Like Tree16Likes
Old 08-17-2017, 09:31 AM   #1981
hey
i have the m spec version of the buggy but the 4s battery way bigger than the tray and has stuff all room to fit the esc and battery.
i have had to velcro the battery to the tray seems a pain that its designed for 2s battery anyone found a soulotion?
bardynt is offline   Reply With Quote
Old 08-17-2017, 09:35 AM   #1982
EbbTide's Avatar
Trader Rating: 34 (100%+)
Originally Posted by bardynt View Post
hey
Which 4s lipo are you using? Last MBX I used had the same tray and my hard case 4s lipos fit fine. I believe they were Gens Ace 5000mah 4s batts at the time.
::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is offline   Reply With Quote
Old 08-17-2017, 09:41 AM   #1983
hey
Even the SMC 6700 4S Hardcase are fitting perfectly fine. Not sure what the problem is.
mlax is offline   Reply With Quote
Old 08-17-2017, 11:36 AM   #1984
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by nmadsen View Post
Hey guys a few questions that came up while building my buggy.
1. It seemed strange that there was no grease called for between the large conical gear and the bevel gear inside the diff. case. Do you guys typically lube this in any way?
2. On the other hand, I thought it was strange that the instructions did call for grease to be applied to the ends of the CVD shafts that contact the differential outdrives. On my first drive those immediately got caked with clay. Seems to me that they wear caused by that caked on buildup would be bad? What do you think?
3. Do you guys run the shock boots on your car? They seem to be restrictive and could also trap dirt/grime that could lead to premature wear.
Thanks for your help!
1. We do grease ours.
2. We have found that applying grease to these overwhelmingly reduces the wear on the outdrives themselves. Good outdrives means you only have to replace the driveshaft pins every so often.
3. We always run the boots. Without them, you will get more dirt in your shock bodies through the bottom seals.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 08-17-2017, 12:27 PM   #1985
Can mugen and associated gearboxes bolt onto each other's chassis? Are the bolt patterns the same?
juskruzin is offline   Reply With Quote
Old 08-17-2017, 10:46 PM   #1986
rubezzz's Avatar
anyone know what the benefit is of running a clutch bell instead of the standard pinions?? Seen a few running this setup
Ruben Martins
Futaba 4PXR / MBX7R Eco / MBX7R Nitro / MBX7TR Nitro
Thank You for your Support: RYPER HOBBIES | AKA
rubezzz is offline   Reply With Quote
Old 08-18-2017, 04:08 AM   #1987
jmackani's Avatar
It smooths out the torque from the electric motors
Old 08-18-2017, 04:23 AM   #1988
rubezzz's Avatar
Where can I find a kit for it?
Old 08-18-2017, 11:38 AM   #1989
jmackani's Avatar
Good luck. I think people were using a tekno conversion or making their own through modifications. I recall you need to search on electroclutch.
1/8 IC Fan likes this.
Old 08-18-2017, 11:42 AM   #1990
Good luck. Probably be better to grab the Losi version, and see if it needs any mods.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 08-18-2017, 02:16 PM   #1991
werner sline's Avatar
werner's bunch of 1/8 RC freestyle tricks NEW video : werner's home made rigid axle monster truck : bashing, jumping, crashing, welding, hitting the driver, double flip !
check it out : https://www.youtube.com/watch?v=WpAlaTrpNa0
werner sline is offline   Reply With Quote
Old 08-18-2017, 07:39 PM   #1992
Trader Rating: 16 (100%+)
Nope.
MX304 is offline   Reply With Quote
Old 08-18-2017, 08:22 PM   #1993
1/8 IC Fan's Avatar
Trader Rating: 47 (100%+)
No, Associated did not clone to 100%... 😂😂😂
W.E.D.Jim and ezlight like this.
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 08-20-2017, 04:12 AM   #1994
hey
I had the same problem when i first built my car, didn't realise the batteries i ordered were a full inch longer then most others.
Basically i cut off the vertical sections from front corner and back edge of the battery tray, did the same at the front of the esc tray and then glued the battery tray and esc tray together.
That let the battery overlap onto the esc tray slightly but still left enough room for the esc.
Sully is offline   Reply With Quote
Old 08-21-2017, 09:51 AM   #1995
1/8 IC Fan's Avatar
what 4s batteries are you guys running? For flight models? I have run Trinity, Orion, LRP, and Finally SMC... no issues.
