Like Tree16Likes
Old 02-01-2015, 05:09 AM   #271
idbdoug's Avatar
Trader Rating: 33 (100%+)
Hello
I am new to Mugen 1/8 electric, so i was wondering if the Mugen MBX6 eco will fit on the MBX7r eco??
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 02-01-2015, 06:28 AM   #272
statton iv's Avatar
Originally Posted by idbdoug View Post
Hello
idbdoug
u mean chassis swap?yes but the 6 front steering parts (ackerman,servo saver will have to be changed )they are different from the 7,and ur 6 droop screws will moved too if u use the 6 arms.
i was gonna do this ,but i was going to swap out the front tower,arms, and front shocks to the 7 parts. in the end i decided to only swap the front tower ,and front shocks......
Thank you to my 2017 sponsors:
Dialed rc, Mugen USA,Reds racing USA ,Rchqhobbies.com
Al Statton iv
210 849 7279
statton iv is offline   Reply With Quote
Old 02-01-2015, 04:17 PM   #273
My first post on this forum. Been lurking for quite a while. I raced a gold pan RC10 in the mid 1980's, But life got in the way of fun. Now I have my son at an age that we can play together. Bought him a short course truck a couple of months ago and we have been having a lot of fun together. I wanted a buggy for myself and been looking at 1/8th scale buggies. It really came down to two that I wanted. Tekno and the Mugen. Well today I ordered my MBX7R Eco from Tower should be here in a few days. Pretty good deal with all discounts applied came out to $464.00
Few questions. I plan to build is pretty much as box stock and take it from there. But are they any must have hopup parts that would be of substantial benefit?
What is a good starting gearing setup for a 1900KV motor?
What spare parts would you keep on hand?
Thanks,
Al
Al_T is offline   Reply With Quote
Old 02-02-2015, 10:52 AM   #274
Originally Posted by Ginther View Post
There is a list of new parts for the 7R on this page. I assume you could add those to a regular 7 and get a 7R.
Maybe download both manuals and compare parts lists to see what all looks different.
MBX7R Eco Specs
MBX7 Eco Specs
Ok thanks for the help
donnyc2015 is offline   Reply With Quote
Old 02-02-2015, 03:35 PM   #275
Trader Rating: 17 (100%+)
how does the stock body fit
bkuff-losi is offline   Reply With Quote
Old 02-02-2015, 05:30 PM   #276
Waflet's Avatar
Trader Rating: 30 (100%+)
Red face
Thanks,
Al
Hideeho
I don't see any parts as being "must install" for new kits. Some other brands have that issue, not mugen.
I am planning to add a few durability things, but that is it.
M2C chassis with both plates (my track can wear out a chassis in a season)
M2C servo saver arm (I like the steering linkages to be as stiff as possible)
M2C pillow ball bushings (because they are cheap & I was ordering anyway )
M2C shock top bushings (I have had issue with the stock braking, see next )
T-works spring steel shock stand offs (I have bent several of the aluminum ones )
Cf top plate (it's cool looking , if I didn't wreck so much I'd get the towers also , cf is always cool till you brake it )
I gear mine 14/46 for a mid size (95'x55') indoor track. I have gone as high as 18/46 for a large out door track.
For spares, the only things I have broken are:
Lower front arms
Lower shock mount
Shock shaft
Drive shaft
Wheel (all the previous was in one collision )
Spur gear (if you set your gear mesh right & remember to tighten you motor screws, you won't have this issue)
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 02-02-2015, 05:33 PM   #277
Waflet's Avatar
Hideeho
Over the chassis...
\sarcasmmodeoff
If you have a tall (150mm) lipo, it will sit on the lipo. If you have a shorter one (147mm) it clears everything fine.
Old 02-02-2015, 06:11 PM   #278
Thank you for the information. That is exactly what I was looking for.
Al
Originally Posted by Waflet View Post
Hideeho
Lower front arms
Lower shock mount
Shock shaft
Drive shaft
Old 02-02-2015, 07:39 PM   #279
idbdoug's Avatar
Hello
idbdoug
Talking about body only?..
idbdoug
www.r1wurks.com
Old 02-03-2015, 07:10 AM   #280
Waflet's Avatar
idbdoug
Hideeho
It will fit. It's not exact, but if you have an x6 it will work for the x7. If your buying new, get an x7.
Old 02-03-2015, 07:19 PM   #281
idbdoug's Avatar
Hideeho
www.r1wurks.com
Old 02-06-2015, 12:50 PM   #282
Does anyone know if the M2C front plate or brace from the nitro will fit on the 7R ECO, I have on laying around that I would like to use if possible.
diamonddawg21 is offline   Reply With Quote
Old 02-06-2015, 04:09 PM   #283
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Yes,its the same
hairymuffin is offline   Reply With Quote
Old 02-06-2015, 04:19 PM   #284
Thanks,
Al
Spares,front arms,upper and lower...front hubs,spur gears,i would get an steel spur..the plastic does last a long time,i only stripped a gear is when the motor mount moved..
The eco needs no upgrades,the pistons might be the only upgrade..the 5 hole pistons are good..out the box is good..takes some time to get it dialed out the box because the car needs to be ran in for about a good hour or two to break it in and thats it!!!
I put m2c chassis skid plates on mine..also i would chang the rear toe to 3
Old 02-06-2015, 09:15 PM   #285
Thanks for the info.
I received the kit yesterday. The quality of everything appears to be exceptional. It will be a couple of weeks before I can get started so I think I will order a few spares and and a few of the necessities before I get started on the build.
Thanks again.
