Like Tree13Likes
Old 07-23-2015, 04:54 PM   #946
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by nitro2be View Post
and I used kyosho center rear and front universal drive shafts. Front kinda to long but I shaved it down a few mm and looks to be good fit now. Read rc8b3 front center universal drive shafts fits well
Are the kyosho drive pins replaceable on their universals?
hairymuffin is offline   Reply With Quote
Old 07-23-2015, 05:22 PM   #947
roblupo's Avatar
Send a message via Yahoo to roblupo
not sure, but I would think so, I have the Mugen tool to replace pins, its def worth getting to save outdrives
Mugen USA MBX7Reco
Mugen USA MBX7R nitro, AKA tires, Airtronics radio, Tekin Power, Turnigy Lipo, Maxy fuel
Team Associated B5
Low Country R/C, Philhurdraceway.com, Savannah, GA
roblupo is offline   Reply With Quote
Old 07-24-2015, 11:21 AM   #948
nitro2be's Avatar
Originally Posted by rcgod View Post
I run kyosho shocks on mine too, and fyi if you use the 7r shafts in the front kyosho shocks it makes them about 3mm longer and allows more droop. The only way I could get to Drake's front droop setting before was unscrew the shock ends. But then I started pulling the ends off of the shafts in a crash. The mugen shafts aren't too long either. They don't hit the bladders at full compression.
yes, I am using the mugen shafts and I can get up to 106 droop in front if needed. thanks for clarification for others.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 07-24-2015, 07:35 PM   #949
rfleck's Avatar
Trader Rating: 58 (100%+)
You have to use 2.9mm pins. Major turnoff I had when running Kyosho for 3 years. You can find the pins but not readily.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 07-24-2015, 08:48 PM   #950
Ran my 7r for the first time last night, man the plastic spur gear is noisy. Is this normal, changing the mesh made no difference.
goldy is offline   Reply With Quote
Old 07-24-2015, 11:39 PM   #951
Shouldn't be noisy,my steel spur is quiet...I think tlr is the quietest I've heard.. Maybe it's motor noise? Is your motor used? Does everything feel pretty free?
Old 07-25-2015, 03:46 AM   #952
The pinion to spur will wear in, as Long as your mesh is correct. It will Quiet down a little bit. For the 6 that is at my local, mugen has a sound all to it's own.
Dont Hack Me is offline   Reply With Quote
Old 07-25-2015, 03:50 AM   #953
OfnaJoe's Avatar
You use the steel spur? I have thought about it but didn't want the extra rotation weight.
Mugen Seiki \\ Dialed RC \\ Tekin \\ SMC \\ AVID\\ AKA \\ Futaba
OfnaJoe is offline   Reply With Quote
Old 07-25-2015, 04:28 AM   #954
Yea because all we run is outdoors..the plastic spur is very good, in the past, the only time I stripped a gear is because the motor moved..indoor the plastic will last forever
Old 07-25-2015, 04:50 AM   #955
It certainly does have a noise that can be heard over everything else!
Old 07-25-2015, 04:55 AM   #956
Indoor? If it's a new car, the drivetrain needs to break in..if it is new, make sure the ring/pinion gears are not too tight(no shims)
Old 07-25-2015, 06:44 PM   #957
Its an outdoor car. I will check all the meshing and try again.
Old 07-26-2015, 10:59 AM   #958
I'm running a tekin t8i and a Novak pinion and it's super quiet compared to my hobbywing combo with a tekno pinion in my eb48.2...
worm304 is offline   Reply With Quote
Old 07-26-2015, 06:31 PM   #959
easye's Avatar
So you run no shims at all?
easye is offline   Reply With Quote
Old 07-26-2015, 07:10 PM   #960
rfleck's Avatar
I run two shims to space the ring gear away from the pinion when new. It's been like that for both my nitro and electric cars
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
