Like Tree16Likes
Old 06-20-2016, 10:17 AM   #1636
mrnizzles's Avatar
OK! I bought all the stuff from Amain, thanks to the nice Fathers Day weekend, figured I should treat myself, but the kids mostly drive.. errr crash my cars anyway
mrnizzles is offline   Reply With Quote
Old 06-24-2016, 01:29 PM   #1637
Originally Posted by Photocycler View Post
sounds like the SMC 6500 is the way to go.
How did you fit a 6500? I have a SMC 5500 and does not fit without tilting the body.
eortizr is offline   Reply With Quote
Old 06-25-2016, 04:46 PM   #1638
rp180sx's Avatar
Originally Posted by RCmenace View Post
NIce that looks good man
Thank you very much
rp180sx is offline   Reply With Quote
Old 06-28-2016, 12:45 PM   #1639
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
what currently is a setup that is considered a good starting point for rough extremely loose tracks that have big jumps?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 07-01-2016, 11:29 AM   #1640
mxnickj's Avatar
Trader Rating: 51 (100%+)
here is a video of my 7Reco from last Friday at LCRC. I started 7th and worked up to 5th at the end. Running the Drake standard setup on AKA Gridirons with Tekin RX8gen2 and 2050kv motor.
https://www.youtube.com/watch?v=6nGGWQTrgL0
Nick Johnson
AE SC5M - AE B6D
Bumps & Jumps RC - LCRC
mxnickj is offline   Reply With Quote
Old 07-01-2016, 05:48 PM   #1641
Capelracer's Avatar
Originally Posted by rp180sx View Post
Here you go. My venom 4s are 139x47x49. I lay them on there side and the body has clearance. My smc 4s batteries are a little taller and just barely touch the body
Random question - where did you get the flame mask from??
Capelracer is offline   Reply With Quote
Old 07-01-2016, 06:12 PM   #1642
rp180sx's Avatar
Parma 10839 1/10 Long Lick Flames Paint Mask
I got the mask kit on ebay
Old 07-03-2016, 05:10 PM   #1643
wittyname's Avatar
For those who have the eco and nitro car , how similar are their driving characteristics ? In my experience the e car and nitro are always a bit different , same with the mbx7r ? What's different in your opinion ?
wittyname is offline   Reply With Quote
Old 07-10-2016, 01:10 PM   #1644
Does anyone have any insight on springs for bashing? My MBX7R eco is probably 1.5 lbs heavier than most setups and the hardest springs I have aren't enough. I use a short course body, longer can motor, and heavier batteries. I looked into custom making springs at leesprings, but it's more than I'm willing to pay. Most websites require bulk or over a certain $ amount. I'm estimating my buggy weighs about 9 lbs, so I'm looking for 9 lb/in springs or slightly softer/harder.
RepEvox is offline   Reply With Quote
Old 07-10-2016, 03:39 PM   #1645
werner sline's Avatar
you may consider to change the connecting point of the shocks to the lower arms with a little piece of aluminium, just like the kyosho psycho cruiser ( check this picture : http://www.the-kyosho-store.com/uplo...564_grande.jpg )
if you do this + change the shocks towers for the mbx7T ones, you won't need to put harder springs ( but you will loose some suspension travel )
werner's bunch of 1/8 RC freestyle tricks NEW video : werner's home made rigid axle monster truck : bashing, jumping, crashing, welding, hitting the driver, double flip !
check it out : https://www.youtube.com/watch?v=WpAlaTrpNa0
werner sline is offline   Reply With Quote
Old 07-10-2016, 08:15 PM   #1646
I don't know if I want to change the suspension geometry. I just want the ride height of my car to be higher. The only way I can do that is to attach clips that don't really fit the big bores.
Old 07-10-2016, 10:09 PM   #1647
you may use a aluminium tube from the hardware store to preload the stock spring a bit more
Old 07-10-2016, 11:04 PM   #1648
They drive very similar, however the nitro buggy feels more nimble overall. Turns a little better and more lively in the air as well.
JJG690 is offline   Reply With Quote
Old 07-11-2016, 09:30 AM   #1649
MeasuresMicrons's Avatar
I've decided to throw in the towel on my TLR 4.0 and bought a new MBX7R Eco today. I'm seriously considering going with Hobbywings 2250kv because the my Orion VST2 1900v has way to much low end...anyone run the HW 2250?
MeasuresMicrons is offline   Reply With Quote
Old 07-11-2016, 03:28 PM   #1650
I have a Hobbywing XR8 plus and a HW 2250 motor it has more than enough power through its whole rpm range, I don't really like the bullet connectors that the motor has, I would look into HW new brushless motors that have solder tabs on the motor.
Bull_Dog is offline   Reply With Quote
