Like Tree14Likes
Old 05-23-2015, 07:41 AM   #736
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by R1Joel View Post
Hard packs aswell. It's unlikely to have a problem with soft packs but the risk is there.
If you are looking for a cheaper hard pack, Fantom racing just came out with some sport series 4 cell's for only $70.
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 05-24-2015, 11:34 AM   #737
TOO-TALL's Avatar
What's the stock anti squat and toe in? I look but can't find it.loveing the buggy so far.
TOO-TALL is offline   Reply With Quote
Old 05-25-2015, 04:22 PM   #738
idbdoug's Avatar
thinking about trying tapered pistons!!! any recommendations on brand, hole count, etc
thanks
idbdoug
www.r1wurks.com
Old 05-25-2015, 05:10 PM   #739
werner sline's Avatar
thinking bout getting a mbx7r eco as a basher
I like the fact that ball bearings are overall 16x8mm
what parts do break when bashing hard ?
werner sline is offline   Reply With Quote
Old 05-25-2015, 10:43 PM   #740
Standard is 3* Anti Squat and 2.75* Toe.
With the dot on the rear insert down it works like this:
Anti Squat, front insert dot:
Up - 4*
Middle - 3*
Down - 2*
Toe, rear insert dot down and:
Inside - 2.5*
Middle - 2.75*
Outside - 3*
Sully is offline   Reply With Quote
Old 05-26-2015, 04:02 AM   #741
Motorman007's Avatar
Trader Rating: 76 (100%+)
Up - 4*
Middle - 3*
Down - 2*
Inside - 2.5*
Middle - 2.75*
Outside - 3*
This should help
The official Mugen MBX7R Eco thread!-screenshot_2014-09-21-09-28-37.jpg   The official Mugen MBX7R Eco thread!-screenshot_2014-09-21-09-28-19.jpg
YOU WILL (ALWAYSWIN).....
Motorman007 is offline   Reply With Quote
Old 05-26-2015, 04:20 AM   #742
Gpeters66's Avatar
Originally Posted by Motorman007 View Post
This should help
I would like to print this out. Where do you find this chart? I tried to print it out from here but it came out so small I couldn't read it.
Grant
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 05-26-2015, 04:29 AM   #743
Grant
This what we had back when i say the mbx6 or 6r and 7. Someone Team wise made this for us Mugen Fans.
PM me and i'll email it to you. I keep it on my phone so when I need to look up stuff I have with me at all times.
Old 05-26-2015, 04:34 AM   #744
Old 05-26-2015, 06:14 AM   #745
Trader Rating: 14 (100%+)
Has anyone tried the +1mm or +2mm hexes?...front or rear if So what was the result?
There really is no reason to run the wider hexes up front.
In my experience, the wider rear hexes really free the car up. Even 1/2 a mm makes a difference, the avid carbon pieces are work really well to try small adjustments.
If you are a on a low traction surface, stick with the stock hexes. The only time I could see using the wider hexes are high traction (and you need more rotation) or you need some extra stability on a really rough track.
The wider hexes do aid on power steering as well, but it might not be the best adjustment to get that, depending on the traction levels.
o.s. power is offline   Reply With Quote
Old 05-26-2015, 09:10 AM   #746
TOO-TALL's Avatar
Awesome!!. ...thanks for all the replys
Old 05-26-2015, 01:33 PM   #747
Here is some info
jmaxey51
jmaxey51's Avatar
Originally Posted by Eastside777 View Post
Guys at one point there was a discussion about wheel hex extenders . I think that's what they are called not sure . But what was the finally verdict on which went were ? Did the 2mm up front and 1mm in back work better then how it's was on the mbx6 1mm in front and 2mm in the back ?
Was it more stable in ruff track conditions compared to running stock extenders ?
Can you run 2mm front and back?
From all what I've tried I like 2mm front 0/stock rear with the 7.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
Mugen MBX7
01-05-2014, 10:25 PM #6478
Ben Burtle
Can you run 2mm front and back?............................................. .................................................. .................................................. .................................................. .......................................
It is all track dependent on whether you need them or not. I know "in my experience with several cars" extending the rear dramatically increased bump handling on power. It increases rear traction rotating around corners so it may slow you down or help you consistency. In the front I find a decrease in steering extending out and the car has slower reactions and reduced steering. Easier to drive with less steering in other words. It's a good tuning option to have. Just remember to consider droop setting as you move your wheels further out. You may find a nice balance with more offset hexes and less droop.
www.benburtle.com <---- CHECK OUT THE NEW IMPACT PERFORMANCE PRODUCTS HERE
Team Driver for:
Mugen Seiki | IMPACT Performance Products | Team Tekin | Team Futaba | AKA Tires| Maxy's Engines | Maxy's Fuel | Elite Performance R/C Hobby
Mugen MBX7
Old 05-26-2015, 01:54 PM   #748
offroad dude's Avatar
Trader Rating: 25 (100%+)
Do you have the chart for the front also?
offroad dude is offline   Reply With Quote
Old 05-26-2015, 02:08 PM   #749
Still looking sir. But I think front will be the same as on the Hudy setup or JQ setup
Old 05-26-2015, 11:36 PM   #750
what is every one running on there rx8 esc setting wiseon a low traction track I am running a tekin rx8 and a trackstar 1900kv
coombes is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
