Like Tree14Likes
Old 04-15-2015, 02:31 AM   #601
egobrkr's Avatar
Trader Rating: 26 (100%+)
Originally Posted by dengor View Post
Here attached another photo showing where it's hitting the diff case...
I drimel the diff case a little and set epa as normal
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-15-2015, 02:56 AM   #602
Guess it's a design flaw then
dengor is offline   Reply With Quote
Old 04-15-2015, 03:17 AM   #603
egobrkr's Avatar
If that's what you want call it. Sure
Old 04-15-2015, 04:05 AM   #604
jannedwr's Avatar
Originally Posted by TLR_TeknoRC View Post
cant understand what you trying to say in here, is it the simple answer is no? it wont fit?
It depends of what battery packs you use. I run 4200mah siftpack and tekins smaller indoor T8 and then my car is lower than the nitros, and then these nitro bodies will fit!
jannedwr is offline   Reply With Quote
Old 04-16-2015, 04:16 AM   #605
DaveG28's Avatar
Trader Rating: 60 (100%+)
Hi guys, couple of questions as I am considering switching to Mugen:
1. These come completely unassembled correct? Not prebuilt?
2. Is the body fit on the car fine with 4s batteries? I seem to remember the 6 being a tight squeeze?
3. What option parts are around... Things like Ali rear hubs etc?
Thanks!
DaveG28 is offline   Reply With Quote
Old 04-16-2015, 04:53 AM   #606
egobrkr's Avatar
Thanks!
These are kits not pre-built.
I have no body fitment issue with thunder power 5300mah or thunder power 4300mah 4s lipos.
There are a few option parts. I will say that in the 2 years I have ran mugen I have never used an option part other then spring, sway bars and pistons. The last couple months I have been playing with weight on the rear of the chassis with good success. The options I have told people are get different rates of springs and sway bars. Try some different shock pistons and oils. Also as of the last few months adding weight in front of the rear diff case on the chassis.
All the option part in my opinion are just that, option parts. They are not needed but for certain People may provide a tuning aspect they are look for. Check mugenracing.com for the different option parts that are available.
Old 04-16-2015, 06:16 AM   #607
What springs do you reccommend? I know a lot of people ran kyosho springs on other makes. Seems like kyosho was the go to spring.
MBX7R Eco--Tekin Gen 2 1900kv, RC10B5m Factory Lite on order, Hitec Lynx 4s
All sold: RC8.2E--Tekin RX8 1900kv, DEX408--Tekin RX8 1900kv, SC104x4--RX8 Pro4 4000kv, E-Revo Brushless, Hpi Sprint 2 Drift, Airtronics mt-4,
jjahn is offline   Reply With Quote
Old 04-16-2015, 06:24 AM   #608
egobrkr's Avatar
In my opinion kyosho springs didn't offer me anything that the factory springs didn't do and are double the price. For my home track I have 1 stiffer and 1 softer for springs. I do some traveling so I have 2 stiffer and 2 softer. It depends on you qnd where you are racing. If I'm racing the same track all the time I would have 1 stiffer and 1 softer then kit springs.
Old 04-17-2015, 02:12 AM   #609
TLR_TeknoRC's Avatar
my battery pack is SMC 6500mah 70C, does the pl phantom body for mbx7r fit?
because the mbx7r nitro body is also the body for mbx7r eco isn't?
TLR_TeknoRC is offline   Reply With Quote
Old 04-17-2015, 12:49 PM   #610
Waflet's Avatar
Trader Rating: 30 (100%+)
Originally Posted by hairymuffin View Post
the silver springs are 15mm..the black ones are 16mm,they both will rub,but the 16mm will be a little better
Hideeho
As typed, you are wrong. Silver springs use 1.5mm wire & black use 1.6mm wire. Both black & silver have the same inside diameter.
Also, some will say the black springs are stiffer than the silver. This is also wrong. They overlap in stiffness. Someone did some measurements a while back & had posted them. If any one still has those please repost (I have a new phone & lost that ).
Waflet is offline   Reply With Quote
Old 04-17-2015, 12:52 PM   #611
Waflet's Avatar
Originally Posted by S.TRIPP77 View Post
I like the thinner lipo but I can't see it make 8:00 heat race.
Hideeho
I have tried on in practice (4300mah protek) & got right around 15minutes before lipo cutoff (3.4v per cell) & put just under 4000mah back into it. 8 minutes should be no problem at all.
Old 04-17-2015, 12:57 PM   #612
Waflet's Avatar
Hello r1. Put some washers under the front body mount and a long screw. That might work?
Maybe do the same in the rear??
Hideeho
Be careful with this, it can raise the roof line above the line from front tower to the wing. The problem with this is the body will hit 1st in any roll over & be destroyed VERY quickly. I do not know that this is the case with phantom, but it is with the FTW night fox.
Old 04-17-2015, 01:04 PM   #613
Waflet's Avatar
Hideeho
The proline phantom nitro body can be squeezed into place on this chassis with your lipo, but it will not sit straight & will rub causing premature wear.
Was I clear enough that time?
Old 04-17-2015, 02:20 PM   #614
rcgod's Avatar
Trader Rating: 27 (100%+)
Mugen and Kyosho spring rates:
https://www.dropbox.com/sh/wulhhncyk...v6_QzwCxa?dl=0
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-17-2015, 06:51 PM   #615
Waflet's Avatar
Originally Posted by rcgod View Post
Hideho
Awesome! Thank you very much rcgod! I didn't have the kyosho list before, so that helps even more! When I tried them I thought the kyosho lt blues felt awfully soft.
I find it VERY interesting that the most common problem I hear about the stock mugen springs is they are too soft. Then I will see those same folks use kyosho lt blue springs all around that are even softer.
I guess it just goes to prove if you spend twice as much money on a part, it is always twice as good, especially if it says kyosho on it.
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
