Like Tree13Likes
Old 02-27-2015, 06:55 PM   #376
For those who are thinking about using the Xerun 150a on this buggy, see attached photos of mine. I was worried it would overhang a lot. But as you can see, its actually a good fit. Only a Little bit of overhang. I currently am not sensored, but the way I've set up the ESC means the sensor cable plug opens easily towards the motor for when I get a sensored motor.
Haven't decided where to stick the ESC switch yet. Any suggestions?
The official Mugen MBX7R Eco thread!-img-20150227-wa0005.jpg   The official Mugen MBX7R Eco thread!-img-20150227-wa0004.jpg   The official Mugen MBX7R Eco thread!-img-20150227-wa0003.jpg
dengor is offline   Reply With Quote
Old 03-01-2015, 07:53 AM   #377
Gpeters66's Avatar
Ran mine for the first time yesterday and was very pleased. I used mostly the box set up except on front camber. I ran one washer on top and no washers on bottom and to make up the loss in track width I ran +1mm hubs. I wasn't sure where to go completely with the camber for indoor so I started there and running 3 classes did not have too much time to play with it. Still playing around with some radio setup and hopefully get some more time on it next Saturday. What can I say It's a Mugen!! Looking forward to getting the MBX7TR soon to compliment it for outdoor season coming up!!
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 03-01-2015, 08:14 AM   #378
may i ask you something...
i will buy a mugen mbx5 converted to brushless.. and the listing doenst include a receiver box... could i buy the one from mbx7R eco?
will it fit?
and generally.. will the components of the mbx7r eco fit my model ?
AGAMA A215 - REDS R5T
Sponsors :Agama Racing Greece , REDS Engines Greece , Savox electronics Greece , Proline Racing tires
Special thanks to : Hobbytrip, SickPaint , ΙΜC models , Hobbytech.gr
fotispao is offline   Reply With Quote
Old 03-01-2015, 08:44 AM   #379
hairymuffin's Avatar
Trader Rating: 93 (100%+)
will it fit?
You will have to drill holes for it to fit..the only thing you can use from the7r is thr bearings and the diff parts,like the cases and gears,maybe even the towers,shocks.. If you tied to run the arms,you would need to change the alum hinge pin holders.. The motor mount should fit also..
hairymuffin is offline   Reply With Quote
Old 03-01-2015, 08:54 AM   #380
Originally Posted by wreckya View Post
I want to ship my painter some bodies and was wondering if u guy's could tell me if these bodies work with this buggy and if they clear batteries? And is it true that I will only need 4500 mAh packs to make 10 min mains? I don't want to have to run my packs on their sides so can someone give me battery dimensions that I can run flat and w these bodies? Thanks in advance. PL Phantom MBX7 pt# PRO3433-00, PL Bulldog gen3 MBX7 pt# PRO3406-00, JC Silencer MBX7 pt# JCO0253, JC Silencer MBX7 ECO pt# JCO0268
For a big outdoor track,you will be cutting it close with anything under 5000mah.. At the dnc i had to run 6500 cuz the track was big, and had 10min mains and plus you have to consider how fast and smooth you are..after a 7min qual we put 3800mah back in at dnc.. Big track tho... Ty ran shorty 4500s. Being smooth is critcal..go 5000mah good in between battery
Old 03-01-2015, 08:54 AM   #381
do you know if there is an electric mugen model which will fit mine 100%..
i was determined to buy this converted mpx5.. but i think i will have a hard time finding parts....
Old 03-01-2015, 09:07 AM   #382
You should be ok. If you got in a bind with parts,im sute the new arms might fit,but it will not be legal in terms of arm width...you can find the mbx6 pretty cheap..the arms should be fairly close to fitting..that would be your main concern..see if you can compare it to another arm..i would not worry much..if it were me, i would sell it and at least get a 6... If its out of reach, then just enjoy what u have..u can still find 5 parts so dont worry. I still have 5r shocks because the shafts were the same for my 6
Old 03-01-2015, 09:17 AM   #383
i found it used.. in a very good condition
only for 160$...
it is complete but without servo and remote controller..
with 2560kv turnigy motor 5s
and turnigy trackstar 150A 1/8 esc
Old 03-01-2015, 09:39 AM   #384
Davidka's Avatar
Trader Rating: 75 (100%+)
only for 160$...
It seems like a good deal but that's a really big motor for buggy. You'll probably change it shortly after you begin running. You are right to worry about parts availability, this car is nearly 10 years (and 2 generations) old. I'm told lots of the parts from Caster's buggy work so that might be a good resource. You should also be able to find decent used rollers for part donors at very low costs.
Good luck with it. The MBX-5r was always one of my favorite buggies.
Old 03-01-2015, 09:56 AM   #385
only for 160$...
thats a good deal,yea, with that motor you might be better off with a 3s battery...or you can sell that motor and get the smc 1900kv, its only $69!! Sell that other 5r you have for sure..The 6 is an awesome buggy!! my son ran it for years at the pro level up until a few months ago
Old 03-01-2015, 10:04 AM   #386
this motor i have with 4s will not work properly ?
the one i found used is the mpx5..
i dont have it yet... i will buy it in the next few days.
no money for new motor or new model kit right now
Old 03-01-2015, 10:07 AM   #387
have you been told what caster buggy model is the one that will fit?
Old 03-01-2015, 07:24 PM   #388
RumbleBeeAL's Avatar
Trader Rating: 55 (100%+)
I finally set some time aside to breakout my airbrush and acrylic paints for the stock MBX7R body...
Gordon
(It's pronounced Gor-don...)
Futaba 4PX | MBX7R Eco| MBX7R Nitro | MBX7T Nitro
RumbleBeeAL is offline   Reply With Quote
Old 03-03-2015, 03:41 AM   #389
Here's mine painted and ready to roll
Old 03-04-2015, 05:19 AM   #390
CALABASH1950's Avatar
Very nice
MBX7r Eco
CALABASH1950 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
