Like Tree16Likes
Old 04-24-2015, 07:43 AM   #646
rcgod's Avatar
Trader Rating: 27 (100%+)
Originally Posted by rcracenut View Post
Ive had several mugens and losis. I would take the mugen anyday over a losi. I wish mugen made a 4x4sct. I would go to that in a heartbeat.
They do. It's called a Durango. Lol.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-25-2015, 08:47 AM   #647
TOO-TALL's Avatar
Started my build....so far very impressed with Quality and the manual is clear and easy to understand.....
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 04-25-2015, 08:52 AM   #648
TOO-TALL's Avatar
my front diff and pinion mesh is kinda tight....not bad.maybe it will have to break in?
www.skyski.com
www.foilforum.com
Old 04-25-2015, 10:59 PM   #649
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
You may need to shim it different from the manual. My x7 Eco shimmed exactly per manual, but the x7r Eco was different. I can't remember off the top of my head the difference, but it was 1 shim different.
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 04-25-2015, 11:59 PM   #650
TOO-TALL's Avatar
That's the problem....I have no shims in it now
Old 04-26-2015, 01:43 AM   #651
Intech 4wd Sct is closed team d sct
coombes is offline   Reply With Quote
Old 04-26-2015, 05:09 AM   #652
Mauve's Avatar
Dont worry about your mesh being a touch tight for starters with no shims, it will loosen up after 30 mins to and hours running, just check it after your first race meet. The car will loosen up and handle a bit better after 2 race meets as well. Just keep everything cleaned and maintained. I check mesh at every diff rebuild but have found to never need to change the shimming after the first 2 or 3 race meets.
Mauve is offline   Reply With Quote
Old 04-26-2015, 07:19 AM   #653
Trader Rating: 16 (100%+)
On my second build so far and I have yet to shim the front or rear diff. I wouldn't worry about it.
sclogger is offline   Reply With Quote
Old 04-26-2015, 02:07 PM   #654
TOO-TALL's Avatar
Thx I'm just gonna run it.it will be fine.
Old 04-26-2015, 02:22 PM   #655
Although to firm up some of the comments from above, on my first build I had no issues with my motor mount. On my second build I had to grind down the side facing the motor that the bracket slides into. It seems it was machined about a few thousands too big and hits the motor as you trying to set gear mesh.
Old 04-26-2015, 04:19 PM   #656
TOO-TALL's Avatar
I'm having the same problem....
Old 04-26-2015, 04:59 PM   #657
Chris Prelot's Avatar
yes you will need to run 1/2 gallon , generaly with mugen it's a typical breakin process
Team Mugen - Beat - AKA - Airtronics - ChpGrafix
Chris Prelot is offline   Reply With Quote
Old 04-26-2015, 06:14 PM   #658
I had this issue but it was actually caused by the screws that hold the front face of my castle motor on to the main body. The screws protruded out of their recess by about 1/32" and were making contact with the motor mount when I tried to slide it in. Backed each screw out a bit and hit the head with a grinder to shorten them up a bit and then it slid in fine.
Pretty weak on castle's part if you ask me.
mdchris is offline   Reply With Quote
Old 04-26-2015, 07:32 PM   #659
symmetricon's Avatar
I pit mine together with no shims in the diffs too. No problems after 2 weekends of running. ..
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is online now   Reply With Quote
Old 04-27-2015, 04:51 AM   #660
And this may have been mentioned by someone else but my second kit came with some replacement screws, probably to resolve the issue I had on the first build which the chassis screws where awfully tight, so tight that I snapped a 2.5mm hex bit in one which required a bit of finese to remove.
