Like Tree13Likes
Old 03-28-2016, 02:38 PM   #1516
werner sline's Avatar
what strong aftermarket body do you guys use ? it should have a maximum lipo clearance
werner's bunch of 1/8 RC freestyle tricks NEW video : TRUGGY tricktionary, part 2: 14 tricks
check it out : https://www.youtube.com/watch?v=5PVrXfs5TG8 6s power !
werner sline is offline   Reply With Quote
Old 03-28-2016, 06:14 PM   #1517
Trader Rating: 120 (100%+)
Are any of you running the VRP pistons and if so can you give me some feedback please. Thanks
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 03-28-2016, 06:41 PM   #1518
The Leadfinger Racing Assassin body is amazing. Covers a 4s lipo with no issues and the body is unbelievably durable.
450rdawg is offline   Reply With Quote
Old 03-28-2016, 06:47 PM   #1519
interesting ! this one : http://shop.leadfingerrc.com/Assassi...LFR100004e.htm
seems that you have to order it directly
Old 03-29-2016, 05:49 AM   #1520
Trader Rating: 74 (100%+)
Looking for suggestions on pistons with more pack. The stock pistons don't seem to have enough pack as my car wants to bottom out off of any medium to large sized jumps. I went up to almost 650 cst oil which helps (but doesn't eliminate) the bottoming, but then the rebound became too slow.
I tried the 5x1.35 pistons and to me it felt like the car's handling became inconsistent. So now I'm on the hunt for something different to try.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 03-29-2016, 06:12 AM   #1521
Default upgrade to the 7r eco
Hay Guys,
Just wondering if it would be worth upgrading A MBX6 eco to the 7R specs??
wolfe99 is offline   Reply With Quote
Old 03-29-2016, 11:05 AM   #1522
1/8 IC Fan's Avatar
Trader Rating: 45 (100%+)
Originally Posted by wolfe99 View Post
Hay Guys,
Its much easier to convert a MBX7 to R spec, than trying to piece an X6/X7 hybrid together. There are a lot more differences between the two, and you would need to know specifically what will work and what won't. Plus depending on how much you want to spend, and later on if you want to sell it, you may not see any of that cost returned to you.
1/8 IC Fan is offline   Reply With Quote
Old 03-29-2016, 11:13 AM   #1523
rider313's Avatar
Trader Rating: 94 (100%+)
I am using Vision Racing Products 5x1.5 pistons with a 400cst range of oils and the car is planted. I highly recommend VRP pistons in a ebuggy so you can have enough pack for over jumping but keeping your rebound consistent.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 03-29-2016, 02:18 PM   #1524
VRP pistons :
https://www.youtube.com/watch?v=YeEAw_nlCjs
Old 03-29-2016, 06:55 PM   #1525
Has anyone tried to retrofit the ball bearing steering rack out of the rc8b3e into the mbx7r eco buggy?
Tekno RC, AKA Products, LFR
JJG690 is offline   Reply With Quote
Old 03-30-2016, 06:30 AM   #1526
Hey Rider313 what springs are you using with the vrp pistons?
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
Old 03-30-2016, 06:59 AM   #1527
I've personally never tried VRP pistons so can't speak to that. I use Kyosho 6x1.3 pistons. 40f/35r for oil and Mugen 9.0x1.6 springs front and 10.25x1.6 springs rear. Honestly, I don't think you'll ever completely eliminate bottoming out at times and still keep a good piston package. It just happens. The package I mentioned above is a solid one though. Just my $.02.
Old 03-30-2016, 07:05 AM   #1528
1/8 IC Fan's Avatar
I think that the Servo Saver Arm offset and the spacing will not work as the servo as mounted in the MBX7 Buggies is different (the offset angle is greater in the RC8B3 series). Plus the Ackerman plate needs to be mounted on the top instead of below. Perhaps maybe someone has toyed with it already, yet I have not had much problem out of the stock Mugen one, on either Buggy or Truggy.
Old 03-30-2016, 07:12 AM   #1529
rider313's Avatar
silver 1.5 7.75 front and rear.
Dan Williams
MNRC Chairman
Old 04-01-2016, 10:20 AM   #1530
Tim W.'s Avatar
What servo horn is everyone using? The Mugen Racing Aluminum Servo Horn Set MUGB0429?
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
