Like Tree16Likes
Old 05-24-2016, 06:10 AM   #1606
mxnickj's Avatar
Trader Rating: 51 (100%+)
Originally Posted by Schuie Driver View Post
Anyone know if this wrap can be purchased somewhere? I think it looks awesome.
Another question on 4S battery packs. Did I read somewhere in this thread that the 5000 mah SMC packs push the stock body up?
Looks like an UpgradeRC wrap to me
mxnickj is offline   Reply With Quote
Old 05-24-2016, 06:28 AM   #1607
mxnickj's Avatar
Originally Posted by smoke229 View Post
the weight thing, i have two different brands of the chassis weights in my toolbox and thought about getting the heavier pillow balls also, but 2 race weekends in with my eco and i just dont think it needs them. i will try them eventually or maybe i havent been to a track that requires them, not to mention im pretty weak at setup but my buggy is flying around the track now.
the body/battery thing - im very unhappy with fitment. my stock eco body barely fits with 6500 smc pack, and only with the wires facing the rear. the used (i think proline predator) body that came with my eco sits about half an inch high on the battery side when using bigger 4s packs.
the rest of the buggy - i love it!
On my MBX6 I ran the heavier steel pillow balls on the bottom only and it made a noticeable difference but never felt the need on my 7 or 7R.
As far as the battery and body, a little trick I picked up, put a small spacer and longer screw under the front body mount to gain another few mm clearance for the battery.
Old 05-26-2016, 04:53 PM   #1608
RCRjuanabbe's Avatar
I tried to scan through and did not find any comparison to 6-Eco? is there a big difference?
RCRjuanabbe is offline   Reply With Quote
Old 05-26-2016, 06:21 PM   #1609
werner sline's Avatar
yes, mugen made the mbx7 more agressiv to drive and better in tight turns. they mostly put the weight more forward
werner's bunch of 1/8 RC freestyle tricks NEW video : werner's home made rigid axle monster truck : bashing, jumping, crashing, welding, hitting the driver, double flip !
check it out : https://www.youtube.com/watch?v=WpAlaTrpNa0
werner sline is offline   Reply With Quote
Old 05-27-2016, 09:38 AM   #1610
Question for you Mugen experts. I'm thinking about getting this buggy. I feel good about it after all the videos I've watched and things I've read. How often does Mugen make new models. I see this one cam out 12/14. Think there is going to be a new one this year?
Thank you!
superbikemike is offline   Reply With Quote
Old 05-27-2016, 01:28 PM   #1611
nitro2be's Avatar
Originally Posted by BermyDomRepRC View Post
Has anybody tried the rear under drive in the Eco ?
yes works great? I believe only way to run the car.
Hb D413 Orion 5.5, associated rc12r5.2 4T LRP .Lucky Easy E..
nitro2be is offline   Reply With Quote
Old 05-30-2016, 12:53 PM   #1612
Trader Rating: 120 (100%+)
With running the rear under drive do you need to go up in weight with the diff fluid?
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 05-30-2016, 09:18 PM   #1613
Trader Rating: 65 (100%+)
It didn't work for me. I think if you change both front and rear the change in gear ratio might be useful. Not for me though. If it works for you post about what you liked and how it worked better with setup info.
Thunder Trail is offline   Reply With Quote
Old 06-07-2016, 12:41 PM   #1614
so when is the MBX8 coming out?
eortizr is offline   Reply With Quote
Old 06-08-2016, 06:51 AM   #1615
Capelracer's Avatar
Got a new offroad track starting up in my area & they're going to run a "superlight" class - 1/8E buggies with 2s batteries & 550 motors (it's a small track!!!).
Any recommendations on kv for the motor and gearing??
Capelracer is offline   Reply With Quote
Old 06-08-2016, 08:08 AM   #1616
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Nope just run the 42/12 rear.. 4k in the rear.... We also dont run anything over 7k in the center.. First add more toe to the rear before you buy those gears.. Stock is 2.75 rear toe with dot in the middle of the pill insert.. Install the insert with the dot towards the "outside" of the car.. If you need more traction, ad 5k rear.. Cheap fixes
hairymuffin is offline   Reply With Quote
Old 06-08-2016, 05:02 PM   #1617
nitro2be's Avatar
http://www.neobuggy.net/
Wahooo.
Old 06-08-2016, 06:57 PM   #1618
mbx8 : I will be very interested to see what they improve ! probably a bit more suspension travel, a even more narrow setup, a bit more weight forward and let's hope : STRONGER front arms !
by the way, I let a message to mugen japan about my videos : they didn't reply. it's ok, their customers are racers, not bashers like me. Adam drake did reply to me on youtube, that is much appreciated ! they pick up the right guy to promote mugen !
Old 06-08-2016, 10:39 PM   #1619
Default Mbx7r black springs
Hey what is with the black springs I see everyone using??? Is it 10.25 rear and 9.75 front. And what piston and oils do people use in Australia.
Jdmufc is offline   Reply With Quote
Old 06-09-2016, 04:07 AM   #1620
Capelracer's Avatar
Originally Posted by nitro2be View Post
http://www.neobuggy.net/2016/06/08/m...x8-on-the-way/
