wrong.
Thunder Trail is offline   Reply With Quote
Old 09-07-2015, 11:05 AM   #1137
I'm trying out a 1750kv Orion that I was able to get cheap. Normally I run 1900-2100 motors. I am running the stock kit gearing with 15 degrees of timing and the other buggies very slowly walk away on the straights. I catch up in the turns so I'm not running any slower lap times but I'm wondering if gearing up would be a better option to gain back the lost speed than adding timing. Stock gearing and the timing I have now I'm at 153 degrees after a 10 minute main, thanks
Turtlex is offline   Reply With Quote
Old 09-07-2015, 11:26 AM   #1138
O and I see some of you are running the smc 1900 motor. I got one and the sensor board in the motor went out after one battery pack with the motor only reaching 135 degrees. It runs fine sensor less. How is Danny's customer service? Think he will replace/repair it? That's the reason I got the Orion cause there was a big race yesterday and I didn't have time to try and get it fixed
Old 09-07-2015, 07:23 PM   #1139
rcracenut's Avatar
Trader Rating: 52 (96%+)
Are there better front lower arms for the 7 eco? I have broke two now. Seems to be a weak link. I never had this problem with my 6 eco.
____________________________________________
1 Corinthians 10:31 ...whatever you do, do it all to the glory of God.
S&N Trackside Hobbies
Innovative Hobbies and Raceway
Clark RC race park
rcracenut is offline   Reply With Quote
Old 09-07-2015, 08:57 PM   #1140
mebolson's Avatar
Trader Rating: 39 (100%+)
I had the same issues with my 6, 6r, and 7... I haven't broke anything on my 7r this whole year
I have heard the the RC8.3 arms "mostly" fit if you want to give it a shot.
E
Support my small time online hobby shop
www.FactoryRCHobbies.com Custom Race Shirts and Pitmats Dealer for: Soar Seiki, T-Pro Racing Tires, Lipo Batteries, MIP Tools, VP-Pro Tools, and some other stuff
mebolson is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Halert71
