Like Tree16Likes
Old 12-29-2014, 06:15 PM   #106
egobrkr's Avatar
Trader Rating: 26 (100%+)
Looks good. I just ordered some of the parts to start to convert my x7eco to a x7R eco
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 12-29-2014, 09:56 PM   #107
gixxerman's Avatar
Originally Posted by Bburns View Post
Just about done.
Your rear camber links are on backwards.....
gixxerman is offline   Reply With Quote
Old 12-29-2014, 10:51 PM   #108
Bburns's Avatar
Yep, already fixed. Was in a hurry to get it done before I left for work. When I got home. I finished it up and went to set camber and realized what I did. I usual have the lines in the turnbuckle on the left side. Just a quick flip and good to go. Gonna try and get one practice in before the mid west champs. But I'll have my mbx7 Eco with me to.
Mugen Seiki racing - Austintown Hobby Shop
Bburns is offline   Reply With Quote
Old 12-30-2014, 12:27 PM   #109
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Originally Posted by statton iv View Post
yep,im only upgrading my shocks and tower.
the rest when the buggy is worn out .
same here,in fact,my son still runs the x6 with 7 diffs,x7 motor mount..the car is super dialed..all its lacking now is the 7r shock setup..my son has won some big races here in socal over some big name drivers...nitro is something different
hairymuffin is offline   Reply With Quote
Old 12-30-2014, 11:29 PM   #110
debocurl5.0's Avatar
got mine today and started the build....going well so fare hope to finish tomorrow.
debocurl5.0 is offline   Reply With Quote
Old 12-31-2014, 10:44 AM   #111
spider882009's Avatar
Trader Rating: 7 (89%+)
Can't wait to start building mine after the new year!!!
Sponsored by: Mugen|Proline|LFR|Carpy's
Chad Segner
spider882009 is offline   Reply With Quote
Old 12-31-2014, 11:40 AM   #112
CALABASH1950's Avatar
To those building, would love to see pictures as you build yours.
CALABASH1950 is offline   Reply With Quote
Old 12-31-2014, 05:53 PM   #113
Waflet's Avatar
Trader Rating: 30 (100%+)
Originally Posted by wreckya View Post
I'm torn between this buggy and the xb8e, u say the xray is more more balanced. Can u help in any way with my decision? Unfortunately I don't have the option of driving either buggy before I order and have never owned one from either company. I would greatly appreciate any input u guys could give me. Large indoor hard packed dirt track medium traction. I care more about a better handling and jumping buggy then I do in longevity as I don't crash and break often.
Hideeho
I got to drive the xb8e last night. As said before, it felt almost exactly like my x7eco. The owner had it set up very similar to my x7eco setup, only more so. He had more on power rotation than my setup, & more off power turn in. I found his on power rotation too much, but I did like his better turn in. Next time I'm at the track I'll try moving the Ackerman to the back hole & see if I like that.
P.s. This is the same guy that used to drive a kyosho & was faster with my car. He also had several hundred dollars of hop up parts to get the handling that I have with no hop ups (other than durability mods such as the mugen cf top plate).
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 12-31-2014, 05:57 PM   #114
Waflet's Avatar
Hideeho
Does anyone know when, or if, M2C is going to come out with stuff (chassis & Pistons) for the x7r Eco? I currently run their chassis & Pistons & would love to continue with the x7r Eco.
Old 12-31-2014, 09:17 PM   #115
so what do I need to make my 7 eco in to a 7r eco any ne can tell me
TheMuffinman is offline   Reply With Quote
Old 12-31-2014, 09:29 PM   #116
Waflet's Avatar
Originally Posted by egobrkr View Post
Mugen just announced that the Mbx7R eco will be released in December! Can't wait!
E2016 - MBX7R ECO*1/8 electric Buggy Kit (off road):Mugen concentrated on the making the suspension on the MBX7R ECO even better with new 16mm bodied front and rear racing shocks. These bigger bore shocks will improves stability in bumps which will handle all the power that this electric buggy will produce.**The 7R ECO chassis has been changed to increase strength and give the ECO buggy a better feeling on all indoor and outdoor racing surfaces.The 7R ECO has a re-designed front hub carrier in which the position of the front axle has been changed to a trailing axle position. This new front hub carrier in conjunction with a new designed steering ackerman plate will greatly improve steering input of the 7R ECO.* The front upper suspension arms have been shortened 1.6mm to allow for more camber adjustability.* The front and rear drive train (diffs to wheels) have been changed and improved with new designed universal drive shafts.* These drive shafts will greatly improve the feel of the ECO buggy on bumpy surfaces.* The use of the universals will make the overall drive train much smoother and will spin with less friction.* The new wing mounts will allow the wing to be moved closer to the shock tower and will increase rear traction and jumping abilities.The MBX7R ECO is equipped with a specially designed battery tray which will accept either 2-2 cell LiPo batteries in a staggered mounting position for optimum weight distribution or a single 4 cell battery location...the choice is yours!* A specially designed motor mount which has been beefed up so you can run bigger and fast electric motors without losing gear mesh or without the flex which causes motor or mount breakages.* There is a heavy duty sliding motor mount that is anchored down with 4mm screws for extra strength.
All these new improvements on the MBX7R ECO will make the ultimate 1/8 electric buggy.* The 7R ECO will be available in December 2014.
MBX7R ECO*Features:
- Heavy duty aluminum motor mount housing A- Heavy duty aluminum motor mount B- Lightweight conical gears- Straight cut conical and ring differential gears- Specially designed front upper and rear lower suspension arms, front hub carriers,*** rear suspension arms and hub carriers- Fully adjustable steering with new geometry, servo saver and ackerman plate- Front/Rear 16mm hard anodized threaded shocks with 3.5mm shock shafts and slim rubber*** boots- 3mm A7075 hard anodized chassis- 5mm A7075 aluminum front shock tower- 4mm A7075 aluminum rear shock tower- 5mm A7075 aluminum lower suspension mounts for optimized geometry- Stylish cab forward body- Re-designed wing mount and high-down force wing
New parts on the MBX7R ECO
-E2129 Front UprightA new designed front hub carrier that incorporates the front universal to be in a trailing axle position.* A new universal (E2218) is used with this hub and it uses an 8mm x 16mm ball bearing.-E2131 Rear UprightThe rear hub carrier has been modified to allow for use of an 8mm x 16mm ball bear which is required for the new (E2219) universal shaft. This hub carrier will also allow the use of the 15mm x 21mm ball bearing too. This hub carrier can be used for either the MBX7R or MBX7.-E2132 Front Upper ArmThe front upper suspension arm has been shorten 1.6mm. This will allow the use of the E0161 spacer between the pillar ball and the upper arm. This will allow for the same camber on each side of the buggy.-E2133 Rear Lower ArmThe suspension arm has been modified to allow for clearance so the new E2219 universal doesn’t rub the arm. This arm will work on either the MBX7R*ECO*or MBX7buggy.-E2218 Front Universal ShaftA new design universal drive shaft set for the front of the MBX7R*ECO.*The E2129 front upright must be used with these universals as they require an 8mm x 16mm ball bearing. The length of the drive shaft is 91.5mm.-E2219 Rear Universal ShaftA new design universal drive shaft set for the rear of the MBX7R*ECO. The E2131rear*upright must be used with these universals as they require an 8mm x 16mm ball bearing. The length of the drive shaft is 89.5mm.-E2314 Steering PlateThe new steering ackerman plate has 5 adjustment holes for maximum steering adjustability.-E2408 Wing StayA new wing mount that can move the wing forward maximum 10.5mm to improve traction and overall feeling of the buggy.-E2409 Stone GuardThe sides of the stone guard are changed to fit the new chassis.-E2411 ChassisThe side angle of the chassis has been changed to increase chassis strength. This will allow for a better feeling on all surfaces.-E2528 Front 16mm Shock Set-E2529 Rear 16mm Shock SetNew 16mm Front/Rear shocks which will greatly improve stability in bumps and jumps
Differentials Oils:Front - 7,000 wt Oil (B0323)
Center - 7,000 wt Oil (B0323)
Rear - 3,000 wt Oil (B0321)Shocks, Springs, and Sway Bars:Front:
550 wt Oil (B0333) / φ1.5 L75/7.75T Spring (E0573) / φ1.3 8H Piston (E2525) / φ2.3mm (E0164)
Rear:
550 wt Oil (B0333) / φ1.5 L86/8.0T Spring (E0577) / φ1.3 8H Piston (E2525) / φ2.7mm (E0168)
Hideeh
1st page, 1st entry, new parts paragraph
Old 12-31-2014, 11:54 PM   #117
Finished my build. Only ran Rc8.2e Associated until now. We will see.
ramctd is offline   Reply With Quote
Old 12-31-2014, 11:58 PM   #118
Got mine built whent well running some test laps in morning
Old 01-01-2015, 12:08 AM   #119
Ramctd: Nice build-clean wiring-gorgeous body. I would be interested in your review after you run it awhile. Thanks for the pics. Again, nice job!
MBX7r Eco
Old 01-01-2015, 01:24 AM   #120
CobraSVT's Avatar
Thumbs up
My MBX7R and the newly assembled MBX7R Eco....
Mugen MBX7R Eco thread!-20141230_211933.jpg   Mugen MBX7R Eco thread!-20141230_211940.jpg
Run, Jump, Make Noise but do not SIN
CobraSVT is offline   Reply With Quote
