Like Tree16Likes
Old 05-05-2016, 02:23 PM   #1561
werner sline's Avatar
I would recommend the 5 holes pistons if your track had a lot of jumps. the 8 hole stock one don't give enough pack
werner's bunch of 1/8 RC freestyle tricks NEW video : werner's home made rigid axle monster truck : bashing, jumping, crashing, welding, hitting the driver, double flip !
check it out : https://www.youtube.com/watch?v=WpAlaTrpNa0
werner sline is online now   Reply With Quote
Old 05-06-2016, 02:24 AM   #1562
my mbx7r eco's jump tricktionary :
https://www.youtube.com/channel/UCtL...fmTwQ5hFmbGx1g
Old 05-06-2016, 04:31 AM   #1563
Thumbs up
Originally Posted by werner sline View Post
great video!
quimico is offline   Reply With Quote
Old 05-06-2016, 05:32 AM   #1564
thanks you, I appreciate
some may think that the mugen is not agile, but this proves it can whip !
Old 05-06-2016, 08:26 AM   #1565
Most of the local guys are suggesting stock silver springs and 5 hole. My biggest problem with the 15mm was to get the front to not slap the chassis on a jump was to make it so springy the car would not drive well. So I just dealt with a little slap. I am hoping I can fix this with the 16mm. I'm didn't realize they took the same springs until yesterday. I almost ordered some new springs and I already have a lot of springs already.
Watkins4x is offline   Reply With Quote
Old 05-06-2016, 08:29 AM   #1566
It's gonna be really interesting to see how the universals hold up to electric power source.
Daniel_ is offline   Reply With Quote
Old 05-06-2016, 02:49 PM   #1567
Hella SICK video!! Well done!
McKeownJ is offline   Reply With Quote
Old 05-06-2016, 03:40 PM   #1568
thank you
next vid will show a bunch of crashes ! modified-mugen durability test !
Old 05-09-2016, 06:16 PM   #1569
Trader Rating: 30 (100%+)
forgive me for not searching but does the shock towers, rear stand ups, and under drive option gears interchange from the 7r to the 7r eco? as in someone has done it compared to just searching part numbers?
smoke229 is offline   Reply With Quote
Old 05-09-2016, 07:47 PM   #1570
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Same parts
hairymuffin is offline   Reply With Quote
Old 05-10-2016, 12:56 PM   #1571
Default Camber Adjustment
Hi Guys, I was wondering why I have such a big space in the arm when I set my camber to -2 deg? I have looked at other setups and I don't see the same gap.
What am I missing?
Italo2275 is offline   Reply With Quote
Old 05-10-2016, 01:20 PM   #1572
CAR
CAR's Avatar
What am I missing?
That's about right for -2 camber stock setting is about -4.5 screwed all the way in....also two top washers will give you -2.
CAR is offline   Reply With Quote
Old 05-10-2016, 01:48 PM   #1573
Originally Posted by ddick View Post
hi i am new at E buggy. Only drive nitro buggy´s and have some questions.
The only thing i knew is that it will be a Mugen 7R eco
i not know which combo to buy.
1) Hobbywing Xerun XR8, Tekin 1900 or TORO X8S 2150
What the difference of the tekin and the Toro ? not mean the company
2) Tekin Gen 2 ESC and Tekin 1900
3) battery 4 s or 2 x 2s
1) HobbyWing works just as fine, but Tekin 1900kv is an excellent motor.
2) Tekin is good, but so is also HW
3) 4S battery is less hassle
my 2c...
Kyosho MP9E TKI4 | Mugen MBX6 Tekno V4
stigno is offline   Reply With Quote
Old 05-10-2016, 06:21 PM   #1574
Speed Freak RC's Avatar
Well done.
Speed Freak RC is offline   Reply With Quote
Old 05-11-2016, 07:23 AM   #1575
Having a weird issue with my steering and want to see what people think. I'm running the sidewinder system so was running with the esc bec before which is 5.5v. Steering was pretty weak and slow with my hitech 7954sh.
Last night I wired up a castle 10a bec to it set at 7.4v and now the speed of the servo is much better, however it's getting much more torque turning left (pushing the linkage) than turning right (pulling the linkage).
When pushing the linkage if I hold the wheel straight the servo will completely overpower the servo saver and rotate the top half about 30 degrees. However when pulling the linkage if I hold the wheel straight it will not overpower the servo saver at all, maybe a couple degrees.
Anybody else experience this? Seems to me that I should have the same steering torque in both directions. Haven't swapped out the servo yet to check my spare.
mdchris is offline   Reply With Quote
