Like Tree12Likes
Old 05-05-2015, 11:57 AM   #691
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by ben_john View Post
I'm wanting to change the front... Have you tried that??
Yes that's what I said. I used front and rear with mbx6 front uprights and rear hubs.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-05-2015, 07:46 PM   #692
ben_john's Avatar
Oh.. I see. Thanks man!!
ben_john is offline   Reply With Quote
Old 05-06-2015, 12:28 AM   #693
Trader Rating: 65 (100%+)
Need to find out why they are bending. Must be bottoming out in the cup at full compression. Some rubber stops on the front shocks might help. Check plunge in the out drives. If it's too deep add equal washers on PB top and bottom to provide clearance.
You can also straighten those bones in a vise if you are careful. I have straighten many in the past. They were not 100% straight as new, but very close and did continue to work for year or so.
Hope you figure it out either way, but seems wrong to go back to old style parts IMO. Good to have the option to do that though since you own the parts needed.
Thunder Trail is offline   Reply With Quote
Old 05-06-2015, 07:07 AM   #694
jmackani's Avatar
Trader Rating: 14 (100%+)
My front universals are extremely bent and they are on backorder everywhere. Does anyone know of any alternatives?? I have a big race coming up...
I noticed one of ours was bent this weekend also. Local shop had one set in stock though.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 05-06-2015, 07:20 AM   #695
ben_john's Avatar
Good Advice man... I'll check that out, I did't think about plunge. I did notice that the front is way more sloppy than the x6r was too. Seems to come from the upper arms and/or ackerman rack. I thought maybe the slop had something to do with it, but I'll check plunge too.. Thanks!
Old 05-06-2015, 07:21 AM   #696
tlyons68's Avatar
Trader Rating: 75 (100%+)
anyone having excessive wear on chassis where the droop screws touch the chassis ?mine has almost completely wore through chassis from the droop screw head against the chassis buggy is 2 months old !!
tlyons68 is offline   Reply With Quote
Old 05-06-2015, 10:13 AM   #697
rchogfan's Avatar
Has anyone happened to try the tekno wing on their mbx7? I'm wanting to make sure it'll fit. I'm looking at getting a couple and I like the look and they are about $7 cheaper than the proline wing. Thanks in advance.
**CALVIN BRUCE**
MUGEN SEIKI MBX7 ECO - TEKIN GEN 2 RX8 1900T8 | MUGEN SEIKI MBX7 - ALPHA LUTZ WORLDS | B5M CE - TEKIN RSX - 9.5 | 2015 XB4 - R10 PRO - 6.5 |
rchogfan is offline   Reply With Quote
Old 05-06-2015, 10:14 AM   #698
tlyons68's Avatar
teknno wing fit right on no problems
Old 05-06-2015, 11:00 AM   #699
rchogfan's Avatar
Thank you for the quick response, sir.
**CALVIN BRUCE**
Old 05-07-2015, 05:16 AM   #700
Jason Baliban's Avatar
Not surprised to hear this. I just started driving the car two weeks ago (and 8th scale in general) and i cannot believe the amount of stress and wear on the car in that short amount of time. My approach to the droop screws is to use them as a tuning tool and set any baseline droop using internal shock limiters.
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 05-07-2015, 08:10 PM   #701
jB
I don't think you will want to go with internal shock limiters, With as much as i adjust my droop per track and traction amount. . I cant see that being the best way to go. If you just wanna add 1mm your tearing apart those shocks. It does wear on the chassis but your chassis is made to wear.
Dont Hack Me is offline   Reply With Quote
Old 05-08-2015, 03:26 AM   #702
Jason's review of his new toy....
https://youtu.be/HBCsZiU3d44
dengor is offline   Reply With Quote
Old 05-08-2015, 03:28 AM   #703
Interview with Drake...
https://youtu.be/QeFQdSGHxm8
Old 05-08-2015, 06:17 AM   #704
Thanks for the input.
What is your approach to setting your droop amount based on the track and traction?
jB
Old 05-09-2015, 06:09 PM   #705
mebolson's Avatar
Trader Rating: 39 (100%+)
Looking for feedback:
VRP Shock pistons or RCShox pistons?
http://www.rcshox.com/mugen-mbx-2-st...or-the-r-16mm/
http://visionracingproducts.com/VRP-...-VRP5H13KY.htm
Support my small time online hobby shop
www.FactoryRCHobbies.com Custom Race Shirts and Pitmats Dealer for: Soar Seiki, T-Pro Racing Tires, Lipo Batteries, MIP Tools, VP-Pro Tools, and some other stuff
mebolson is offline   Reply With Quote
