Like Tree16Likes
Old 06-28-2015, 06:31 PM   #856
easye's Avatar
Im new to the mugen. What part numbers are need to run a under driver rear diff. Thanks
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 06-28-2015, 08:52 PM   #857
Originally Posted by werner sline View Post
ok thanks, I think tekno just need some time to get to the perfect buggy. mugen had more time to make their mbx series evolve and up to date.
what about the suspension travel ? it seems to me that the eb48 has bigger shocks and more suspension travel, am I wrong ?
Well mbx7r rear are longer then teknos by a small amount, maybe a 1mm or less. It will also be dependent on the shock tower them selves, shock location on the arms. Taller towers compared arm droop. Over all suspension travel I don't know who has the most. Honestly that really doesn't mean anything. Just because you have the most doesn't mean its the best or easiest to drive. Another example is Tekno eb48.3 It has truggy shocks on it. the length of the front shock are unbelievably long, but they mount up all the way out at the wheels, so you would need longer/bigger (total fluid volume) to get the same amount of travel. just to make it on par with every other buggy on the market.
I never run max droop. Only time i would run max droop is if someone was very new to it. More suspension travel will help on landing but its not as reactive. Easier to drive if your new, better to learn on, more forgiving but not faster. Honestly it's all about geometry of the buggy
Dont Hack Me is offline   Reply With Quote
Old 06-28-2015, 10:16 PM   #858
werner sline's Avatar
thanks for the answer
werner sline is offline   Reply With Quote
Old 06-30-2015, 08:36 AM   #859
cyba888's Avatar
Need some help on front camber adjustment. I haven't ran the buggy for a few months and forgot how to adjust front camber. Last time I remember was to use washers to adjust camber but this time I am not sure why one side is way off. With same washers on both sides my front left camber reads 1.5 and front right reads 3.0
I must be doing something wrong this time because I ran into this same issue last time and fixed it but this time I cant figure it out...any help will be appreciated thank you.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 07-01-2015, 09:14 AM   #860
almost done. first soldering job!
Mugen MBX7R Eco thread!-mugen1.jpg   Mugen MBX7R Eco thread!-mugen2.jpg   Mugen MBX7R Eco thread!-mugen3.jpg   Mugen MBX7R Eco thread!-mugen4.jpg   Mugen MBX7R Eco thread!-mugen5.jpg
worm304 is offline   Reply With Quote
Old 07-01-2015, 02:47 PM   #861
you mean when the suspension is fully compressed ? if you want less camber in this case, put the upper arms higher on the shocktowers.
right now you suspension moves like a triangle. for a even camber in any case, it should move like a parrallelogram
Old 07-01-2015, 02:50 PM   #862
good job ! cool body
what lipo will you use ?
Old 07-01-2015, 09:11 PM   #863
Thanks, man! I have a sky 5000 4s that has been solid for me for the past year. I also have an smc 6500 that is too big because I'm trying to keep weight down. In my tekno that battery lasts forever... I got like 40 minutes of practice time with it.. It was stop and go but still was amazed at how long I ran it.. I will probably pick up a SPC 5000.. From what I have researched they are on the lighter side for 5000 mah batteries... Price can't be beat either! Although I would like to see how much run time the 3600 SMC gets me.
Old 07-01-2015, 10:59 PM   #864
by the way, with the same electronic, which one was lighter ? eb48 or mbx7 ?
Old 07-02-2015, 08:51 AM   #865
Well, I have different electronics in both... The 1800 combo with a 150a esc is considerably heavier than the 120a and a tekin t8i... If I had to guess though the Mugen is probably a bit lighter as a roller. The side and mud guards are definitely thinner more flexible plastic. The shocks are smaller and lighter plus the chassis is tapered and thinner in spots where the tekno feels beefier. I have no real way of knowing but I would say the Mugen is lighter... It's funny but the tekno is totally American muscle and the Mugen is an import tuner, if I were to make an analogy...
Old 07-02-2015, 10:40 AM   #866
Default Upgrade OEM screws?
Hopefully I will finally get my MBX7R ECO built this weekend
Are the stock screws GTG or should I order a set of Tony's Screws for the build.
I am a big fan of Tony's products but don't want to replace the stock screws if not necessary.
DNF2005 is offline   Reply With Quote
Old 07-02-2015, 01:02 PM   #867
good analogy
but I feel the mbx7 might be heavier because of its "old shool " design : large chassis, 16x8 ball bearings everywhere
but indeed, the small shocks might make it lighter...
Old 07-02-2015, 01:18 PM   #868
I stripped a couple screws but that's because I lack finesse at times. Make sure to hand tighten where needed. I've had rc screwz before but never Tony's. Now I'm reading Tony's is better. If you have the funds it can't hurt to start from scratch with aftermarket.
Old 07-02-2015, 05:39 PM   #869
Mauve's Avatar
Aftermarket screws aren't necessary with the Mugen from my prospective. The mugen stuff is up there with the best of them. I've used RCsrewz and Tony's before and found them to be no better than the Mugen stuff. For a little while I thought the Xray screws where a little deeper in the hex keying but with the benefit of hindsight and having ran a XB9'13 and a XB8'14, there is not a real difference. Take your time and care with the initial build and you'll have no issues in the future. I've owned Associated, Losi, Mugen, Xray, OCM and a few others, its for good reason I keep coming back to the Mugen, they offer the right plastics (the best compromise between flex and strength), Alloys are awesome, great build quality, wear really well over time (not to fast) and I rarely break anything. Build it as it comes out of the box and go practice where your going to race predominantly to work on getting the car dialled for you. Also, use medium strength (blue) loctite on anything that screws into metal.
Limestone Coast Remote Control Model Car Club (http://www.lcrcmcc.com)
Special thanks to Kincraig Elite RC for hooking me up with:
1/8 IC Offroad Mugen Seiki MBX7R, AKA Tires, Hobbywing, Spektrum Servos and Sanwa Radio gear
Mauve is offline   Reply With Quote
Old 07-04-2015, 10:36 AM   #870
TOO-TALL's Avatar
Does anyone have a chart that lists the front upper arm spacers?
Like spacers forward what would the caster be?
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
