Like Tree14Likes
Old 01-21-2015, 07:33 PM   #226
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by teamtrackpants View Post
I too am about to build up a set of the rear shocks and am pretty much at a loss re: how to top up and bleed the shocks.
i've got an online manual for the Mugen MBX7 Eco - that i can't link to here yet cause i'm still new to RCTECH - but it's not really detailed for a new-be...
any instructional help is much appreciated!
and fyi: i'm building these to put on my 9yr old boy's Vaterra Glamis Uno - so apologies all around - more of a basher than a racer /: (:
This is how I bleed mine: make sure bladders are placed well into your cap, you screw cap on with bladder all way "hand tight" and then remove, this should push bladder into its fully seated position inside cap. Since these are bleeder style caps your bleeder hole shouldn't be blocked after doing this step.
---now fill shock oil to rim of shock body with shock shaft fully extended. Work shock shaft in and out, then let air bubbles escape with shock shaft still fully extended.
---I then screw shock cap on until you start getting shock oil coming out of bleeder hole. This usually is almost where the cap is fully hand tight. Once you reach this point, slowly start pushing the shock shaft in and you should see oil coming out of bleeder hole in shock cap. Once you reach desired rebound position, hand tighten shock cap rest of the way to fully tight and hopefully this technique gets you desired rebound
idbdoug
www.serpentamerica.com
www.r1wurks.com
www.falconsekido.com
idbdoug is offline   Reply With Quote
Old 01-21-2015, 07:33 PM   #227
CALABASH1950's Avatar
Originally Posted by cyba888 View Post
Almost done building the buggy everything went smoothly all the parts fit perfect very high quality kit. Only thing left are the shocks and electronics.
Any tips on building the shocks....the manual looks confusing. Let me know if this is correct. For example to get 50% rebound tighten the shock cap half way then push the shaft up half way for the oil to leak out, then fully tighten the cap?
https://www.youtube.com/watch?v=rixBJu93Qyw
MBX7r Eco
CALABASH1950 is offline   Reply With Quote
Old 01-21-2015, 07:51 PM   #228
egobrkr's Avatar
Trader Rating: 26 (100%+)
http://youtu.be/3XFDgpg3o3k
This is my video of how I build mugen shocks
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 01-21-2015, 10:43 PM   #229
thanks so much... i can fumble it from here!
teamtrackpants is offline   Reply With Quote
Old 01-22-2015, 02:45 AM   #230
cyba888's Avatar
awesome thanks guys!!
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 01-22-2015, 04:48 AM   #231
Does the MBX7 Eco bodies fit the MBX7R Eco?
MBX7 Eco, MBX7R Eco
SC10 FT, Tekin RS, Fantom Ion 3
Southern Cross Guest Ranch
www.southcross.com
Dmann33 is offline   Reply With Quote
Old 01-22-2015, 05:29 AM   #232
egobrkr's Avatar
Yes
Old 01-22-2015, 08:35 AM   #233
Gpeters66's Avatar
idbdoug
I have a problem with setting rebound the same on each shock and knowing how much rebound to use. Any help would be great. Thanks, Grant
Grant Peters....wave when you pass me please
Mugen MBX7r Eco, Mugen MBX7T Eco, Associated RC10 B5M Factory Lite, Associated RC10SC5M
Gpeters66 is offline   Reply With Quote
Old 01-22-2015, 08:45 AM   #234
cyba888's Avatar
Is it a must that we use 10 awg wires? Can I get away with 12 awg wires because I got a bunch lying around.
Futaba 4PX
Old 01-22-2015, 09:40 AM   #235
ok im kinda a newb. my first kit. is anyone else having an issue getting the screws into the diff housing? it seems like the holes are 2 small for the screws. ive only got 2 screws in one of the housings. maybe i just need more practice....
jomoe is offline   Reply With Quote
Old 01-22-2015, 10:00 AM   #236
A few wire gauge, connector questions.
MBX7r Eco
Old 01-22-2015, 11:15 AM   #237
HollywoodRC's Avatar
I have always used 12 awg wire with no problems.
HollywoodRC is offline   Reply With Quote
Old 01-22-2015, 12:04 PM   #238
i got em lol just took some patience
Old 01-22-2015, 03:06 PM   #239
Ginther's Avatar
+1
Everything from Deans to Tekin to cheap Turnigy 12ga.
Every connector from Deans, Traxxas, EC-5s, 4mm bullets...
No problems.
Ginther is offline   Reply With Quote
Old 01-22-2015, 03:13 PM   #240
Ginther's Avatar
One of these help tremendously with the build. Just go slow and dont strip out the threads as you cut them into the virgin plastic parts.
Dewalt Gyro Screwdriver
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
